Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fisher&pakel dishwasher The settings on my office dishwasher wont stay on normal it changes to "delicate" and then beeps at me and doesnt do anything. Is there anything i can do or should i call someone?
  • 136 Answers
I would call the company number to ask
you could have a problem if it is a push button type controll and could have gotten dirty behind it
Posted on Oct 30, 2008
Replaced computer in fisher and pakel top loading washer and still does not work. what is wrong??
does it beep at you? is it dead? if some lights are on while it's beeping, they are an error code, can you relay them to me?
Oct 11, 2013 | Fisher and Paykel Washing Machines
Dishdrawer stops beeps mid cycle
It could have fogged up because you had the drawer cover off in the first place.
The problem may be the alignment of the mirrors. If the control board has slipped down so that the mirrors do not line up to the photo cell and led---that can cause the problem you are having. Make sure the mirrors (light tubes) are properly lined up with the photo cell and led on the control board. You may have to move the control board to make this alignment. Once aligned secure the board in place and this should solve your problem. NOTE: MAKE SURE THE POWER IS TURNED OFF BEFORE YOU MAKE THIS REPAIR.
Aug 19, 2013 | Fisher and Paykel 24 in. DS-603 Built-in...
The time on now shows 107 instead of 127 min. drawer Fisher & Pakel double
your dishdrawer is in ECO mode. Press the ECO button on the program panel on top of drawer lid. This should restore the Heavy wash time to 127min.
Mar 29, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Pakel dish drawer sends F1 alarm flashing. It usually happens when there is a drop or change in water pressure. Have had 3 repairs on this disappointing product. Only repair person for Fisher...
F1 is a flood fault ir happens when the machine detects water on the base of the unit, to clear this fault you can remove the bottom draw and use a towel to clean up the water this should clear the fault, But usually there is only water on the base if the lid is not closing properly, this can happen due to you putting long utensils in and the lid cannot pull down or you have faulty lid actuators witch is probably the case and they wont pull the lid down correctly, So if the lid wont come down properly water splashes over the top and floods the base. :)
Jul 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a fisher & pakel eocsmart cycle but when it gets to rinse it starts beeping and wont drain the water
We had that problem and is was because we had the hose (which is long) too far into plumbing drain it would set off a syphon effect and stop. Then it would start the beeping
Oct 28, 2009 | Fisher Paykel EcoSmart GWL15
How to take or remove drawers out of 2 drawer Fisher Pakel
Hi, welcome to FIx Ya...
1. Unplug machine.
2. Slide drawer open, remove two pegs that secure front panel to drawer (one on each side of drawer)
3. Slide front panel down and out, remove green ground wire.
4. Depress tabs that hold bottom plastic cover on bottom of drawer and remove entire cover, being careful not to break the tabs.
5. Disconnect tan water fill hose from rinse dispenser.
6. Disconnect two wire harnessess at control board.
7. DIsconnect drain hose from pump base. (might want to put a pan underneath to catch water)
8. Depress tabs on hose/harness coupler at bottom rear of drawer and dis-engage the coupler.
9. Lift drawer off slides.
Jan 13, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher pakel water saver washer non stop beeping in cycle
hi any of these beeps that occur outside normal operation are normally indicating an error picked up by the processor and most times requires service you could try switching off machine and unpluging it for a couple of minutes then plug it back in ,this ill ussually reset any memery faults if they are able tobe reset
cheers grant
Oct 21, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher pakel water saver washer stopped early in cycle and is non stop beeping
www.ths.gardenweb.com/forum/laundry
try this website. I found answers to my questions on it that i did not find here.
repairman who came to my house yesterday said manuals are only available on dvd, not in paper anymore.
saw on the other website that you can order FP parts through Sears. have not tried, so don't know if that is reliable. maybe you can order a FP manual through Sears to tell you how to fix your issue.
Fisher & pakel dd-603ss top drawer wont drain
Have you cleaned the drain filter ? If not, clean that ( it is beneath the rack where the utensil bin is normally positioned and accessible by lifting up the plastic door..If that is clogged up then your drain flow will be restricted. Also, check to make sure the drain line is not restricted ( pinced or clogged). .And yes , the drain is pumped out. If these tips do not get you going, please write back and let me know.. will help get your dw going ...
Regards
Oct 10, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
66 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
