Cars & Trucks Logo
Posted on Aug 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1981 toyota cressida, 2.8 l seems like it is starving for fuel idles great, after about 2500 rpm it boggs down. exhaust is clear and secondary ignition is good while acting up.Sensor light is out and stays out.
Ricky Gittins
Level 3:
  • Toyota Master 715 Answers
  • Posted on Aug 25, 2011
Ricky Gittins
Toyota Master
Level 3:
Answers
715
Questions
30
Helped
248467
Points
2077
Check the fuel pressure, minimun 70 psi Minimum Pressure Range (psi): 70 Minimum Pressure Range (psi): 70
Whats the valve clearance for my Diahatsu Mira 1998 850cc?
Mira 847 cc 1993- Engine Code ED 10
Ignition data
  • Ignition system type: El-ecu
  • Ignition coil make/type: Dia/-
  • Supply voltage: 12 + Volts with ballast resistor
  • Primary resistance: 1.35-1.65 Ohms
  • Secondary resistance: 22000-30000 Ohms
  • Distributor make/type: Den/-
  • Contact breaker gap/air: 0.2-0.4 mm
  • Dwell angle: Deg\par Ignition Timing - unleaded: 5 2/900 Deg eng/rpm (without vacuum)
  • Ignition Timing - leaded: Deg eng/rpm (without vacuum)
  • Timing mark location: Flywheel
  • No 1 plug location: Pulley
  • Firing Order: 1-2-3
  • Spark plug make: Bosch
  • Spark plug type: WR6DC
  • Electrode gap: 0.7-0.8 mm
Fuel System
  • Fuel type: U/L
  • Fuel pump type/pressure: bar
  • Engine idle speed: 900+100/-50 rpm
  • Fast idle speed: 2000 rpm
  • CO level at idle speed: 1.0
  • 0.5 Vol %
Engine Data
  • Valve clearance - inlet: 0.25 mm (hot)
  • Valve clearance - exhaust: 0.30 (hot)
  • Compression pressure: 1.2-1.5 bar
  • Oil pressure: 2.5-5.6/3000 bar/eng/rpm
  • Radiator pressure cap: 0.6-1.05 bar/type
  • Drive belt 1 - size: 9.5x925/KDB 925 mm/type
  • Drive belt 2 - size: mm/type
Electrical System
  • Alternator output: 10/2500 Amps/eng/rpm
  • Regulated output: 14.2-14.8 Volts
  • Battery: 12/35 V/Ah
  • Starter motor make/type: Den/-
Other data
  • Clutch operation type: Cable
  • Clutch adjustment: 10-30 mm
  • Cambelt failure: Damage
  • Cambelt Part Number: 13514-87211
  • Tyre pressures: 1.8(26)f 1.8(26)r bar (psi)
  • it took me 3 seconds to google this then i realized that this is a older engine then yours
I have a 2008 mercury Milan with nearly 60k miles on it. When I come to a stop the rpm drops by 1000 then recovers quickly. What should I do to fix the problem? Any suggestions will be greatly appreciated.
Check out related help links to troubleshoot these problem:----Click the link below:---Idles Fine but RPM jumps in drive mode? http://technoanswers.blogspot.in/2012/07/idles-fine-but-rpm-jumps-in-drive-mode.html
---------Mitsubishi Lancer rpm needle bounces? http://technoanswers.blogspot.in/2012/02/mitsubishi-lancer-rpm-needle-bounces.html
--------How to adjust rpm on 2009 dodge charger SRT8?
http://schematicsdiagram.blogspot.com/2011/12/how-to-adjust-rpm-on-2009-dodge-charger.html
Engine cuts out at 3000 RPM? http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
High rpm in neutral? Inconsistant high RPM in neutral? http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
Jetski Sputters and Low RPM? http://whatisbyme.blogspot.in/2012/07/jetski-sputters-and-low-rpm.html
Fuel Injection Problem And RPM suddenly increases http://whatisbyme.blogspot.in/2012/07/fuel-injection-problem-and-rpm-suddenly.html
2005 Toyota Highlander: Engine runs hard RPM below 3000? http://whatisbyme.blogspot.in/2012/05/2005-toyota-highlander-engine-runs-hard.html
1987 Toyota Camry: RPM Drops going Up hills? http://whatisbyme.blogspot.in/2012/05/1987-toyota-camry-rpm-drops-going-up.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500 http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
1990 Toyota 4Runner: Engine cuts off when reaches 2000 RPM?
http://whatisbyme.blogspot.in/2012/05/1990-toyota-4runner-engine-cuts-off.html
1999 Toyota Camry: Erratic stalling and high engine RPM at idle?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-erratic-stalling-and.html
1995 Toyota LS: Misfire at idle or low RPM http://whatisbyme.blogspot.in/2012/04/1995-toyota-ls-misfire-at-idle-or-low.html
Lexus RX: Tapping noise under Valve Cover At Low RPM? http://technoanswers.blogspot.in/2012/04/lexus-rx-tapping-noise-under-valve.html
These will help.
Thanks.
2answers
2answers
'92 toyota Pickup 22re Intake air Leak???
check fuel presure but it is not a likely culprit likely the throtle position sensor has a bad spot in it
it is likely thet the vechale seams to act up at arround the same rpm or near same rpm every time
1helpful
Engine boggs down
either fuel filter or fuel pump...replace filter since its cheaper. 6-12 dollars at autozone
Loping and high idle
You are really onto it! Either the TPS or the cable from the peddle. Do check the cable first. Frankster016
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
