Question about ASUS P5S800-VM Motherboard
I CAN'T HEAR SOUND FROM THE INTERNET MUSIC
Sir, i have another problem, my first problem was already solved. now here's another problem, when i try to listen music from the internet i can't hear sound, but when im using my save music in my PC its the only time i can hear sound. sir, please help me fix these problem, thanks.
STOP: 0x0000007B error problem
Posted on Sep 25, 2008
    Guru:
  • 859 Answers
Sure I can help you more as this will be between the two of us alone.
Was the information I gave you before and you rated Helpful something that Solved a problem? If so, would you return and rate that Fixed for me? Thanks.
Regards,
Worldvet
I have to go attend a meeting but will be back on line later tonight.
Posted on Sep 08, 2008
  • Glenn Rogers
    Glenn Rogers Sep 09, 2008
    What Internet browser do you use and what version. When in your browser drop the help menu down and choose the about line entry. The subsequent pop out will indicate what version you have.
    If you are using WindowsXP have you applied the SP3 update? Do check this press, at the same time, the Windows Key and the Pause key. The Pop out will show in the upper right what version and service pack (SP) you have installed.
    What anti virus and pop up blocker are you using?
    Regards,
    Worldvet
We have an HCL desktop computer. Though we had loaded Ac97 Sound Driver still the sound is not coming (totally soundless) Can you suggest what to do?
Try to download and save the Audio Driver and then Run it to overwrite the Drivers and then restart right away. Make sure that you select the right operating system. Normally when you restart, you'll already hear the sound for shutting down and the welcome sound.
http://www.realtek.com.tw/Downloads/downloadsView.aspx?Langid=1&PNid=23&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false
Then try to play the sample music using Windows Media Player. Try to use a headset if there's one available. If it's still quiet,
Note: you'd need a sound blaster or any desktop speaker to be able to hear any sounds. But if there's already a speaker built-in, then it that means the speakers are defective.
Hearing a beep is not the speaker you use to hear the music.
Hope this helps.
Jan 20, 2011 | Computers & Internet
OUT SPEAKER NOT WORKING
this s bcoz of other music files for the ringtones i guess...may be that files might have got corrupted...jus try to update u r softwre for u r mobile and try it sir...then it will work for sure...plz reply if u have further problems!!!!
Jul 30, 2009 | Sony Ericsson W910i Cellular Phone
No sound coming from the T-mobile dash.
If u cant play music or dont hear call u must restore ur phone program first if it does not work u must repair ur phone speaker
Oct 04, 2017 | T-Mobile Dash Smartphone
No sound on my laptop but when i plug in head phone i can hear
Oiie; meu computador também está sem dispositivo de som!
quando eu tento reproduzir alguma música no media player aparece a seguinte mensagem : ' Não é possível executar o arquivo porque há um problema com o dispositivo de som.Ele pode estar sendo usado por outro programa, pode não estar funcionando corretamente ou talvez não haja um dispositivo de som instalado no computador. 'foi_ruim.gif
O computador também não reproduz nenhum outro som.Eu formatei meu computador recentemente e acho que foi esse o problema .fiquei_triste.gif
poor favoor mee ajuudeem.! Meu msn é isalove.css@hotmail.com , caso prefiram. Obrigadaa desde jáa ;D rindo_ate_agora.gif
Apr 15, 2009 | Intel ESS ES1868F Sound Card
I can't hear sounds from my internet browser.
Have you just tried reopening the browser? I get this problem with FF and Opera. Closing/reopening usually solves. Or try updating the browser.
Dec 09, 2008 | ASUS P5S800-VM Motherboard
No sound
Sir,
Please explain that from which you are not getting the sound??? is that from laptop or dvd system....??????
Please explain to get a solution......
will get back to you....
Nov 25, 2008 | Philips HTS-3555 System
AUDIO PROBLEM HELP PLEASE
In whatever player you are using for video with audio on the Internet check the player controls that mute is not selected or the volume is not turned down. These players will work audio independently of the volume properties sliders.
If this approach is not consistent with your problem you may need to repair your audio codecs on your machine a good program to install that will add-in codecs and repair any broken codes is K-Lite. You can get it from this location. Select a download mirror and then allow or start the download. Once you have downloaded it install it and let all the default settings ride.
Let me know how this works out for you.
Regards,
Worldvet
Sep 07, 2008 | ASUS P5S800-VM Motherboard
Nokia N73 Music voice problem
dear sir ,
pls upgrade the software&change the MIC of the phone ,if not solved than change the IC( retu).
Jan 20, 2008 | Nokia N73 Cellular Phone
How to implement music player in online music site
there are a million different online media players that will do the job, merely search for "embedded webpage media player" and your bound to find one. most have to be HTML coded into the page..
Dec 06, 2007 | Computers & Internet
NAD C740 no longer reproducing music through loudspeakers
what was your amp? ic or transistorized? the output transistor of your amp may be opened, mostly it will short but because u still hear sound, maybe open and only the driver transistor are working. replacing output transistor or IC could solve the problem.
May 14, 2007 | NAD C320 2-Channel Amplifier
ASUS P5S800-VM Motherboard Logo
156 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
