Question about Apex Digital GB5108 51" Rear Projection EDTV-Ready Television
Blue wave across screen
My tv usually takes about 5 minutes to warm up before the picture would show. Now it powers on then a blue wave is across the screen and after about 10 minutes it shuts off.
  • jmanhunt78 Sep 11, 2008
    When the tv powers up a blue line come across the screen
  • 2,071 Answers
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Posted on Oct 10, 2008
Faulty BUSH FLAT SCREEN TV
Hi there are a few things that could be wrong with that TV. The power supply can be faulty, you can check it for bad bulging capacitors and replace them and see if that fixes the problem. The other two things would be your signal board or your T-con board. The T-con board would be the most likelly.
you can get parts for this TV at www.interliquidparts.com
Feb 29, 2012 | Televison & Video
TV turns itself off after about 5 minutes (green light remains on). I can turn off the TV and turn it back on immediately, however, the TV turns itself back off after a few minutes. It started turning off...
Check and make sure your fans are working and there is sufficiant cooling to the back of the set. Sounds like it is overheating and going into protection mode.
May 04, 2011 | Mitsubishi WS-65513 65" Rear Projection...
When powering Samsung TFT-LCD it turns on w/dots or lines in the screen that are only removed if restarted (usually multiple restarts are necessary). Also, on occassion, the TV will do a series of beeps...
I f the TV needs warm up to get working right; don't turn off for a few days and see if moisture on the circuits can be dried off. Or keep it on standby to prevent build up of any condensation on the circuits.
Mar 11, 2011 | Samsung Televison & Video
I've got a 4 to 5 year old panasonic tx32pd50 tv and it has just started to show signs of a problem. when the tv has been off for a few hours and then turned on from cold the picture is distorted and...
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 07, 2017 | Panasonic Televison & Video
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Jan 26, 2009 | Televison & Video
Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KLV-S23A10 takes approx 30 minutes to warm up
OFF YOUR TV WITH POWER BOTTON, THEN PRESS IN REMORE CONTROL DISPLAY BOTTON # 5 BOTTONVOL + BOTTON AND POWER BOTTON.( DISPLAY--5--VOL+--POWER)
May 04, 2008 | Sony KLV-S23A10 23 in. LCD HDTV
Powering up and warmup problems
why does my lcd monitor change different colors no picture just turns to all sort of colors ViewSonic N2751W 27 in. LCD Television thanks 4 your help
Dec 05, 2007 | ViewSonic N2751W 27 in. LCD Television
Blue Yellow Wave
I believe what you have is a convergence problem and it is usually caused by two Integrated Circuits going bad which also opens up one or two resistors associated with them. Replacing the Convergence Ic'S - (Ik04 & Ik05) and Resistor Rk62 a 1.8 Ohm .5w. Metal Film type should take care of the problem. As far as costs involved, I would guess about $350-$425 to get repaired. With it only being about 4 years old, it should have that many more years left of good use for you.
Mar 11, 2007 | Hitachi 43FDX01B TV
Apex Digital GB5108 51" Rear Projection EDTV-Ready Television Logo
167 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
