Question about Dryers
Dryer starts when you press start button but stops as soon as you take finger of start button.Ive replaced switch but no different
  • 550 Answers
The switch is not likely at fault.
the switch activates a relay that is supposed to latch in place until the door switch or timer de-energize it, to supply the very large currents to heater and motor.
The relay has failed, it looks something like this,dryer starts when you press - 1d9c9e9.jpg though may not be transperent, trace the wires from the start button, the relay will be the first 'thing' in the circuit. Generic relays will be available to fit, one fits many dryers, at the local parts store.
Posted on Sep 08, 2008
When I push the start button the dryer starts but has soon as I take my finger off the button the dryer stops. why is that happening?
sounds like a bad push start button either the switch or the knob is defective, see pics
May 05, 2015 | Dryers
My kenmore gas dryer (#73952) will start when the button is pressed, but as soon as it is released it stops. Can you help?
check the door safety switch, you can bypass it by jumping the 2 wires together, if it runs then just replace the door switch
Aug 23, 2011 | Kenmore 73952 Gas Dryer
Dryer will start when start button is pushed, but as soon as you stop pressing the button, the dryer stops
I would open up the control panel unplug the unit, disconnect the wires to the push-to-start-switch and use a paperclip to attach these two connecters. If everything works you know it is the switch that is bad.
Sep 18, 2010 | Kenmore 67841 Electric Dryer
My Kenmore model #110.68944891 starts when I press the start button, but stops immediately when I release the start button.
Open the control console to access the start switch. If you have 3 wires on the start switch,replace the start switch.
Nov 07, 2009 | Kenmore Dryers
Estate dryer wont engage
Check the following--
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Jun 01, 2009 | Whirlpool LER5636P Electric Dryer
Dryer starts but goes off as soon as I take my finger off the start button
The starting capacitor has low storage of current some are open or shorted , need to replace the starting capacitor.
Dec 22, 2007 | Kenmore 63942 Dryer
Hoover tumble dryer
I think you may have a bad relay on the motor, where power is re-applied after the push start is released
Oct 11, 2007 | Hoover HDC6 Electric Dryer
Dryers Logo
85 people viewed this question
Top Dryers Experts
