Question about Panasonic PT-47WX49 47" Rear Projection Television
Is there an issue(s) I can check for?
The nearest repairman is 45 miles away, and no means large enough to transport this tv. Can you suggest anything I can look/test for in order to diagnose this problem. I have the other resistors from panasonic and new IC modules(OEM). Can you advise where to look?
  • 4,234 Answers
Since I only have this posting to go on, I don't know your original problem. Can you update this please. Armed with that info, I should be able to give you some details about possible repair solutions.
Thanks,
Dan
Posted on Sep 10, 2008
    Sergeant:
  • 264 Answers
Have you checked the manual
Posted on Sep 09, 2008
Tv will not switch on - when you press power on the remote the tv goes to switch itself on and then switches off straightaway
I've answered three of these so far, so this problem must be a very large manufacturer's defect big among large-screen LCD TVs of a bunch of different makes.
It's a power capacitor inside the TV that controls whether the power supply works or not. Our Samsung 46-inch started doing the same thing with about 2 months of a 2-year warranty left in it, and I'm glad we called the local retailer, because they were aware of this problem and gave us the number to Samsung, who paid to send a trained repairman about 60 miles to our house to fix it. During his repair, I helped him remove the large back cover, and set the TV on its face, and asked him about the problem. He detailed to me exactly what I said above, and also that it's been a very big problem with the rush to get new TVs out to market.
If your TV is still under warranty, jump on this situation before it runs out--it is a hardware problem, not fixable otherwise...
If it's out of warranty, your local TV repairman should be able to repair this for less than $100, easy (the part on ours was a $2 capacitor, the repairman said).
Hope this helps.
Feb 24, 2011 | LG 42LP1D 42 in. LCD HDTV
No heat
It is either the igniter or the limit. Their is a limit mounted
at the 12 o'clock position beside the igniter. If you look at this video you will see it. Well the base of it and 2 philliphead screws that hold it anyway. LOL
Check ot the video HERE
Jan 08, 2010 | All-Pro Propane Garage Shop Heaters - All...
TRANSPORTING A REAR PROJECTION tv
One major suggestion i will make it do not let it fall over or even tip to the side. With most projection tvs any damage to alignment or anything like that can be undone with a correction to the bulb alignment. Any tv repair place should be able to walk you through this or do it for you for a relatively reasonable fee.
Sep 08, 2009 | Philips 50P8341 50" Rear Projection...
1994 pontiac transport se sluggish running
check the sparkplug wires on the firewall side for arching-body seam there that will cut them
Apr 09, 2009 | 1994 Pontiac Trans Sport
Bad color, faded out picture
Hello emtzer, Typically, overtime your tv will become out of tune.
The way a display TV works is by shooting electromagnetic pluses through a vacuum guided by variations of magnetic stability.
What that means is overtime magnets tend to wear down thus resulting in a repairman call. Unless you are a expert in the field of tv repair i would also suggest for you to call them up and have them come fix it again. Although, though experiences and a budget, if you are able to upgrade to a LCD flatscreen I say do it. It will save money in electricity and the hassle of someone having to come fix your display.
Please post what you do and how you did it. I look forward to your posts.
Nov 11, 2008 | Philips 50P8341 50" Rear Projection...
FUEL DELIVERY DRIVIABILITY ISSUE
it could mean that you have a leak and the proper amount of fuel isn't getting to the engine.
Oct 06, 2008 | 2002 Ford Taurus
Detailed problem per your response
The problem is that the ICs may have been blown because the resistors were bad. Just as a double check before you replace anything else. Please confirm that the STKs are STK392-110. Also, replaceing them with STK392-150 is a valid upgrade, I'm not sure about the 180s, but I'll check. Both the STKs and the resistors need to be changed at the same time.
The hour glass view you reported: Was the bowing on the top and bottom or on the sides?
Thanks,
Dan
Sep 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
45 magnum issue
No repairman will come near your house as long as you and the 45 are there... ;-)
Dec 13, 2006 | Sony Grand WEGA KDF-42WE655 42" Rear...
Panasonic PT-47WX49 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
