Question about Goodman Heating & Cooling
Goodman GSC130601BC A/C unit not working - Goodman Heating & Cooling
CONNECT A GOODMAN 2 WIRE AC TO A LUX 5 WIRE
AIR HANDLER
Posted on Jul 23, 2009
I have a 2.5 ton ac outside. the indoor unit downstairs in the basement is a goodman. a new a coil was put in about a month ago. which is a goodman product. ive heard goodman is not a good product. a
the inside coil and outside unit should be matching in tonages another word if you have 2.5 ton outside the inside sould be the same. it don't matter what brand name or who made it.
Aug 04, 2012 | Goodman CKL36AR36 Air Conditioner
I'm trying find out if my old goodman unit was a
Hello WESLEY The unit mod# is 3 ton.If the inside part has an 048 number means together it produces 3.5 ton.If inside is 036 it is 3 ton together.If it is a split.If it is a package it is 3 ton.
Aug 02, 2010 | Goodman Heating & Cooling
Goodman a/c unit outside not coming on. buzzing
Sounds like compressor is bad...taken out by a bad contactor.
Aug 17, 2009 | Heating & Cooling
Goodman AC fan working but not cool air.
0204 built the second week of 2004 sound like you have a loose or burnt wire in the a-c and arcing when the unit comes on. turn the breaker off next time you fix an outlet
Aug 02, 2009 | Goodman CKL24AR24 Air Conditioner
I have an old Goodman(1985) unit and the cover the cracked
tough to tell by the age they probably dont manufacturer parts for that model anymore try calling a goodman wholesaller otherwiseupgrading to a new 13seer unit will cut your operating cost in half
Jul 08, 2009 | Goodman CKL24AR24 Air Conditioner
Model gsc13042aa goodman central air unit sevice manual
just go onto goodman website and download pdf file if that doesnot work call godman with model #
Jul 01, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman SSX16 split system not working
Defective thermostat wire.
Defective contactor.
With the t-stat set for cool and turned down on a low temperature, check for 24 volts at the contactor low voltage hookup. If you have 24 volts, replace the contactor.
You can manually close the contactor to make sure the high voltage is going through it.
Apr 28, 2009 | Goodman CKL60AR60 Air Conditioner
Goodman Furnace/AC unit not working 3a fuse blows even after replacement. once thermostat is turned on and clicks to start ac unit the fuse blows
3 amp is standard.the fuse is blowing to protect the transformer.It is telling you that there is a short in the low voltage wiring.Goodman also had an issue with the coil shorting on the contactor.To prevent damage.....i'd call a pro.It should be a fairly simple repair.
Jul 03, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman a/c unit
Look at this forum and others as well. You will see many issues with Goodman products. Believe the old saying "You get what you pay for!". Carrier, Trane / American Standard, Payne.
May 27, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
781 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
