Question about Goodman GMS90703BXA Heater
PARTS I NEED A CIRCUIT BOARD FOR A GMP100-4 MAYBE THIS IS THE PART # IAM NOT SURE # 9701844820601848206 CAN YOU TELL ME IF HAVE IT IN SCTOCK AND HOW MUCH IT COST,THANK YOU. chibcha_008@yahoo.com
    Problem Solver:
  • 22 Answers
How old is the Furnace?
Posted on Oct 11, 2008
Washing Machine - Bowl is full of water, won't progress to spin cycle. PU error code displayed.
When all else fails its usually the computer. There's a circuit board that goes bad (mine did after 20+ yrs) and cost around $60. You can usu. see a bulging resistor, capacitor, etc and smells 'burnt' to tell. If you're getting an error code that made be computer declaring itself dead! Sorry. Those beasts are SUCH a pain some times!
Link is just for pics of circuit boards and some info. DON"T go by insane price seen! Not true. WASHING MACHINE CIRCUIT BOARDS
Maybe try Repair Clinic for a video. They MAY have a decent price on your board. Sears has its own site. LG Washing Machine Circuit Board Timer Parts
Jan 11, 2015 | Washing Machines
Hi I want to save our Daewoo DWF 450 full automatic washing machine. It was broken. I opened,removed and checked the control board then a I found out one of the parts or maybe 3 parts were burned. The...
hello, this is a guess but it sound like resistors or diodes you would need a circuit diagram to tell you the value of the resistor and diodes it would be better to buy a new control board hope it helps
regards
shaun
Mar 13, 2011 | Washing Machines
My daughter broke one of my usb ports in the front of my asus cm1630 how do i get replacment parts can i buy a usb 2 or do i have to buy the whole setup that contains the usb ports and media card slots
USB 2.0 refers to the technology, not the connector itself.
http://en.wikipedia.org/wiki/USB
Obtain another USB connector, and solder it in?
Sure, maybe. Depends on your de-soldering/soldering skills, and if the circuit board is damaged.
> Physically damaged in that the board is cracked, and circuit traces are ripped loose, (Repairable with a jumper wire, or wires), AND/OR the USB port was fried out (Short Circuit), and it fried out the entire circuit board.
Obtain another circuit board? This would be the way to go IMHO, but try to find one.
You may have luck on Ebay looking at Desktop Computers > Computers for Parts, or the actual circuit board itself, dunno.
1) http://www.mouser.com/Search/Refine.aspx?Keyword=USB+female+connector
2) http://www.radioshack.com/product/index.jsp?productId=2062744
3) http://www.mgchemicals.com/downloads/appguide/appguide0805.pdf
(PDF file. Takes approximately 20 seconds to download. {Time it takes also until you see the first page)
For questions post in a Comment.
Regards,
joecoolvette
Dec 12, 2010 | ASUS Computers & Internet
My coils are freezing up making the refrig side not cool because the air cant flow threw the coils. i had a tech come out and tell me that the electronic control board part # 6 to model ED2FHAXSL03 was...
Has frost covered the fan blades so they can not turn.
Maybe you need to pull the plug and give it a good defrosting .
Then once all signs of frost and water have been mopped up
plug it back in and be sure you STILL have a problem.
Be sure the fan runs to blow air over the coils .
If it frosts up again ..trouble shoot the defroster system.
But new board may have fixed this if problem was on the old board .
Are the seals around the door damaged allowing moist air into the freezer secton?
Nov 26, 2010 | Whirlpool ED2FHSS Side by Side...
Pitch slider
usually, when you buy the pitch fader itself, then it comes with the circuit board. Ring up panasonic or a distributor and maybe they stock them, but im not sure why you need just a circuit board...and if u bought a pitch and it came without one, then just give a ring around...at least someone will stock it
Jun 01, 2009 | Technics SL-1210 Turntable
Microwave does not turn on
There are about as many causes of this as there are parts in the set. To Start with, Check that the microwave is not plugged into a GFCI wall socket.. If it is, make sure the socket has not been tripped. If it has reset it. Make sure the set is unplugged for the rest of this. Follow the power cord in the unit to find the primary fuse. You'll need to test the fuse with a Continuity tester since this fuse usually a ceramic fuse and you can't just tell by looking at it. If that's good, the problem will most likely be a mini fuse on the controller board or a fuselink that's in side the small transformer on the controller board. If lightning is suspect, you can pull the board out and look at the circuit side to check to burned traces. Replace any MOVs that may be on the board otherwise any corrective work is just wasted. Back to the primary fuse... If the primary fuse is blown.... Chances are that you have a bad Diode in the Tube side of the circuit. Depending on the age of the unit... it maybe a HVR-1 diode. If their are no relays on the controller board, check for a bad Triac. It could be just time to junk it.
Sep 07, 2008 | Microwave Ovens
Need to replace the circuit Board.
You can call Canon tech support and be transferred to the parts department.
Hope this Helps!
Jun 08, 2008 | Canon PowerShot A640 Digital Camera
Fantom Vacuum powder head Parts
In Canada I don't know. Parts for the older Fathoms are getting scarce. There is a wholesaler here in the US that has parts, but you have to be a repair shop to buy from them and I don't know if they are in Canada. Call your local repair shops to see if they can get you that circuit board, the co. name here is Essco, or Electric Sweeper Service Co. Wish I could help more.
Apr 24, 2008 | Fantom Vacums Lighting Canister Vacuum
Subwoofer Module N-200 ( Nuance ) Short on circuit board
I'm working on a guys board looks like it is the Q10 and Q1 transistors I'll let you know how it goes.
Jan 05, 2008 | Audio Players & Recorders
Parts
you can get parts on ebay at shop jimmy an ebay store. However they will not be listed as Hisense parts. You have to take the numbers off of the circuit board you wish to replace. Almost every circuit board is actually made by Samsung as is the actual screen and then put into off brand televisions like Maxent, ESA, and Hisense. These three companies have used about 90% of the same parts in their 42" edtv's from what I can tell. I actually have the exact same television you have and it needs a non-Samsung part. So if you don't have any luck maybe one of us could canabalize the others tv or swap parts to trouble shoot our problems. Scott austin, tx
Dec 11, 2007 | Hisense TA42P40M 42 in. Plasma Television
Goodman GMS90703BXA Heater Logo
120 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
