Question about LG 22" Widescreen Flat Panel LCD Monitor
LG Flatron W2242S OSD controls dont work
Hi
I cant seem to work out how to use the OSD controls on the monitor of the LG Flatron W2242S. The screen has gone really dark and whenever i try to use the f-engine button on the front panel to adjust it, it keeps saying 'processing auto image adjustment' but it doesnt do anything. What am I doing wrong?
5 Suggested Answers
  • 5 Answers
SOURCE: Resolution 1680 x 1050 is not adjustable
Make sure your video card is capable of supporting that resolution and also make sure your video card drivers are up to date.
Posted on Apr 08, 2009
rj_8017
  • 22 Answers
SOURCE: Message: OSD LOCKED'' when i press a button on my LG Flatron L1720
change all pressing keys..then press menu key 15 seconds for unlocked.
Posted on Jan 23, 2010
SOURCE: Dark, horizontal lines after text and dark images.
This implies that your monitor had gone bad. you need to take it to a computer repair shop.
Posted on Apr 10, 2010
SOURCE: Pl. solve my problem "PROCESSING AUTO IMAGE
I have the identical problem
Posted on Oct 18, 2010
  • 452 Answers
SOURCE: processing auto image adjust appeares more times
open the rear cover there is a trimmer, with a screw drive adjust it by turning right or left; the message will not appears again
Posted on Oct 27, 2010
Flatron W1942TQ monitor has "OSD Locked" message
Press and hold menu button for a few seconds, pressing and holding, acts as a toggle. So if OSD LOCKED still appears, pressing again UNLOCKS.
Mar 25, 2011 | LG Flatron L1951S 19" LCD Flat Panel...
Control locked how can i unlock it?
To unlock the On Screen Display (OSD) lock, hold down the menu button for 20 seconds until OSD unlocked shows on the screen.
Please rate my answer if this helps,
Chris
Mar 03, 2011 | LG Flatron F700B 17" CRT Monitor
MY LG FLATRON L1951S, THE OSD IS LOCKED. HOW CAN I UNLOCK IT.
On screen display is locked. Fix it by:
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Mar 14, 2010 | LG Flatron L1951S 19" LCD Flat Panel...
Jan 21, 2010 | LG 22" FLATRON LCD Monitor
Unable to drive LG W22432S monitors in WindowsXP
Hi there.
Go to the control panel, select display, click on the settings tab and set the display to 1024 x 768 pixels, that should sort the problem out.
Post back if you need more help.
Good luck and thanks for using FixYa!!
May 14, 2009 | Computers & Internet
Apr 07, 2009 | LG 22" Widescreen Flat Panel LCD Monitor
FLATRON L192WS LG
hold de book buton 5 or 6 sek
Aug 10, 2008 | LG Flatron L1750S 17" LCD Monitor
OSD problem
Should be as simple as holding the Menu button for several seconds. Give it a try. You should get the message OSD unlocked and then the menu button will function as expected.
Jul 15, 2008 | LG Flatron L1951S 19" LCD Flat Panel...
LG 22" Widescreen Flat Panel LCD Monitor Logo
1,276 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
