Question about SanDisk Sansa e200 MP3 Player
I cant get my computer to recognize my sansa e260
I used to not be able to listen to my music because i needed to synch it, but i fixed that but now it wont recognize my device ever since, please help me. can't recognize device
  • azriel_tino Sep 13, 2008
    my computer wont reconize my i pod
  • Stephie73124 Sep 22, 2008
    My computer won't recognize my Mp3. It's a e200 sansa. I use to be able to load music and everything and now for some reason I can't. When I plug it in to the computer it starts to charge but nothing else happens.....help me please~~
    Problem Solver:
I couldn't get my e260 to work at all. Came to fixya and was able to reformat. Comes on now but can't get computer to recognize it and also will not let me set date and time. (time and battery level do not even show up on bottom of e260 screen). Help!
Posted on Sep 20, 2008
Hi I bought scandisk e260 without cd, when I connect it to the computer, the computer ask me to locate driver. Where can I get driver? thanks
Try connecting it to another computer and see if it will recognize it as sansa or removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansa and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier Make sure USB mode is MSC I use my computer to drag and drop my music from my music folder to the sansa media folder.... Open my computer click on folder what ever folder has your music in it and drag to media folder and drop (click on the (+)where it say's sansa ) easier not to sync
Apr 19, 2009 | SanDisk Sansa e260 MP3 Player
Problem recognizing songs in sansa e260 mp3 player.
From what I'm hearing you don't have a good driver. If you still have the disk use that. If not google it or something. I have a Sansa e260 as well so I would suggest loading the songs on in windows media player rather that windows explorer. If you open Media Player and then go to sync and it does not recognize your device, then you have a bad driver. If not, then start syncing your songs that way.
Hope everything works,
Fixer Guy
Feb 04, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260
You need to synch them to Rhapsody or whatever music service you pulled the songs from. also, make sure your music service subscription supports transfer to portable devices instead of simple transfer to a computer.
Jan 15, 2009 | SanDisk Sansa e260 MP3 Player
E260 - now showing two empty directories (but I still have my music)
try formatting it. to do that, simply scroll down to settings, and in settings hit format. you'll lose everything that was on it tho, if that don't work then try updating. if your unsure how to update go here.
and install the program.
Nov 06, 2008 | SanDisk Sansa e260 MP3 Player
What i would recommend you to do is to uninstall the device and reinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardware then device manager...look for the sansa device..it usually located under portable device..if its not showing there i would recommend you to look for under disk drives and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer....Then follow this link below to download the porting kit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en .Then check the mode of yuor device to make sure it sunder MTP not msc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows media player click on tools, options and click under privacy...clear the history and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..and try to reconnect your device..make sure you have it on the back of your computer...
Should you have any questions..let me know..
P.S.Please rate accordingly...
Thank You
Computerrep
May 03, 2008 | SanDisk Sansa e260 MP3 Player
Sansa cant be detected by computer
i had the same problem with mine and my computer didn't detected it so try plugging it in and out a few time it might work.but if that doesn't work go on settings and change the usb setting
Apr 06, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
For everyone having e260 problems here is the answer. First make sure that you have your usb mode on msc before plugging in to the computer. Then go to folder options and select show hidden folders. You now have access to the music folders and can delete music. You can create a new folder or use the music folder for your music. To prevent future problems go to properties on the hidden folders and unhide them.
Jan 16, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 4 gb mp3 player
You could reinstall the firmware (what makes the sansa work). Its pretty easy to do, no need of downloading/installig, its already all in the sansa. You just need a computer How do I restore the firmware Firstly, place the e260 in restore mode. To do this, follow these steps 1. Push the Hold button on top of the e260 to the right. 2. Hold in the record button 3. Press and release the Menu button 4. The device will now go into Restore Mode. If you have not already connected the USB cable to your PC, it will direct you to do so. 5. The root directory of the device will open up on the PC screen. Now drag and drop the two files Firmware into into the e260 root directory. You will find a copy of the two firmware files zipped up elsewhere on these forums 6. Push the Hold button on the e260 back to the left 7. Unplug the USB cable from the PC. The e260 will now reboot, writing the new firmware images to the correct location. 8. This process will have wiped all your music files. You will now need to re-synch.
Jun 28, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
53 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
