Question about Toshiba 32A50 32" TV
I have a thin line in my tv and i dont know what ic no.to replace?
  • Toshiba Master
  • 17,130 Answers
The fault is a failure of the deflection circuit and since you have not specified whether it is a vertical or an horizontal line the section failed will be related to the position of the line.
If horzontal the vertical IC or the section related is faulty and if Vertical the horizontal section., Now this can be the deflection IC, teh deflection coils or even discrete components like capacitors or resisitors in this section which will require a signal trace with a voltage test before the absence of the sync pulses are confirmed and the section identified.
I request not to change the IC unless it is proved but you can solder the vertical IC or the section concerned -- if there is dry soldering.
Posted on Aug 25, 2011
SOURCE:
Our tv, a Panasonic # CT-36D11E/CT-36D11 only shows a horizontal thin line across the screen. The sound is fine - any ideas? Is it time to replace or could it be repaired cheaply?
Resolder the vertical IC and replace those capacitors near and next to your vertical IC. If the horizontal line still appears, you may have to replace the IC. Thanks for asking and be caredful!
Jun 18, 2010 | Panasonic CT-36D11 36" TV
Picture go into a thin line.
You have a thin horizontal line in the center of the TV. You, in this case have vertical IC that has bad grounds. Resolder the vertical IC pins and check the capacitors in the immediate area and replace these caps as necessary. If you still have a horizontal line, you will have to replace the vertical IC. Find a TV tech or someone with electronic experience to do this for you. Should be reasonable to fix. Thanks for asking and Good Luck!
May 30, 2010 | Sanyo AVM-3659S 36" TV
My sanyo ds31590 31 has a black picture with a thin white line in
check the voltage at vertical ic must get 24volt dc then replace the IC that all
Jun 30, 2009 | Sanyo DS31590 31" TV
Set only has a thin line across,but sound is still there Is this something that I can repair myself ? I dont know much... 1 Solution
This is a problem with the vertical circuit. It can be as simple as poor solder connections at the vertical IC or a defective IC. Look for a small flat IC attached to a heatsink with about 11 pins. It may be marked LA7837 or something similar. Try resoldering the pins first. If that does not resolve the problem, replace the IC. Please note that there are potentially dangerous high voltages present inside the set even when unplugged.
Keep us posted as there may be other components that need to be replaced. If so, the symptoms will change. Report them here and we'll provide additional details.
Thanks,
Dan
Feb 23, 2009 | Mitsubishi CS-35405 TV
A bright thin white line, side to side.
You need to replace the vertical IC and all the dry capacitors near to him.Good luck
Jul 06, 2008 | Sylvania 202SL8 TV
Screen displaying a thin white very bright horizontal line.... plz help
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Darshan
Jul 05, 2008 | LG Studioworks 552V 15" CRT Monitor
JVC Interiart 32" Digital TV. No longer turns on. Has a thin horizontal line across screen when TV is on. No picture.
The thin line indicates that there is no vertical. This is usually controlled by a single IC (vertical IC). Look for a small flat IC attached to a heat sink with 9-14 pins. It may be marked LA7837 or something similar. Try resoldering the pins first. If that fails to resolve the problem, replace the IC with a new one.
Keep us posted.
Dan
May 09, 2008 | Televison & Video
My mitsubishi CS-35405
This condition can be easily fix by replacing and IC that is the vertical amplifier.
The number is something like LA7835 or LA7836, this IC is mounted on a heatsink.
Do a search in google for it.
Mar 01, 2008 | Mitsubishi CS-35405 TV
Thin Horizontal line through tv blank screen.
Replaced vertical IC ( la78041 ??>.. Or La78040 ). Look for born resistor beside IC. Replaced capacitor 100uf 35V too!!! Good luck !!
Nov 08, 2007 | Insignia NS- 27" TV27 TV
I have a thin bright white line,horizontal,no picture
i have panasonic sophia tv 29" i have white horizontal line on middle of screen i know i have to solder ic but where is the ic located on main circuit board. thankx
Aug 22, 2006 | Jensen TS2750J TV
Toshiba 32A50 32" TV Logo
112 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
