We have a JVC AV-32F577 tv that we purchased about 1.5 years ago. Over the weekend my husband turned the tv off using the remote. When he tried to turn it back on a short time later, nothing happened. The "on/off" button on the tv will not work either. The green "on timer" light is lit. If we unplug the tv and re-plug it in, it sounds like the tv is powering on, but the screen remains black with no volume. Any suggestions?
  • Kathy Eddings
    Kathy Eddings Sep 09, 2008
    Additional note: This TV is a 32" flat screen standard TV. The on/off button will not "depress". Is there a chip or board that controls this mechanism?
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Posted on Jul 19, 2007
patopato
  • 3 Answers
SOURCE: blinking green timer light
i have seen a couples mitsubishi and i all ready talked with a tech suport from mitsubishi but they said change the capacitors in the shop were i work we do the same but the tv still doing the same then we send the dm module to them and they fixed we asked whats the real problem and they said the capacitos the best i think is send the module to them
Posted on May 07, 2008
  • 80 Answers
SOURCE: Blinking green timer light and fan turning on randomly, now no power at all
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
thanks
scott
Posted on Oct 16, 2008
  • 41 Answers
SOURCE: Tv picture freezes then goes black 10seconds later HL-R5067W
Sounds like the digital board needs replaced.
Posted on Jul 11, 2009
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi TV green flashing timer light after power outage.
You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
http://servicemanuals.vstore.ca/
Posted on Aug 29, 2009
I have a JVC AV-27120. Just purchased a new remote but the TV codes that came with the remote user guide dont work. What is the 3 digit code for my TV to program the new universal remote?
The codes in the owner manual don't work not any codes out here will help u.Return the universal remote.Try website like Remotes.com to buy an exact remote as original remote,might have some new JVC codes u could tries,but not likely it will work either.
Feb 02, 2011 | JVC AV-27120 27" TV
No video on my JVC AV-30W475 30" flat screen.
It sounds like you have bad solder connections in the Vertical circuit or the horizontal circuit. The Vertical IC may need to be replaced if resoldering does not help.
You will need to call a good TV Tech for this repair.
Aug 09, 2009 | JVC AV-30W475 30" TV
Jvc av-32fa44 tv--loud pop, then off and won't turn back on. buy new?
Its the power cap mine did the same thing about 11 months into daily use
Oct 24, 2008 | JVC AV-32FA44 32" TV
My JVC TV Problem
hi.. sir
if universal remote does not work properly.. i am not sure
just open the tv and see if any cmos battery is inserted .. in circuit board.. if any present.. answer me sir..
Sep 01, 2008 | JVC AV-27D302 27" TV
JVC AV-32F577 No Vertical
need to replace the VERTICAL OUTPUT IC or transistor, hope this helps , please rate thanks AJ
May 07, 2008 | Televison & Video
JVC AV-27530 27"
WHEN YOU TURN THE SET OFF,SOUND LEAVES BUT PICTURE STAYS ON--SOUNDS LIKE THE MAIN POWER RELAY IS STUCK-NEEDS TECH TO REPLACE BUT SHOULD BE A CHEAP JOB!!
Dec 03, 2007 | JVC AV-27530 27" TV
Remote control not working
if you still have a problem (and the tv!) email me at gmail.com
May 01, 2007 | Protron PLTV-32 Television
Delay with channel surfing
Two things I would check before contacting JVC. In the on screen menu does it have a setting under tuner controls to disable AFC? It sounds like the tuner is seeking the proper channel frequency before it locks it in and displays a picture. If there is no such setting, then I would try a channel autoprogram in the cable mode. I'm assuming you have no cable or satellite TV box hooked up to the set. JVC is usually a pretty good brand name.
Dec 19, 2006 | JVC AV-32F476 32 in. Television
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
