Question about Mitsubishi VS-50603 50" Rear Projection Television
TV Stuck in TV Guide Plus+ Installation Mode
Out of the blue the TV decided it wanted this mode and would not stop.
The message at the bottom of the screen reads:
Installing Guide Plus+ data now
Turn TV off during installation
CANCEL to abort
It stays at one of the kids channel for a while, starts running though the channels at about 3-5 second intervals, then turns itself off. I don't have the original remote control, therefore I have no CANCEL button to hit. I unplugged the TV for a coule hours, but that didn't change the situation. Mitsubishi VS-50603 - Same problem. Stuck on TV Guide Plus Installation, cannot cancel.
No remote
HELP!!
  • Anonymous Mar 19, 2009
    HELP!!! STUCK IN THE TV GUIDE PLUS+ INSTALLATION MODE.
5 Suggested Answers
SOURCE: autoprograming
get the original remote.....i had to. it costs $95 thru best buy(special order it takes 5 days)
Posted on Oct 15, 2007
SOURCE: TV Stuck in TV Guide Plus+ Installation Mode
None of the above worked for me even with the original remote. That installation message will keep repeating if the cable line is not directly connected to the tv (the message and tv will flicker with static which means it's flipping through each channel about 120). I disconnected the line from the comcast box and put it in the tv and let it flip through all the channels (it had picture this time and no static once the line was directly in the tv). I then turned the tv off for 2 hours and the installization was done.
Posted on Jun 03, 2008
  • 346 Answers
SOURCE: Sound has gone out on Mitsubishi VS-50603
connect headphone-. did you hear sound?
Posted on Jan 04, 2009
MNfisherman
  • 11896 Answers
SOURCE: Mitsubishi VS-50603 Wont Turn on
The power supply will need to be changed. The capacitors inside the power supply are not sending the correct amount of power to tv and will need to be changed.
Posted on May 13, 2009
How to get the buttons to work agin on front of tv.
You may have accidentally set it to the demo mode.
The user's guide might help:
Mitsubishi VS 45609 VS 50609 User Guide
Sep 06, 2014 | Mitsubishi VS-50609 50" Rear Projection...
Miele G 694 SC Plus Dishwashers : Cannot exit Test Program
Ok,if you unplug it,it should reset it.
Mar 09, 2014 | Dishwashers
I have a Honeywell Chromtherm IV Plus. I put the
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Jan 05, 2010 | Honeywell Programmable Thermostat Heater
Xp
Hi There,
I just experienced the same problem you did concerning the partmgr.sys blue screen error. I am installing Windows XP Pro SP2 on a pretty old Dell Latitude LS (upgrading it from Win 2000). The XP installation disk gives me the option to format in NTFS, FAT, and both formats in a "quick" mode. I usually do not recommend using the quick mode, however, after trying both NTFS and FAT and receiving the blue screen, I decided to try NTFS (quick). That has allowed me to actually get further into the installation, so you may want to try that.
May 27, 2009 | Microsoft Windows XP Professional
buy a good universal remote and it will have the correct button, that's what I did, I got the Radio Shack 8-in-1 remote and programmed it and it got rid of it.
Dec 03, 2007 | Mitsubishi CS-36609 36" TV
Dwt 1905 tv stuck in game mode
Comcast universal remote code for dwt 1905 is 0171, just tried it, it works
Nov 26, 2007 | Durabrand DWT1905 TV
Autoprograming
Sep 15, 2007 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi CS-32509 TV
Unplug the TV for 4 hours or more. This is called a 'Hard Reset'. Then plug it back in, turn it on and let the TV do it's thing. It will set itself up. Just follow the TV setup prompts. Guide Plus is a feature on the TV. Much like a TV guide showing all channels, shows, description of shows, times, etc..
Jun 30, 2007 | Mitsubishi CS-32509 TV
Stuck in progressive scan mode
You need to be sure to remove the discs from the disc changer and close the disc changer. Make sure that your TV is on the Blue Screen and it should say " Progressive Scan Mode" Press and hold the stop button on the unit....not the remote for 5 seconds or more and it should reset. However, if your TV is a Progressive Scan compatible TV, you may need to refer to the user guide for the TV as well....Many newer TVs Use a Progressive Scan Setup, but this solution should still work for you. Make sure all discs are removed FIRST!!!
Aug 29, 2006 | NexxTech ESDVD100 System
Televison & Video Logo
63 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
