Question about Panasonic Microwave Ovens
Microwave not working
Hi, I have a Panasonic microwave.  It has been in storage for a year and the first time I used it, it worked until I stopped it midway because I wanted to change the length of time.  It refuses to work although the clock timer lights are on - the keypad doesn`t respond.
I don`t have the model number as the booklet is still in storage somewhere.  It has been a fantastic microwave and has worked since I bought it 20 years ago and it worked in Australia but refuses to work now in France.
What could be wrong?  My boyfriend checked that the voltage is okay here.  Perhaps the keypad has blown?
As I say, the window shows the colons of the clock timer lit up but nothing works thank you
  • Panasonic Master
  • 9,086 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Otherwise, your controller or keypad may have moisture on it.
Posted on Sep 09, 2008
Microwave starts then quits, turntable doen't turn
At this time we recommend you locate an authorized service center using the below link. www.panasonic.com/repair Welcome to Panasonic Online Repair
Apr 03, 2014 | Panasonic Microwave Ovens
My Panasonic Inverter S333 just suddenly stopped working. I get a "refer to manual" message. Manual has no help to offer. Even the "signal bell" sounds a little off. Up until today, it was working just...
My Panasonic Inverter S333 just suddenly stopped working April 30 after I used it for only two years, no showing in panel. It will run only when I open the door, it is strange.
Apr 19, 2010 | Panasonic NN-T694SF Microwave Oven
My panasonic microwave stops working after 6
If it stops after 7 seconds, it has a problem with the inverter.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Aug 09, 2009 | Panasonic Microwave Ovens
Panasonic Microwave only works for 37 secs no matter what time setting
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Jan 04, 2009 | Microwave Ovens
It stoped
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
Nov 01, 2008 | Panasonic NN-S542 Microwave Oven
Panasonic NN-CS596S Convection Combi Steam Oven
Let us know if the hard reset does not fix it.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If you do indeed have a problem, Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 16, 2008 | Panasonic NN-SN657S Microwave Oven
Hi there, I have a panasonic microwave which is a few years old now. The problem is that it goes for about 20 secs then stops, the display returns to the time and the light in the microwave goes out....
22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 30, 2008 | Microwave Ovens
Microwave runs for a few seconds then stops
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 01, 2008 | Panasonic NN-S962 Microwave Oven
Microwave Ovens Logo
168 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
