Question about IBM ThinkPad T30 2366 Notebook
T30 still won't boot after fan replacement
So, all you did was R&R the fan.
I followed the exact Lenovo fan R&R instructions which started with remove battery, remove memory, remove DVD, remove CMOS batery, etc. Looking back i shoudl have ignored all that and just R&R the fan.
This should be simple enough. I'm going to venture to say that either the processor isn't seated correctly, or you missed a connector. Tear it back down, pull the processor, blow it out with air, and reseat it.
I did that twice.
Also check for any connections you may have missed, and reseat the memory.
I did that many times and discovered one of the two 512MB RAM strips is dead, actually killed by the removale process i suppose. So now i get to see the IBM Thinkpad boot screen!! but it will not boot... anything, not HDD1 not HDD2 in Ultrabay, not bootable CD, not bootable flopy.
I set the CMOS time and date. I set teh default CMOS values, nothing makes the disk light flash for boot up. Seems like something else is whacky.
At the initial start, start it without the battery, then reboot with the battery.
Did that, no boot.
You did remove the battery when changing the fan, right?
Yes
Anyway, try this and let me know through the "ask me" tab next to my name.
  • 2 more comments
  • acavedo Sep 12, 2008
    Yes it does.
    BIOS sees built-in HDD and will see Ultrabay HDD if I plug it in. I tried to boot off HDD1, HDD2, CDROM and floppy drives, nothing works. All I get is the BIOS screen on the LCD screen. If I press F12 to show boot list, I only see the Preparing boot list message but the boot screen choices do not appear. It’s like all booting is dead.
  • acavedo Sep 18, 2008
    Here's the thing... it just started working!! It seems OK. Maybe it needed a vacation. Thanks for the help.
  • Anonymous Feb 01, 2009
    I have the same strange problem. The first thing I have discovered is that I have one bad ram slot, the slot farthest away from the esc key.
    The second thing was a insanity inducing flakiness when starting. Sometimes it wouldn't start, sometimes holding the power button would make it start, sometimes pulling the battery and waiting would work...
    SO - what I did was take a piece of paper and return to the only real culprit I had. Ram.
    I folded the piece of paper tightly in the shape of 1/2 stick of ram longways. This gave me a thick thin rectangle which I put on the edge of the good ram slot farthest away from the point of attachment (the pins and such).
    This paper pushed the ram firmly against the pins and has fixed it so far. I am assuming my prob was an incomplete connection at the Ram slot.
    Either way, I hope we all realize that we are talking about 5 year old laptops and that rocks. Show me any manufacturer that makes laptops that last this long...
  • rich medrano
    rich medrano May 11, 2010
    In the bios setup for boot devices does it recognize the HDD?
I previously wrote that I tried booting up the CDROM, HDD1, HDD2 and a floppy. That is two hard disk drives a CD and floppy disk, all were bootable and each was told to boot from the BIOS. So I doubt that I have a bad HDD since both will boot in another T30 I have. I wrote that I had a bad memory strip, not a bad memory slot. Neither of the memory slots are bad as I can plug good 512MB strips in both slots and show 1GB RAM in the BIOS. I replaced the CMOS battery with a new one before reporting this problem.
Got any more ideas?
Thanks,
Allen
Posted on Sep 18, 2008
    Scholar:
  • 188 Answers
One of your memory slots might be bad as I'm assuming you tried both memory chips in the known working slot.
I found setting the boot up sequence in BIOS is better than using F12.
Set your BIOS to boot the CDROM first. I suspect the hard drive has failed or has a problem. Do you have a floppy boot disk? Lenovo has PCDoctor bootable diagnostics on their website. You may have inadvertently bent a pin inserting the hard drive. Your CMOS battery could be dead but since that was untouched I would be surprised.
Posted on Sep 17, 2008
  • rich medrano
    rich medrano Sep 18, 2008
    Okay so everything seems in order but it still won't boot. Everything was bootable to start with so I'm thinking something happened when the fan was replaced. Bent pin on a HDD connector? Cabling not quite seated right? Just asking because the more complicated the problem seems the answer tends to be simpler. I'd ccertainly check the pins on your hard drive first.
Lenovo ThinkPad X61 got "thermal sensing error" when it boot up
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Aug 04, 2012 | IBM Lenovo ThinkPad X61 Notebook
Lenovo z560 cpu overheating problem solved
Jul 24, 2012 | Lenovo IdeaPad Z560 Laptop
Lenovo G555 overheat
Jul 08, 2012 | Lenovo G555 156 160GB Black Hard Drive
I lost my recovery Cd. Where can I buy it?
If you cannot purchase a Recovery CD from IBM/Lenovo then you can download the device drivers from their WEB support site.
To restore your T30 back to the original Windows beg borrow etc a Windows installation CD. This CD must match the Windows version on the label on the bottom of your T30, it also displays the Product Code and this is used to install Windows on your T30.
Follow these instruction to download and install the T30's device drivers.
The same model ThinkPad can have different types of network, video and audio drivers and unless you know exactly which one is installed in your ThinkPad, you need to download all the drivers and install each driver until you find the right driver.
When you download the drivers, write down the device driver and it’s file name so you have a record of which driver you are installing and which directory the unzipped files are located on your hard drive.
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model computer, Use this link: -
http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
You can download the various drivers and then you click on and run the various driver files, they will then unzip and expand into a sub folder on C:\drivers Then install the various drivers from this folder (run the set-up file).
Jun 19, 2010 | IBM ThinkPad T30 2366 Notebook
Lenovo ThinkPad R61 Fan
Were you able to fix it? I took out the fan and cleaned it with a toothbrush (didn't disassemble it). If it worked, can you provide some insight into what you did?
Feb 27, 2010 | Lenovo ThinkPad R61e Notebook
When I boot my IBM T30, I am getting this message "fan error."
Usually that message indicates the CPU fan has stopped spinning for some reason..Possibly needs to be replaced.
Jan 29, 2010 | IBM ThinkPad T30 2366 Notebook
No screen went black on me, but fan is working and dvd drawer opens ands closes
Does the T30 appear to boot up and the hard disk LED flash?
If so you could have a back-light problem - for instruction on identifying your problem and possible fix, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Dec 26, 2009 | IBM ThinkPad T30 2366 Notebook
T30, replaced fan, no boot, no beeps
Did you replace the fan because of a no start problem, or something else?
Aug 30, 2008 | IBM ThinkPad T30 2366 Notebook
Removing password on T30
YES.... providing that the hard drive was not completely re-formated before the windows OS was installed.
Usually, manufacturers leave a section of the HD for this so in the event that something goes wrong, you would be abke to revert back to the manufacturer's setup.
Simply follow the following instructions... :
1) remove power from the T30.
2) hold or tap the 'G' key on the keyboard
3) apply power back on T30 while maintaining step 2)
4) turn on T30 via power button while maintaining step 2)
5) T30 should eventually boot up and in factory default settings.
If this doesn't work, repeat process or the T30 was configured to disable the 'G' key. In this case you need to reflash the firmware on the T30.
Aug 29, 2008 | Compaq EVO T30 Network Terminal
IBM ThinkPad T30 2366 Notebook Logo
576 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
