Question about HP Pavilion ze2000 Notebook
Problem with wireless internet connection
I've reinstolled windows on my lap-top a couple days ago...and after that when i try to refresh network list it doesn't show any networks...i have no idea what to do...
  • Anonymous Mar 18, 2014
    cant locate the switch to get access to the internet on my HP 6530b lap top.is there a picture that shows where I'm to look?
    Problem Solver:
  • 8 Answers
Is your wireless card installed check in the installed devices section and see under network controllers if there is a wireless if not you'll need to run windows update via a lan and get the drivers if not find the support page for your laptop and download the drivers for the Wireless LAN card.
Posted on Sep 08, 2008
Wifi on laptop
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 28, 2012 | Computers & Internet
Net book will not connect to internet through WiFi. With cable is ok
Here are some suggestions that may resolve your problem....
1. if another computer is connecting OK through WiFi, then the problem is likely with the N150
2. if nothing else is connected through WiFi, then you need to check both N150 and router
3. on N150 without cable, click start and click Control Panel then double click Network Connections
4. Network Connections should show Wireless Network Connection and Local Area Connection
5. if Wireless Network is missing, click back and double-click Wireless Network Setup Wizard
6. if wizard done but Wireless Network Connection is Not connected in Network Connections window
7. in Network Tasks in left sidebar of Network Connections, click View available wireless networks
8. in Wireless Network Connection window, click on Refresh network list in Network Tasks sidebar
9. if No wireless networks were found.... then Make sure the wireless switch on N150 is on
10. with the N150 wireless adapter now enabled, click on Refresh network list
11. if SSID for your router's wireless is listed but not high-lighted, click on it to select the SSID
12. click the connect button, if security-enabled wireless network, a pop-up appears for key input
13. click the connect button after entering and confirming key inputs
14. if after step 10 the SSID for your router is NOT listed, you will need to log into the router
15. connect the N150 to the router using the ethernet cable then open Internet Explorer
16. in IE's address field, type the router's IP address - it is in the form of 192.168.x.x
17. if it is not known, open Network Connections window (step 3) and right-click Local Area Connection
18. in the pop-up, click on status
19. in the Local Area Connection Status window, click on the Support tab
20. the Default Gateway has the router's IP address
21. after entry of IP address, IE presents a router login window for userid and password entry
22. unless changed, the router userid and password defaults are given in the router's manual
23. on the first router screen (usually Setup), click on the Wireless tab
24. if Wireless Network Mode is Disabled, click on v for pull-down then click on appropriate mode
25. if SSID is blank, enter a Wireless Network Name then click Wireless SSID Broadcast enable
26. click Save Settings then click on Wireless Security tab in the Wireless window to set WEP/WPA
27. see your router's manual for details on how to setup WEP or WPA mode and its key
28. if you don't want wireless security (OPEN), then set Security Mode to Disabled (default)
29. if any changes, click on Save Settings then click on x at top right corner of IE to close it
30. disconnect the ethernet cable and right-click the Toolbar's Wireless Network Connection icon
31. if the icon (a single screen with ))) beside it) has a little red x, then on the pop-up...
32. click View Available Wireless Networks then in Network Tasks sidebar click Refresh Network List
33. continue with connecting to the wireless network at step 11....
Feb 21, 2011 | Samsung N150 (36725723009) Netbook
Lap top WI-FI does not work with this WBR-1310...no signal showing connections...however, did work a few days ago. Using HP laptop Pavilion.
Make sure you didn't accidentally hit or tap the wireless button as that shuts off all internet connecting abilities.
Apr 10, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Can't get wireless internet to work on dell laptop
May I suggest you give Network Magic a try at solving your connectivity problems. Free to download and evaluate, you may well find it is well worth the couple $ for the 5 full licenses. Get it here: http://www.purenetworks.com/nmlp/home-networking.php?gclid=CPua-J-J1J4CFVw55QodUi_Nrw&src=google&kw=network+magic+download
In addition to connectivity, NM will aid you with security and sharing as well as other fine features.
Thanks for posting at FixYa.com
Oct 01, 2009 | Linksys Wireless-G Broadband Router
HPDV7-1267CL LapTop
Hi raji767. You left out a few important details such as which operating system you are using and if the WiFi signal you are trying to connect to is encrypted. I will try to give the best step by step instructions I can based on the info you gave. I am assuming you are using either Windows XP or Vista. First, make sure the wireless is turned on. There is a button on the side by the headphone jack which turns the wireless on and off.
WINDOWS XP: Click Start, Control Panel. On the left side of the control panel window you should see "switch to classic view" or "switch to category view". To make it easy, make sure you are in classic view. Next double click the icon labeled "Network Connections". Next, right click on the "Wireless Network Connection" and select "View Available Wireless Networks". In this window you should see the network you are trying to connect to. Next just select the network and click connect. NOTE: If the network is encrypted, you will need to enter the key after pressing connect.
VISTA: First, go to "Start Menu", "Control Panel", "Network and Internet". Next, go to "Network and Sharing Center" and select "Connect to a network". Choose "Show All" and hit the refresh button. Now just select the network you want to connect to and click connect.
Hope this helps. If you have any questions just let me know. Good Luck!
Aug 23, 2009 | Cisco CAB-OCTAL-ASYNC Serial Cable HPDB68M...
My Belkin G Wireless Router cant even get passed step 1. My lap top recieves the signal but their is no internet! Help please
Since your unable to access internet through the router(wireless) ,& globe light is flashing--I suggest you to refresh the network list and connect to your network again still if it won't work then you need to Re- configure it. Because your Modem(cable/dsl) is working fine. Check the ip address of your computer. if its invalid then you need to do the "reset" on router (ip address should be 192.168.2... range).
Or else you can call (toll free number) for belkin for reconfiguration
Hope this suggestion helps for you both...
Apr 11, 2009 | Belkin (F5D7230-4) Router (587009)
Wireless network adapter problem
Check to make sure you don't have a manual switch on your laptop, I have a Lenovo T60p the switch is in the front so some times I pick it up and I kind of turn the switch half on and half off. Same result no internet until I turn it all the way to the on position and reboot. As far as the turn on and off sounds like it could be a battery issue. Try running your laptop without the battery in it and use just the power cord to see if you get the same result.
If you think it's a virus try booting up in safe mode with networking and see if you can connect using the wireless and also try wired to your wireless router.
Goodluck
Jan 28, 2009 | Computers & Internet
How do i use my built in wireless connection to connect to the internet,please.
make sure that your wireless or wifi light is on,you may try to press Fn and F2 at the same time to enable or swith on wireless..if wifi is already on,try going to start >> control panel >> network connections,go to wireless network connection and double click it, it will give you a list of wireless network,or right click and then "view available wireless network", if you get an error that windows cannot configure wireless connection,go to start >> all programs >> loo for either dell wlan utility or intel pro wireless, by opening that app,it will also search for wireless network in range,just double click on the network name where you want to connect and you sould be connected provided that "wireless network" doesnt have encryption like wpa or wep key..if your connecting to your home network,you should have wireless router at home and wireless is enabled on the router.
Oct 05, 2008 | Dell Inspiron E1705 Notebook
Computer won't recognize wirless network
try resetting the router to refresh it's hardware, there should be a small reset button on the back somewhere , but be aware you may lose all configuration settings if you do do this , so if you're unsure what your are doing don't hesitate to ask.
Apr 14, 2008 | SMC Barricade 7004VWBR Wireless Router
HP Pavilion ze2000 Notebook Logo
183 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
