Question about Uniden BC250D Handheld Scanner
Uniden bc250d I have a 3300xlt which is the same model as the 250d, it needs a new volume sqelsh set up, as the two are on one dail the sqelsh wheel has snapped off can you tell me off enywere in england that will repair the scanner or enywere that will supply the part for me to fit myself ??
2 Suggested Answers
  • 47 Answers
SOURCE: phone is on pulse when dailing a number
open the on screen menu of the phone there should be a selection for dialing rules.. the tone dialing rule should be in that selection..
Posted on Jan 09, 2009
How do I turn up volume on red hand set uniden Dect 6.0?
With many Uniden DECT 6.0 phones, pressing up-arrow during a call will raise the volume.
If this doesn't do it, please add a comment to this question and specify the model of your Uniden DECT 6.0 phone.
Dec 13, 2014 | Uniden Cordless Phone
Doesnt sacerch scan or nothuing
have you done a reset? some radios have a three button reset that you push at the same time. get a manual if you can or call around to a service center they might help.
Mar 27, 2014 | Uniden BC250D Handheld Scanner
THE BATTERY DOES NOT CHARGE
If the battery pack is more than a year old it likely needs to be replaced. Also check the charger output with a voltmeter if possible. Finally, check the contact pins inside the battery compartment. If they look white instead of silvery, clean them gently with a fine wire brush or steel wool.
Aug 14, 2010 | Uniden BC250D Handheld Scanner
How do you adjust volume on base ringer on uniden dxa15588-2
Setting the Main Base Ringer Volume
The main base has three ringer volume settings: high, low, and off. You can change
the ringer volume while in standby mode or while an incoming call is ringing.
1) Press the ringer key.
You hear the ringer at the current volume level
([ ] High, [ ] Low, [ ] off) (if you set the
main base ringer volume to off, “Ringer off” is
announced) and it is displayed on the main base.
2) Press the ringer key repeatedly until the desired ringer
option appears.
3) The system displays the new ringer volume.
Dec 30, 2009 | Uniden DXA15588-2 Twin Cordless Phone
Lost manual
Without the exact model it is difficult to find the manual.
Here the manual for 900 series/996:Uniden EZI996.
I also quote from manual:
Selecting the Ringer Tone and Volume
Base ringer on/off
The ringer switch allows you to set the base ringer on or
off. If you set the switch to off, you never hear the base
ringer tone.
Base ringer tone
Press the ringer tone button in standby mode to select one of 7 ringer tones.
Base ringer volume
Slide the ringer volume adjuster to set the base ringer volume.
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as the volume/ /+ or volume/ /- key) in standby mode to select one of five ringer tones and volume combinations
Apr 17, 2009 | Uniden Cordless Phone
Uniden model tru448=2
http://uniden.com/index/manuals_results.cfm?cat=1
Feb 09, 2009 | Uniden Cordless Phone
Phone is on pulse when dailing a number
Jan 08, 2009 | Uniden Cordless Phone
2 beeps, no dial tone
hand set no dail tone cant all out on the hand set due to no dail tone
Dec 05, 2008 | Uniden Cordless Phone
Uniden BC250D Handheld Scanner Logo
162 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
