Question about GE Refrigerators
GE refrigerator freezes up
Have a GE refrigerator, side x side that is freezing up and than it quits cooling, had a service tech out and they changed the main control board as that has the defrost relay on it. he said that the defrost heater was ok, but now it froze up again, lots of frost on the back panal in the freezer compartment! so what needs to be checked or what is the problem? thanks for your help!
    Sergeant:
  • 399 Answers
Please check the ventilations as somewhere it is leaking air or somewhere the air is blocked from coming out.
for any further queries feel free to ask.
thanks
Posted on Sep 18, 2008
    Genius:
  • 1,847 Answers
There is issue with proper air circulation inside the fridge. check the fan are working fine.
Posted on Sep 08, 2008
  • Legin Varghese
    Legin Varghese Sep 08, 2008
    The cold air for the refrigerator side comes from the freezer by way of a vent near the top. The air is blown from the freezer by the EVAPORATOR FAN .check it.
    If the evaporator coils are iced up due to auto defrost failure the fan can't pull the cold air across the coils. Check for ice on and or behind the back wall where the coils are. Probably easier to see from bottom. You may have to take the back panel off to see.
    So your all iced up. CHECK DEFROST TIMER--- CHECK DEFROST HEATER---CHECK DEFROST THERMOSTAT
    Link to testing components:Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Side by side GE TFT28PFBBWW freezer ok, refrigerator side cools interminently, most of the times does not cool at all
The problem is defrost.
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 10, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GSS22IBMA GE side buy side. The fridge side works fine but the freezer will not freeze. Also it is hot around the the door frame of the freezer sometime quite hot.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 08, 2011 | GE Refrigerators
Model GSS25SGMCBS coil freezes.heater checkedout ok service man changed the circuit board for $312.After 3 days, same problem again. Freeze temp ok but refrigirator sectio quit working after coil freezes....
Control board is new, heaters ok, Check defrost thermostat and thermisters located on evaporator.
PC board not getting information to defrost properly.See site below
Also check the fill tube at ice maker . Iv'e seen these get loose and fill evaporator with water causing ice block
good luck
GE Refrigerator Repair Guide
Aug 16, 2011 | GE GSS25SGMBS Side by Side Refrigerator
GE GSH22KGMB side by side refrigerator freezes up and doesn't make ice and forms ice on the back wall of freezer and veggie drawer freezes.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE profile side by side is freezing fresh food and not cooling items on top 2 shelves
ge profile side by side is freezing fresh food and not cooling items on the top 2 shelves
May 02, 2010 | GE Profile PSW26P Stainless Steel Side by...
Our GE sss25kfmdww "freezes up" and then stops refrigerating
Most times on that model the defrost heater and defrost thermostat will need to be replaced. The timer is built into the mother board and for some reason they are not the most likely reason. The defrost heater has a glass tube around the element and easy to spot if burned out. If you replace one part you should replace both. Now is a good time for you to do a little reading about your model. I will give you a link to the service manual and a page with a tech sheet, Sea Breeze
Dec 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Coils freezing
coil freezing is a sign of under charged system. Contact aized service center for recharging of refrigerant.
I hope this helps.
Jul 21, 2009 | GE GSS20IEP Side by Side Refrigerator
Freezes up in the back of the freezer..won't hold cooling
you have defrost problem 1 timer may be 2 heater 3 defrost thermostart call service
Apr 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Everything freezing in vegetable and Custom Cool compartment
you have a temp setting above those shelves left side has a porkshop and left side has a carrot i belive set to to the left side to vegies and see if it helps if still all freezes the you have a broken damper on top that letts air in when it does not needed
Sep 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
