Question about Dryers
Belt breakage I just replaced the belt, and it is broken again. It appears to have broken, no sign of burning. The idler pulley appears to spin freely and there are no burrs in the motor pulley, Please help me. Thanks Andy
  • gajrwolf Apr 19, 2009
    I am having a problem with my maytag dryer betl breaking. It is a DE410 model. I have had 2 break on my in the last 2 weeks. All rolers are spinning freely and the idler pully spins free. I have checked for burrs on burrs. What should I look for. One thing I'm not sure of is the specific way the belt goes around the idler pulley and the pulley on the motor. Is there a view I can see to show me the way it should go?
    thanks
    Greg
  • 550 Answers
As well as the obvious pulleys on the belt, most dryer drums are suspended on felt or nylon glides. and a pair of load bearing wheels, separate from those supporting and tensioning the belt.
If the drum support wheels (which are a cruddy bronze bush bearing and do fail) are stuck, or the felts or nylon glides have worn allowing metal to touch metal, the extra load will break the belt.
It could have been the cause of the first belt failing too.
Open the case agan (sorry) and examine the underside of the drum for stuck support rollers, and the drum itself for felts or nylon glides. If one is worn replace them all (they come in sets anyway).
The local parts guy will likely have the parts, as there are very few, common to many dryers
Sorry this is a generic answer, but there is no model given so cant tell you whether you are looking for just rollers, just felts, just glides, or any combination of the three.
Posted on Sep 08, 2008
1998 malibu shreding belts
Before installing a new belt spin all pulleys by hand. They should spin amoothly and freely. Check alternator, idler, tensioner, power steering and A/C. If any are hard, rough, or seized replace. Check that the belt aligns correctly with all pulleys and remove any debris embedded in the grooves.
Feb 24, 2013 | Cars & Trucks
Kenmore 70 Series Dryer Belt Keeps Breaking
A few things to check. Make sure that the idler pulley is turning freely without any signs of distress from the bearings. Make sure that when the belt is installed that all drum, motor and pulleys are perfectly in line. Even a small amount of misalignment will cause premature failure. Turn the drum by hand and make sure is turns fairly freely. There will be some drag from the drum supports, but it should turn readily with one hand, if it is any stiffer then the drum supports may be badly worn and will need to be replaced. Make sure that the pulleys on the motor and idler are in good condition and not damaging the belt. There are basically only three main reason for a premature failure, misalignment, pulley damage and overloading. It has to be pone of those.
Nov 26, 2017 | Kenmore Whirlpool Maytag Dryer Belt...
What makes a belt squeak?
Belts squeak for the same reason tires do when they spin. They are slipping. Something isn't turning as fast as the belt wants it to. On ford it's usually ether the idler sprocket or the tensioner. If you remove the belt and try spinning all of the pulleys by hand.( note the crank wont spin freely) you will usually be able to tell witch ones slipping.
May 14, 2011 | 1999 Ford Taurus
Why belt keeps shredding
usually due to a bad bearing, or from resistance due to a frozen or failing assemble, as in power steering, alternator, or an idler. The best way to determine is to remove the belt and check all pulleys for play and resistance.
Feb 10, 2011 | 2000 Chevrolet Venture
My belt keep coming off the idler polley
Check the alignment of the pulleys. Most common problems are: 1) Belt tensioner. 2) Idler Pulley. 3) Crank Pulley (Vibration Dampner)
Mar 08, 2010 | 1995 GMC Jimmy
Dryer turn on but would not spin
When the dryer will not spin the most common cause is a broken dryer belt.
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Sep 14, 2009 | Kenmore 63942 Dryer
Replaced broken washer belt, but drum still won't spin.
you may have a bad bearing in a pulley,could be motor coupling. Take belt off and spin motor shaft and pulley both ways if it's free, then its more than likely not the motor. Now spin the drum with belt off and see if it does the same as with the belt on if it does it has to be a bad bearing or coupling to the drum. hope this helps
Aug 24, 2009 | Amana ALW480DA Top Load Washer
My Sears 917.272911 Lawn Tractor is eating mower drive belts. The belt is being worn out in minutes on the flat idler pulley side. When I put the old belt back everything seems to work fine. The new belts...
There's a couple of things that could be causing this. First, make sure the idler pulleys and blade pulleys spin freely. Second make sure the belt is behind the belt keepers on the two idler pulleys. There is only one on the left idler, but TWO on the right idler. I suspect that is your problem. Anyway, once the belt is on, engage the blades, with engine OFF, and inspect the belt routing, making sure it's not over or under something it shouldn't be.
Jul 02, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Serpentine belt slips off idler pulley
The A/C pully is supposed to spin freely until the AC is activated to run.. The cranshaft pully does not. Replace the tensioner pully. The belt has to fit in between the grooves on the pullys.
Apr 05, 2009 | 1994 GMC Suburban
Maytag MDG3000AWW drum moving slowly
If the belt looks worn you should replace it. But it sounds like the idler pulley has gone out of position or possibly broken. The idler pulley adds tension to the belt and keeps it from spinning on the drum surface. Check the path of the belt on the bottom of the dryer. That is where the idler pulley is.
Feb 01, 2008 | Dryers
Dryers Logo
102 people viewed this question
Top Dryers Experts
