Question about HP DeskJet 920c InkJet Printer
Communitcate/test sheet I just set up my HP dskjet 920c printer, put in the usb cable and the power, and put in the ink catridges. i also loaded it with some paper. However, when i try to print something it tells me that the computer cannot communicate with the printer and the printer wont let me do a test sheet. I also made sure both cables were secure.
You didn't mention installing the 920c on your computer. You should have received an HP Deskjet 920c series printer software CD which installs the printer on your computer. You may need to check the HP web site to see if your computer is equipped with the appropriate driver. The 920c is an older HP printer. One of my printers is a 920c and I had no problem installing it a computer with Windows XP.
Posted on Oct 21, 2008
My hpf44880 printer prints out blank sheets of paper what do I need to do to get it to print with ink on the paper?
please follow these steps:
1.please print a test page from printer(hold down power and cancel(red X)buttons for 3 seconds together and release both of them..it will print a test page
2.if it is blank :please take out the cartridges.
clean the metallic contacts with lint free cloth
clean the ink cartridge slots with a cutip
disconnect usb cable
unplug the power cable from the back keeping cartridges out
hold down power key for 30 seconds
reconnect power cable
reinstall the cartridges
3.print a test page again from printer if printer is quiet
4.if the test page is still blank..u need another set of cartridges
5.if test page isn't blank and u print blank pages from computer,do the following:
6.if printer s/w is already installed..please go to devices and printers(printers and faxes in win xp)
7.please click on add a printer
8.select driver manufacturer as HP,and driver as deskjet 990c(this is the generic driver for all HP printers)
9.follow the onscreen instructions,and finish installation
10.try printing with this driver
Jan 24, 2011 | HP F4480 All-In-One Printer
The ink icon light is blinking
  1. Reset your printer if you are having communication problems with the computer. To do so, press the "Power" button to turn off the printer. Wait a few seconds and then power it back on.
  2. Power off the printer again if you are still running into problems and disconnect the power cable from the AC power. Wait a few seconds and reconnect the power cable. Power on the printer. This simple procedure resets the printer back to the default factory settings. Move to the next step if the reset does not work.
  3. Disconnect the USB cable from the printer. Insert the printer software installation CD into the CD-ROM drive on your computer and wait for it to automatically launch. Click the Windows "Start" button if it does not launch and click "My Computer. Right-click the CD-ROM drive with the disk and click "Autoplay to run the CD.
  4. Select "Setup" on the CD and select "Remove HP DeskJet 932c. The printer software and drivers are removed from your computer.
  5. Reconnect the USB cable to the printer. The installation disc automatically recognizes it and begins reinstalling the software and drivers.
  6. Print a test sheet to verify that the printer is now working. You can print a test sheet using a word processing application (e.g. Microsoft Word) or using the Internet.
May 13, 2010 | HP DeskJet 932c InkJet Printer
I have an HP PHOTOSMART C4680!On the screen it apears "Cartrigde problem" and the button is blinking!What can I do to fix the problem?
1.Remove the ink catridge
2.Replace properly
3.try to print
4.if even same problem will be occured then replace with new catridge.
Note: Hp printer come along with a software cd.it has the driver for printer,troubleshooting and maintenence software.in the trouble shooting guide will help to removes and replaces the catridge properly.Also a Quick start guide(A printed sheet) also can help.
5. if Even the problem not solved then unsqurew the printer squrews carefully ,
6.look at the mechanisim if any damaged
7.look any Data cable or Power cable may be damaged (Cables are looking like a white color mica ribbon)
Thank u sir ... All The Best....
Apr 22, 2010 | Office Equipment & Supplies
HP 920c Deskjet feeds blank paper constantly. Will not print. Just shoots paper out.
deskjet 920c will not print, green light flashes and blank paper comes out. Printer will print test page perfectly.
Nov 07, 2009 | HP DeskJet 920c InkJet Printer
Ink system failure
Verify that the unit is switched on.
Remove the power cable from the back of the machine.
Wait for 30 seconds.
Press and hold the POWER button on the front panel.
Reinsert the power cable in the backside of the unit.
Print a test page. If the problem persists, replace the cartridge.
Use always genuine HP Original Catridges as recommended by HP
Using oringial catridges will give long life to this HP Printers.
If the problem persists, Please switch of the desktop / laptop along with the printer.
Reboot the machine and re-install the printer driver in the machine.
If the printer is under warranty, HP Printer Service engineer will guide you over phone.
Jul 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
Alignment/selftest sheets print whenever I turn on the printer.
its up to you if you want to make self test..but you can cancelled it if you dont want to make self test..
Mar 07, 2009 | HP DeskJet 920c InkJet Printer
Hp 920c
is printer driver installes if so go into control panel and check that the 920c is selected as active printer...
Sep 25, 2008 | HP DeskJet 920c InkJet Printer
LOW INK
Are you using remanufactured cartridges? If so, i would strongly recommend you only use factory HP ones. It is possible your logic board has gone bad. I've seen this happen to these older model inkjets.
Apr 07, 2007 | HP DeskJet 920c InkJet Printer
HP DeskJet 920c InkJet Printer Logo
121 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
