Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
Mistubishi WS-55315 Lens replacements...
Where is a good place to find replcement Diffraction and/or Fresnel lens replacements for a Misubishi TV ? Had a "DRUNK" fall into mine !!! OUCH !!!
He says he will pay for the replacemnets, but I can't find anything locally here in West. Kentucky. Mitsubishi has been NO help !. And the local yokels here are WAY out in left field with their pricing...
Any help would be Greatly Appreciated...
Thanks in Advance.
  • 927 Answers
SOURCE: Mitsubishi WS-55315 audio no picture
Good Day;
More than likely your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV.
If after the fluid has been removed and TV still does not work, call an Authorized Service Center to come out and repair TV after giving you an Written Estimate. The boards are not available.
Always try resetting the TV by unplugging it for one minute then plug back into A/C outlet and ALWAYS UNPLUG TV BEFORE ATTEMPTING ANY REPAIR ON THE TV.
Good Luck, big IRISH.
Posted on Sep 19, 2008
Benimur
  • 6966 Answers
SOURCE: Mitsubishi WS-55315 no video present
Appreciate the direct "Ask Me".
You description of "...no video but with audio..." could indicate a number of possibilities:
  • power supply section;
  • tuner
  • video amplifier/selector;
  • vertical section;
  • horizontal section .
Other ideas are:
  • Since it has still sound, then the power supply is a least likely possibility;
  • Since it has still sound, then the tuner is a secondary suspect;
  • Since the menu shows, then the vertical and horizontal would be highly unlikely.
  • which eaves us the video amplifier or electronic/soft selector as the most likely culprit.
Further diagnosis would of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 27, 2008
SOURCE: Cleaning the bulbs and mirror on my Mitsubishi 55" WS-55313 TV.
You should re-consider having a tech do that for you. The access is by removing the screen assmbly which are somewhat fragile. If you want to give it a try, pull the speaker grill off, it comes off just from pulling it, there should be five screws across the bottom of the screen assy, remove those, there is also an access door on the front of the set with four screws, that has to be removed to unplug the cable that goes to the screen sensors. The screen assy has to be lifted straight up an inch or two and then you can pull it forward away from the set.
As far as cleaning the mirror and lenses, you can't get to the face of the tubes so it's the top of the lenses that you clean, just use a soft lint free cloth (cloth baby diaper) and wipe the dust off the lenses, you can slightly dampen the cloth with water if necessary, same type of cloth on the mirror and you can use a glass cleaner on it just don't press too hard on the mirror.
Posted on Feb 05, 2009
SOURCE: HD UPGRADE MITSUBISHI WS-55315
Check your manual, I have the same set and you need a
WD 5000 HD upgrade panel, I believe.
This TV is HD upgradeable, it is NOT HD ready, like you have
been told by other responder......
Posted on Feb 25, 2009
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi WS-65313 Screen burn-in
IF you have the area on either side of the picture used in the 4x3 burned---it is now burnt into the phosphor of all three picture tubes this set uses.
The real problem here is most of these sets the default setting for contrast or "picture" (same thing) is 100% and this is what burns fixed images into the tubes.
Pretty stupid, but that is how they are made--the black background in later models was replaced with a light gray one to try to prevent this.
If you do not have a warranty live with it--the cost of the three tubes would be about 900 dollars plus labor to replace them and adjust the set.
It takes less than 100 hours of use with the 4x3 up to cause this kind of problem, just like putting a fixed image on any projection set with full contrast and brightness set full--the damage is permanent.
I have replaced tubes in sets like this and when you get the tube out you can see the BURN in the phosphor.
I am sorry to give you bad news but based on your description this is what you have.
If this helped you rate this solution as I do this here for free.
SD TECH
Posted on Dec 13, 2009
Testimonial: "thanks for the feedback!"
Find generic dlp lenticular screen and fresnel screen
I would find out the make of the lens, probably cannon. The Fresnel and Lenticular screens are nothing to do with the size of the picture, the lens does that bit.
Oct 01, 2017 | Televison & Video
Need a screen for my 55in
I believe Mitsubishi would be the best source for the screen.
The Diamond Shield is part number 760D639020: $77.90.
But make sure the fresnel lens and everything else is in good shape first.
Sep 11, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi hdtv 1080 ws-a65 screen broke need replacement
there are 2 functionality screens and 1 screen protector (on some)
front screen = lenticular
back screen = fresnel
very front screen = screen protector (you can replace w plexiglass)
the fresnel and lenticular are very specific.. contact your local repair center for a new one. you can cut them from old screens but have to do just right (fresnel is a lens type - pic will be distorted if off center)
maybe find a old junker tv to pull screens from because new ones are about $100 a piece
Jun 03, 2010 | Mitsubishi WS-65311 65" Rear Projection...
Ws-55315, screen turned to fuzz
If it was the lamp there should be nothing. press the menu button if the menu does not come up the issue is with the tv. If the menu does come up try a second source a dvd player or game system. If the issue is only with the original source than the original source needs to be replaced.
May 05, 2010 | Mitsubishi WS-55315 55" Rear Projection...
My 17-40 canon lens on a 5d body. i have ISO50 Fstop22 shutter 30sec and i a would think i can lock focus on centre or foreground and gert a sharp result but its not the case. My photos are a bit sharp...
the aperture (f/ ) is closed too much and what happens is 'diffraction'
read more about diffraction here:
http://www.luminous-landscape.com/tutorials/understanding-series/u-diffraction.shtml
good day
yitzy
Nov 18, 2008 | Canon Cameras
Good Day;
Sep 14, 2008 | Mitsubishi WS-55315 55" Rear Projection...
65 inch Mitsubishi replacement screen? (WS-65311)
I think I can help you out if you still need that screen, I have a new screen, both fresnel and lenticular lens in a frame for a ws-65411. contact me at jgrisz@comcast.net
May 07, 2008 | Mitsubishi WS-65311 65" Rear Projection...
Need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Mar 11, 2008 | Mitsubishi WD-65731 65" HDTV
Pink horizontal line when the tv is powered on.
1. White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0357" use the audio button to select "video chroma" adjustments, use the video button to select item "40 - AGIW", use the adjust button to change the setting to 0, then press the enter button to store the change.
Jun 13, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
