Question about Xerox 6100/DN Laser Printer
Printing problem Sometimes when I try to print something I get a message: "the printer at 0*0000000 referenced memory at 0*0000000 and could not be read click cancel to abort or ok to ignore" When I click OK, it doesn?t print the whole document. Any help would be appreciated.
    Novelist:
  • 196 Answers
This error message indicates that the printer memory is full. You might be sending too many documents to print at the same time. I would suggest dividing the number of documents/pages into smaller groups so the printer can take the load. Hope this helps!
Posted on Feb 22, 2006
  • Jogesh
    Jogesh Dec 22, 2013
    how to solve error 5100 for canon mp 287
Memory low message on hp laserjet pro 200
see HP LaserJet Pro Printers Memory is Low message displayed on the control...
HP LaserJet Pro Printers - 'Memory is Low' message displayed on the control panel HP LaserJet Pro - Troubleshoot 20.xx (memory failure) and 21.xx (print failure) error messages (ID: emr_na-c05049204)
HP Customer Support page and ensure the printer is running the latest available firmware. Print a Configuration Report from the control panel of the printer to check the installed firmware version.
  • If the printer supports expandable memory, you can install additional memory in the form of a DIMM. Check the printer's User Guide to see if it supports additional memory.
  • Break complex print jobs into smaller jobs that contain fewer pages.
  • If the printer is an MFP, delete stored faxes to increase available memory. Go to this document for instructions: HP LaserJet Pro MFP - Delete faxes from memory (ID: emr_na-c03264743)
  • Power cycle the printer to delete stored fonts or macros. It is possible to download fonts or macros in a way that power cycling the printer will not delete them; see Appendix A - Memory Allocation.
  • Changing some software and/or print driver settings might result in a less complex print job.
  • Use a different print driver. For example, a PostScript print driver will typically result in a more complex print file. If possible, try sending the file with a PCL6 or UPD printer driver.
  • Adobe PDF files can sometimes be very complex. Go to this document if printing PDF files is slow or resulting in memory out messages: HP LaserJet - Print job is slow or hangs in the print queue when printing Adobe PDF files (ID: emr_na-c04071740)
  • If the printer is connected via a network, try sending the file connected by USB cable only. This will eliminate possible network issues that are taking printer memory.
  • Appendix A
    Memory Allocation Utilities or jobs that you download to the product sometimes include resources (for example, fonts, macros, or patterns). Resources that are internally marked as permanent remain in the product memory until you turn the product off.
    Use the following guidelines if you use the page description language (PDL) ability to mark resources as permanent. For technical details, see an appropriate PDL reference for PCL or PS.
    • Mark resources as permanent only when it is absolutely necessary that they remain in memory while the product is turned on.
    • Send permanent resources to the product only at the beginning of a print job and not while the product is printing.
    NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
    Sep 08, 2016 | HP LaserJet Office Equipment & Supplies
    This message appears when trying to scan something: "Running out of memory. Increase memory available. Scanner driver will be closed.
    On your computer click Start, double click on - printers and faxes, right click on - your printer, click on - properties, select the advanced tab, if not already selected, select - always on, select - spool print documents so program finishes printing faster, select - start printing immediately, select - print spooled documents first, select - enable advanced printing features. click - apply and close any open windows and try a print project that was causing the message to appear.
    If there is still a problem, just send a message and we'll figure it out. Jim
    Jun 20, 2011 | Canon Pixma MP800 All-In-One InkJet...
    It keeps saying memory low, what should i do
    If you already sent a job to print, wait until is finished. These printers have internal memory, like the pc RAM, and if is not big enough you get this message. You can upgrade this memory to a higher capacity. If you haven't sent anything to print, check the printing queue, sometimes it has paused/stopped printing jobs that use up the internal memory.
    Feb 09, 2011 | HP LaserJet CP1515n Printer
    Computer says unable to communicate with printer : if using firewall unblock UDP port 427..I'm not sure how to do this. This problem occurs sporadically..sometimes the printer works, sometimes it doesn't
    Most of the times just skipping that message will let you use the printer. That message is something that has to do with the printer rediscovery just incase the printer get's disconnected.
    Checking with your anti virus software provider might help.
    Regarding that message though. Try skipping that and try printing.
    The printer should work.
    Feb 06, 2011 | HP Officejet 6500 Wireless All-in-One...
    Dell 2135 full memory error message cannot print PDF files.
    All three replies are incredibly stupid, but especially Frank's. The issue is simply that you're trying to print something that has too much complexity in it for the printer's pre-installed memory to store the final rendering of before printing. The way a laser printer works, unlike an ink jet, it has to take the entire page to be printed and render the final output in memory before the page can be fed through since it doesn't go line by line. If you're trying to print something that has a very complex page in it, such as a full 8x10 photo, the base amount of memory may not be enough. Dell sells a 256MB add-on memory chip you can put in the printer to get around this. Unfortunately the only other way around the issue would be to reduce the complexity of the page; perhaps try printing the PDF scaled down to 70% so the printed output is a lot smaller but also takes up less of the page, meaning the printer may be more likely to be able to fit the page into the existing memory.
    Nov 24, 2010 | Dell 2135cn All-In-One Laser Printer
    On HP 5MP laserjet Printer, on printing a document, the message says: the printer requires more memory than is avaailable in this printer.what to do then?
    You don't say what kind of a document you are trying to print. Did you try to print something else. Did it print?
    Normally if you try and print a complex spread sheet you may get that warning. You have the option of adding more memory or making your print job less complex. Or printing to another printer.
    Oct 03, 2010 | HP LaserJet 5mp Printer
    Message Ink Cartridge stalled
    the machine needs servicing, something is causing the carriage to stall
    Nov 04, 2006 | HP PSC 1350 All-In-One Thermal Printer
    Xerox 6100/DN Laser Printer Logo
    141 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Philip Hughes
    docukaaf
    Level 1 Expert
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
