I just replace lamp,but still same problem. a lot of noiseand poor picture
Unscrew the front panel of the tv, and get someone to hold it.
the lower mirror will be covered in dust, so wipe this clean with a duster.
reassemble and you are done
Posted on Sep 25, 2008
How do i fix a non responsive tv set?
Do the ballast first. That should get the picture back. The main board controls everything else.
Oct 08, 2016 | Televison & Video
Replaced lamp on my Mitsubishi 82 in dlp. after 15 minutes pic started to flicker losing color. was advised to also change lamp ballast, did that but still flickers with new lamp. put old lamp back in tv...
When you put the old lamp back in did the picture look OK? If so why did you replace to begin with? Yes, there are some poorly manufactured lamps out there, where did you obtain the replacement? Was it true OEM?
Dec 04, 2014 | Mitsubishi Wd-82837 82" Inch 3d Full Hd...
Why would a Mitsubishi WD-65735 Television turn on and have sound but no picture?
have you pulled the lamp out & checked it. It is possible you have gotten poor quality lamp. It is critical on a mitsubishi to get the proper lamp.
Lamp-Cartridge 915B403001
May 08, 2014 | Televison & Video
Projector says lamp failure and picture has turned Yellow
replace the unit,it sounds like its old,has been used a lot,and needs a complete replacement.
May 06, 2010 | Hitachi EDX-3280 LCD Projector
Poor picture quality. Picture also tends to curve
The curving is caused by bad digital convergencr chips (2) located on large signal board. They need replaced along with blown pico fuses and the convergence resistors. Chips are huge compared to a regular IC. 2" x 1.5" and they will be bolted on fairly large heatsinks. Cloudy picture is most likely the coolant needs replaced in the picture tubes. This needs to be done approximately every 5 years.
May 01, 2010 | Philips Magnavox 9P6034C 60" Rear...
Poor quality picture. specifically the red is brown and can't be adjusted. the tv is about 3 years old.
If the picture is replace the lamp. Lamp only affects brightness if the color is wacked replace the light engine.
Mar 26, 2010 | JVC HD-56FN97 56" Television
I have sound, but no picture
I am finding a lot of people's lamps are going out. This maybe your problem too judging from what I have read above.
There are replacement lamps. They used to be pretty expensive but they are somewhat reasonable now. Below is a site you can order a new lamp this should fix the problem.
But before you order make sure that all the cables in the back of the television are in the right order. Red and White are audio while Yellow is video. A lot of people are unable to distinguish the yellow from the white.
If you have the other cables such as the blue and the black make sure the blue is with blue and black is with black. They are hard to see sometimes in a poorly lit area like behind a TV.
If everything is hooked up correctly.
Your next bet is the lamp replacement. Replacing the lamp its quite easy to do. Just remember to reset the TV lamp timer. Consulting your owners manual should help.
Here is the site for lamp replacements. You also can do your own search for lamp replacement.
Jul 13, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Poor Quality HD Picture
The lamp would make you picture dark.The colorwheel will affect color quality.If brightness is an issue = lamp.If color is the issue = Colorwheel.
Jan 12, 2009 | Samsung HL-S4666W Television
Wavy picture and now has no picture. lamp was replaced.
this set is notorious for defective capacitors. there are many that need to be replaced. I suggest dealing with an authorized mitsubishi servcer for this one.
Jan 11, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Picture quality of my LG Projection TV is very poor
Bad Light engine call UED for price on rebuilt one if they have it!1-800-648-6657
Dec 19, 2008 | LG RU-52SZ51D 52" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
