Question about Epson Stylus CX3200 All-In-One InkJet Printer
Scanning problem I?m unable to scan even after installing and updating drivers.
  • 196 Answers
Re: Scanning problem
I?m afraid helping you would be impossible unless you give us all the relevant details: - What is the exact model number of the scanner? - What computer are you using? - Does the computer recognize the scanner? - If yes, what error message are you getting?
Posted on Feb 22, 2006
0 characters
3 Points
Unable to scan, however it does copy??
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Follow the simple steps below:
  1. Disconnect your printer from your computer.
  2. Reboot your computer.
  3. Unplug and re-plug the printer into the power source to reset it.
  4. When the printer turns on, reconnect it into your computer.
  5. Try to scan again.
You can also re-install or update your Lexmark X2670 printer driver by visiting the Lexmark website at Also, if you are scanning a document for editing, make sure to install the Lexmark OCR scan software. The scan software can only be installed using the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for additional assistance.
Jun 01, 2011 | Lexmark X2670 All-In-One Printer
Hello I have a hp printer and I am trying to scan a document to my pc.but i get this error msg 'scanning error'try scanning from pc or check documentation.
You must also install the scanner driver too, and also the scanner management software, if installed properly one can scan fro paint, Word, Publisher and the like, as well as the software that comes with the scanner. There are also other scanner programs on the net, Vuescan, doesn't even need a driver to work, there is scantopdf, and quite a number of others. So go to the HP website and download the scanning software and the scan manager and install them, then you will be able to use the scanner as it was intended.
Jul 12, 2010 | Printers & Copiers
Unable to scan muiltible pages into a PDF document
Do you get any Error when Scanning ? does it scan single document into PDF ? if no, try to update Adobe Reader and then try scanning
Jun 18, 2010 | HP LaserJet 2840 Printer
My HP C4480 scanner only returns a black image (on
Did you repaired old drivers? if so first uninstall your products drivers and also its folders from program files, then uninstall "wrong update" and reinstall scanner. sometimes built in scanning modules comes wrong but everything works with original scanning software, use different software to scan and some of them may work perfectlly.
Feb 20, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Dont know how to get scanner working
The printer and scanner use different drivers! Check if you installed the scanning driver and software too. Usually the installation media contain a bundled scanning software! Beware of any other driver tha may have been installed in the meantime! You may try a drivers update!
Nov 26, 2009 | Canon MX300 Office All-In-One Printer
HP Photosmart c7180 unable to scan since Windows 7 computer
go to following location and try to scan and tell me if it is scanning fine or same issue.
c:\program files\hp\digital imaging\bin in bin folder locate following files. /* in 64bit operating system inspite of program files look into programe files(x86).*/
1.> hpqscnvw
2.> hpqscnappi
3.> hpqdstcp.
4.> hpqgrpky.
double click on any of these it will start scanning.
Nov 19, 2009 | HP Photosmart C7180 All-In-One InkJet...
Problems Scanning
I would delete the twain scanning driver and reinstall, but first disconnect the usb cable from the pc and reconnect after you install the scanning software.
Aug 09, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Photosmart C7180 not scanning
I had this very same problem yesterday & solved it, after about 4 hours, with a clean install!!
Check my "solution" post at another question where I explained it in detail.
Dec 29, 2008 | HP Photosmart C7180 All-In-One InkJet...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
32 people viewed this question
Top Epson Printers & Copiers Experts
Are you an Epson Printer and Copier Expert? Answer questions, earn points and help others
