Question about Sharp AL-1551CS Printer
Flashing error message "L"
I moved my sharp al-1551cs to another location and now i have a flashing error message - "L" - I moved the clear plastic disk on the left side of the machine but no matter which position that disk is in - the "L" still flashes.
  • Anonymous Jan 02, 2009
    L keeps Flashing
    Wont print
    Wont do anything
jon_than21
  • 30 Answers
SOURCE: My sharp AL-1217 greets me with a flashing "L1" error
try to clean the scanner glass, it has a white stripe at the home position of the scanner optics, clean it well.
Posted on Jul 28, 2008
  • 37 Answers
SOURCE: Error message E 7
Try these steps to cancel the error, press the buttons continously
STEP1. Press CLEAR key then EXPOSURE key then CLEAR key then EXPOSURE key
STEP2. Then you are inside the simulation if the display turns OFF if not, do again step 1 until the display turns off.
STEP3.press 14 then press print button
Posted on Mar 01, 2009
  • 22 Answers
SOURCE: my al-1551cs sharp printer displays L1 and nothing
There is a crystal lock under the scanner and on the top of the exit tray. just rotate the lock, makes sure that the front of the lock is on the direction of the scanner(to the right).
Hope it helps...
Posted on Aug 05, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: My Sharp AL-1551CS copier is flashing L 3. What
Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Good Luck and thank you for using Fixya.
Posted on Mar 15, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: Sharp AL 1551CS copier flashing
To reset the H4 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Jan 31, 2011
Why is my Sharp AL-1551CS displaying error h4?
replace the fuser, do not continue to reset or the machine can catch on fire try this site a fuser unit as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 13, 2015 | Sharp AL-1551CS Printer
Mar 15, 2010 | Sharp AL-1551CS Copier
I have a Sharp AL-1551CS that when turned on shows an error message and will not work. The error code referenced in the maunual says to remove the shipping screw. I have had this unit several years. what...
instead of a screw, some models have a dial to lock the scanner for moving machine. look above where the paper exits machine twords the left side under the scanner assembly for a dial switch and turn it.
Nov 11, 2009 | Sharp AL-1551CS Copier
Sharp AL 1551cs reading L
I also have an AL-1551CS copier...normally the "L" has something to do with the scanner lock device underneath the left side of the top part (ie; the scanner) It's clear colored and round with protrusion to turn it from locked to unlocked...this is for moving the copier so the scanner (lamp and mirror assm) won't be disturbed. Use a flashlight or such to inspect the position of said device (ie; locked or unlocked) insure it is unlocked.....power back on and tell me if there is a number following the "L" Tim
Jul 03, 2009 | Sharp Office Equipment & Supplies
Error code L1
Next exit paper have a key block scanner. Put knob in key out  for work well. Power off and power on. Good luck.
Jan 17, 2009 | Sharp AL-1551CS Copier
Flashing "L" msg
Indicates the scan head locking switch is locked. The switch is under the original table. If you have the Operations Manual, there is an illustration on page 9.
Sep 08, 2008 | Sharp AL-1551CS Printer
H 4 error
If the Reset does not work, then you have a fuser error and your machine will need service.
H4 is a fuser heating error code.
Meaning the machine is not warming up because of a bad lamp, thermal fuse, thermostat, and or thermister.
Hope this helps.
Good luck.
Mac
Feb 10, 2008 | Sharp AL-1551CS Printer
H4 error code
H4 is a Fuser Unit heating problem.
This reset is for another model sharp, see if it will work for you.
Press "Clear", "Auto Exposuer", "Clear", "Auto Exposure", the display will go dead... then press "14" (Like your going to make 14 copies), then press "Start".
Hope this works.
Good luck,
Mac
Al-1551cs / L!
Sharp Error Codes
Sharp ram clear (most models with LCD displays)
Press function 9 * 8 # 7 then # or * until display reads memory clear, then press start. Note the other maintenance mode options displayed on the screen when pressing # or *.
Sharp UX-170 maintenance mode: Turn power on, set the line selector at "T" (tone), turn the program switch ON, then press 9 * 8 # 7. Select the next entry from this list: 01 all black copy, 02 ROM/RAM check, 03 auto feeder mode, 04 aging mode, 05 panel check mode, 06 G3 transmission, 07 check pattern, 08 product check (includes diags, 06, 03, 09), 09 signal send mode, 10 memory clear, 11 led array on mode (lamp), 12 product program sw mode, 13 telephone number list printing mode, * soft switch mode, # transmission level. This same procedure works on similar, older models that do not have an LCD display.
Sharp UX-2100 often has power supply problems which cause the unit to lock up.
UX-3200/FO-3250: FO32TD toner/developer costs less than UX30TD and will work in the UX model if 2 fins are broken off so that the unit can be installed in the UX model. Similar duplicity exists with many Sharp laser supplies.
Sharp FO-4800: fuzzy print often results from a bad Motor PWB (polygon mirror) #RMOTN0020GCZZ located in the optical unit.
Nov 06, 2007 | Sharp AL-1551CS Printer
Sharp AL-1551CS Printer Logo
67 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
