Question about Frigidaire ATF6000ES Front Load Washer
Washer will not start'
Unit is loaded, power on, water on, lights on set for normal wash, door locks, but not start. No problems until, unit 14 months in two adult household.
  • Anonymous Sep 09, 2008
    door not locking to make washer start
    Novelist:
  • 166 Answers
Even if your warranty was for 1 year and you are at 14 months.
Frigidaire will satisfy your problem with no cost to you.
You have to be calm and schmooze them a little!
Here is what you must do!
I do this a lot for my customers!
We are a family business for over 65 years
READY??
You get together all the service invoices and organize your self with the sales slip and service slips and call GE.
Ask customer service for a supervisor!
Then we are going to get them to do a whats called a "PUSH-PULL"!!!!!
You tell them when you bought it and how many times service has been to your rescue! With documentation of dates
Be calm, nice and reserved! BUT FIRM!
You want them to replace this lemon with a brand new machine! And ask them if this is a model flaw .That you want another machine with an up grade so you are not going to go through this again with this model!
WARRANTY TIME MEANS NOTHING WITH DOCUMENTATION!
IT'S EASIER TO KEEP THE CUSTOMERS YOU HAVE THAN FIND NEW ONES TODAY!!!!!!
EVERY DAY GE OR SOME OTHER MANUFACTURE ASKS DEALERS TO DO A , "PUSH PULL".
THEY PAY US TO ORDER AND DELIVER AND PICK UP THE LEMON FOR RETURN TO THEM!
NO COST TO THE CUSTOMER!
Not even delivery.No matter what the dealer says to you about money! No money, honey! Got me?The companies forbid the dealers from taking any money from the push pull customer !
They pay us!!!
Unless you want to tip the guys on the truck.
Some times I've told my customer that when it's a lot past warranty that for good measure, Tell them,
"I just took a loan to remodel my whole kitchen, and I have gutted the kitchen and found all my stainless steel Ge profile appliances that I am ready to purchase BUT !
But I cannot in good faith follow through with this buy until I see that GE does indeed back up their product!
Your going to love the service and being in control!
You are fine now!
All will be right!
JUST , NO MATTER WHAT HAPPENS CALM, SMOOTH, QUIET, AND HAVE A NICE PLEASANT ATTITUDE. ANGER GETS US NOTHING! iF SOMEONE WILL NOT PLAY BALL, YOU POLITLY ASK FOR THE SUPERVISORS SUPERVISOR!
AND ASK THEM TO SPELL THEIR NAMES AND ID # TO YOU SLOWLY!! THEN WRITE THEM DOWN!
I LOVE THIS!
MY COMPLIMENTS, NGAFM
BLESS YOU!
PLEASE GIVE ME THE BEST RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
My web site is www.nastasisfurniture.com
We started with appliances 65 years ago and still sell them TOO!
Posted on Sep 09, 2008
Whirlpool front loading automatic washer is locked with the locked light blinking and I cannot start the washer or open the door
LID LOCK LIGHT STAYS ON NO START:
Usually either the lid lock mechanism, the lid lock actuator or the board is the culprit even a disconnected capacitor.
MACHINES SAIDS SENSING
When the START button is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer
will slowly spin the dry load to estimate the load size, and begin adding water. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been
added for the load. You may also hear water flowing through the dispenser, adding detergent to the load.
NOTE: The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
Try unplugging the cord a couple of times. See what happens then try going into diagnostic error codes, see what codes are shown. To pin point where the problem is. if you have no display to read the fault codes. Your main control board may be the issue.
Next, while in Manual diagnostics, try to get the unit to spin; if the motor hums for a split second and then shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors.
This is proof that the shifter/sensor actuator assembly is the issue because the optical sensor is not reading the motor speed.
I suggest unplug the washer and check the wire connections on the switch. If a meter is available then you can check the resistance (ohms) of the lock motor.
Note: After performing the manual test and the lid lock works perfectly, or at least as it is supposed to. You can eliminate that as the problem.If the lock worked in the manual test but doesn't in an actual cycle then I suspect the control board is at fault.
A safety feature found on front load washing machine is the door switch and the door lock and strike. On most models, the door switch must be closed and the door lock must be activated before the washer will start. The switch is normally located in the door frame of the washing machine, but may also be part of the door lock assembly. Inspect the strike to make sure that it engages the door lock assembly and that the door remains closed. To check the door switch for continuity with a multi-meter, you will need to disconnect the power and remove the front panel.
The lid switch on a top load washing machine is a safety device designed to prevent the motor circuit from operating when the lOn some models, the water inlet valve circuit is controlled as well. If the lid switch fails, the washer may not start. The lid switch is normally located beneath the main top with a projection on the lid or a pin attached to the lid that will actuate the switch when the lid is closed. Verify that the switch is being activated mechanically and that any levers or actuators are not damaged or sticking. If the switch is being activated but there is no power being supplied to the motor or water valve circuits, then the switch may be defective
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
God is good and that's why I give free advice.
Jan 14, 2017 | Whirlpool Washing Machines
Machine won't start, lights are all on and ready to wash
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Goodluck.
Jun 06, 2008 | LG WM-1832C Front Load Washer
Whirlpool Duet Washing Machine door lock light blinking on panel. Door won't open. Pump humming but no other action. No other buttons will work or light up.
Jan 10, 2017 | Whirlpool Washing Machines
Whirlpool he washer-lid lock light flashing and lid locked. reset by using start/pause/ lock button. start washer-light comes on/sensing begins light starts flashing again and washer stops operating
Dec 26, 2016 | Whirlpool Washing Machines
I have a crosley top loading high efficiency low water washer the green sensing light and red lid locked light comes on and it makes a noise like it's trying to work but won't work
Apr 24, 2015 | Crosley Washing Machines
Machine will fill and wash , but will not fill and rinse
AS YOU SHOULD KNOW KENMORE APPLIANCES MADE BY MANY DIFFERNT COMPANIES AND WITHOUT FULL MODELL NUMBER IT IS HARD TO SAY WHAT IS PROBLEM BUT COULD BE DOOR LOCK OR MAIN CONTROLL BOARD PROBLEM
Dec 09, 2013 | Sears Kenmore Elite 3.9 cu. ft. Front-Load...
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Hirundo wdc 1026. the door lock light is rapidly blinking and won't unlock. I've tried setting every thing to off, running a dry only load but then the wash knob will start to spin and it just...
Sep 15, 2011 | Equator EZ 3612 CEE Front Load...
Maytag Neptune Front Loader Washer
Sounds like the door lock unit isn't locking and may be bad. It is also a possiblity but not likely that there could be a problem with the computer board but start with the door lock unit first
Dec 29, 2008 | Maytag Neptune Washer
Washer door pops open during wash cycle
Start the washer in a cycle. When the door locked light comes on, before unit gets to full of water, see if you can pull door open. If so, you probably have a broken latch. The wax motor is activating the switch, but latch is not actually closing. There was a door latch upgrade for some of these models.
Oct 06, 2007 | Maytag MAH6500 Neptune Front Loading...
Frigidaire ATF6000ES Front Load Washer Logo
98 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
