Question about Carrier 36KCARMS Air Conditioner
Carrier A/C Unit
Unit is approx. 10 yrs old and just stopped working. There is power to the compressor and you can hear it clicking from time to time but it will not start. I read about a Starter Power Pack that is suppose to help start a sluggish compressor. Do you fell that this my problem.
Thanks
John
  • Anonymous Feb 12, 2009
    fan in condensor unit is it suppose to draw air through the condensor or blow air through
  • 236 Answers
Be sure that the starting capacitor is good. If the compressor is stuck up the starter power pack may help but sometimes it fail.
Posted on Sep 24, 2008
Compressor kicks/clicks out after approx 10 sec run time,fan runs normal,not froze up, freezer barely cools,negative frig, happened overnight to 6 yr old unit
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 13, 2011 | Refrigerators
Bottom freezer (10 yrs. old) losing temperature. Only +10 degrees. Refrigerator is +30 degrees. Is it worth fixing the freezer? Does this mean that it is only a matter of time that the top refrigerator...
heatman101
Aug 12, 2011 | Amana Refrigerators
My gibson upright freezer stopped working. it is not frost free. it will run for about 10 secs. and stop. it is 22 yrs old and never had a problem before. has it seen its day or can you help me ? thanks...
You will have to check the over load and starter relay on the compressor.they are not expensive to replace.IF you replace it and nothing changes then you will need to replace the compressor.If you have a power meter you can check the continuity on the compressor contacts.If the compressor needs to be replace it could cost up to three hundred dollars for a unit that old.
Jan 02, 2011 | Freezers
I have a Beverage Air cooler (Model UR30G) where the fans seem to be running, but only warm air comes out...it's about 10 yrs old and is in great looking shape and would love to find a way to fix....any...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Aug 26, 2010 | Carrier Beverage-Air UR30GEFD Beverage...
Frigidaire Air conditioner: fas296n2a2 Compressor
Do you have an amp meter? and volt meter. Are you sure that the compressor is getting power? The click may simply be a relay closing but no power. Check both sided of the relay. You will need to trace the power and make sure that the compressor is getting power. Then check the amps to see how much power it's pulling.
Jun 15, 2010 | Heating & Cooling
I have a ARB2205CS that is 6.5 yrs old. It stopped
No, the relay was what caused the buzz click but i think a bad compressor could be responsible for blowing the relays out. If you had a bad defrost timer that was stuck in defrost thus compressor not running you would not get the buzz click..your comressor would also be cold.
Jun 23, 2009 | Amana ABB1927DE Bottom Freezer...
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
Loud noise when stops ''running''.
the noise your hearing  is a weak spring in the compressor. what happens is the compressor is a motor inside of a steel shell that spins at high rpm's when the unit shuts down and as the compressor starts to stop the weak spring is allowing the compressor motor to bang against the steel shell. around here we actually call these "Bangers". anyway the fix is obviously to replace the compressor. but considering the age of the unit you may want to move it to the garage and buy a new one for the kitchen.
Btw in my experience this does not interfere with normal operation of the unit it is just annoying. If I can be of further assistance please ask thanks Peyton
Mar 06, 2009 | Refrigerators
Carrier hi wall split unit on light flashes 4 times ???
as i am a mechanic in sydney australia, i can honestly say that the chance of you getting help via carrier is very very slim... the reason it is doing that is that it has a legitimate problem unfortunately i have a carrier 42g250h which is flashing 4 times aswell... i have been waiting now 10 working days for carrier to call me to tell me what the problem is... if you can afford to do it, throw the damn thing out and buy a new one, i hate to say it but even an LG will work better than these heaps of ****
Feb 23, 2009 | Carrier 38CKC042 Air Conditioner
Carrier 36KCARMS Air Conditioner Logo
163 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
