Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Lid switch i used to have to lean on top of the lid to get it to cycle once it reached the 6min., now i have to put a pen down into the slot to get the switch to work, it is starting to slip & is getting more difficult to find a connection for that system to work, any suggestions??
  • 5,911 Answers
Yes...replace your lid switch. It is not normal to have to use an ink pen, lean on the washer lid, slam on the lid, or use any other means to operate the washer outside the normal functions that it was designed for. In many cases, you actually cause more damage to the appliance by not investigating the cause of the problem. A lid switch is a very simple and inexpensive fix. The following link explains how to replace a lid switch:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
In many cases a simple inspection of the lid switch is all it takes to fix it. It could be loose or not making proper contact. Repeated slamming of the washer lid or using a foreign object to get it work, however, may have damaged it. Check the mounting screws that hold the switch in place, first. If the screws are loose or missing, that may be all this required to get the switch to line up correctly with the lid strike. The lid strike is a small plastic piece that is physically mounted to the washer lid. The strike activates the switch through a slot as the lid closes. If the lid strike is broken or missing, this will also cause the same symptoms.
If the model number you have this listed under is correct, you can find replacement parts at searspartsdirect.com. Just type in the the model number and you can locate what you need under the "Top and Cabinet" heading. The lid switch is item number 11 (part #3949247) and the lid strike is item number 20 (part #358684).
I hope you find this information helpful. The total cost of your repair is less than $50 if you follow the instructions in the link I provided. Repair it yourself, save yourself from an expensive repair, and potentially get some longer years of use out of your washer. Let me know if you require additional assistance.
Posted on Sep 11, 2008
Water goes into the machine but the spin cycle don't work
Most washer under the lid you will see a peg of some sort that goes into a slot or hole on top face of washer. That is called a switch. It is designed to be a safety device, so when the washer is on that high speed spin cycle a child or not to smart adult does not open lid when washer is spinning at high speed. The switch is designed to only allow the machine to spin when lid is closed. It appears to me, which happens all the time, is from normal use, that switch might of Went out. Here is what you do to test it. Carefully!, have lid open and put washer on spin cycle and take a flat head screw driver in the slot where lid peg goes and depress screwdriver in slot, and listen as you put it in slot and release it, do it a few times, if you don't hear a clicking sound of like click, click, then switch is out and will not allow washer to spin. Switch then needs to be replaced which is cheap and pretty easy to do your self. With deal with that once you have determined the switch is working or not. Thanks mike
May 29, 2011 | Washing Machines
How do I replace the lid switch
there should be two screws on the back of the head the plactic piece on the left and right side that hold it down once you undo the screws the head should come up then there is two brass looking clips depending on how old you put your screwdriver in thoughs and unhook them from the cabinet from ther you simple lean the cabinet forward and you have easy access to the switch
Jun 02, 2010 | Roper RAS8244KQ Top Load Washer
All cycles work except the spin cyle
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 08, 2009 | Washing Machines
Admiral washer top load will only spin on delicate cycle, all other cycles work except for the spin cycles
Feb 01, 2009 | Washing Machines
Washer stops mid cycle
OK.. to the back left of your lid, under the top casing, by the hinge.. you have a hook metal bar that activate the lid switch.. hard to describe, but I'll do my best.. use left hand lift up on down on lid.. use right hand, reach under lid and find metal hook.. ok.. push up on lid and right hand push back on metal hook slightly(not to much).. now try closing lid and see if you heard clicking noises.. also, in the future try not to let the lid drop down, that will bend the hook.. hope you got it.. good luck...mike
Jan 23, 2009 | Washing Machines
Washer won't spin or drain
I took the easy advice first. One guest said it was the lid switch. So I opened the lid and put a clothespin in the hole and then leaned the lid on it and guess what??? It began to drain and spin perfectly! PHEW... that saved me some time and money till I can get the switch replaced. THANK YOU "guest" from August 11th!!!
Aug 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
WASHER NOT AGITATING OR WASHING
This is a common symptom of a defective lid switch. If you try opening and closing the lid and do not hear a distinctive "clicking" sound, your lid switch may need to be replaced. Some lid switches are located on the right-hand side of the lid opening with a small slot. It is activated by a plastic piece called a “lid strike” on the lid itself. Make sure the lid strike is not broken off. This will keep the switch from not working. On some model washers the lid switch is located on the left-hand side, in the rear, mounted under the casing near the lid hinge. It is activated by a rod on the lid hinge. Sometimes the rod can be adjusted if it is not making good contact with the switch. In either case, if the switch is not activated, it will allow the washer to fill and maybe agitate, but will not start the rinse or drain cycles. If you diagnose it and wish to attempt the repair yourself, the switch costs about $35 and is fairly simple to replace if you follow the steps below:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions please let me know by posting comments.
Feb 15, 2008 | Roper RAX4232KQ Top Load Washer
Washer Stuck in Cycle
The timer is bad / shorted. Mine used to try to spin with the water in it... that was a sight to see!
Jan 11, 2008 | Whirlpool LSN1000LW Top Load Washer
Washing machine won't empty water
this can often happen on a top loader if the lid switch is not engaging properly.  The drum usually rotates (slowly at first, then much higher speed as the water is expelled) and, as a safety precaution, there is a locking mechanism for the lid. You will get the same result if you leave the lid open... cycle just pauses at the drain/rinse/spin part of the cycle.
Now, to solve the problem...
First we need to confirm the problem ...put the dial in spin cycle and see if you can open the lid, or if it is locked.  If the lid opens ,then you are probably not engaging the switch that enables the washer to lock the lid ( and turn on the pump).
THe switch is activated by a piece of plastic ( often in the form of a loop) attached to the lid which pokes through a slot in the metal top of the washer. a microswitch is located down in the slot. If part or all of the plastic piece is broken, the switch will not be activated.  If found to be broken, these are available at any appliance parats store, cheaply.
Sometimes the switch mechanism shifts down slightly or the internal workings of the switch wear down to where the plastic piece does not push the switch down far enough to activate.  You can test for this -*USING GREAT CARE*  by inserting a plastic stick or other non-conductive (electrical) material (a popsicle stick or plastic drinking straw works fine) that fits in the slot and can be pushed down an inch or so.  The test would be to put the machine in the spin part of the cycle and, with the lid open, insert the stick/straw down into  the  slot (you may hear a click from the  switch). This should turn on the pump if the problem  was that the switch had not been contacted properly by the plastic part on the lid.  Only do this for a moment as it is not safe to run the washer with the lid open (they lock the lid for a reason :).
If this procedure does start the pump, then you have isolated the problem and need to have the plastic part on the lid press down further into the slot to activate the  switch.   For a $50AU washer , i might try to build up  the plastic part with some tape to penetrate into the slot further (dont put on so much that it doesnt fit in the slot or gets in the way of the locking mechanism).
Alternatively you could replace the switch or plastic part, or both (replacing the switch will require taking off the front panel).
do the tests suggested and get back to me.
Gidday!
(from a yank that would like someday to visit coober pedy and ayers rock, along with the other spectacular places and people of Australia... oh, yes, and meet Crocidile Dundee too  :)
Oct 28, 2007 | Admiral AW22 Top Load Washer
Malber p21 spin
the lid switch must be broken if you know how to use an screw driver you can fix it remove the lid witch and replace with a new one, remember to unplug the machine frome the wall...good luck
Aug 04, 2006 | Malber P21 Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
71 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
