Question about Ricoh FT5832 Copier
Ricoh FT5535 I am gettin an error on my ricoh ft5535 machine : E140 ,; call service. Please suggest what shuld I look for.
    Problem Solver:
  • 13 Answers
Either the lens sensor is not seeing the lens at home position, or the lens is not getting there. Also check fuse 303 on the DC board.
Posted on Sep 09, 2008
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
I have a ricoh ft5535 photocopier.. the problem is when the copy come out i has two line on both side left and right... i want to reset my machine to factory default setting... somebody help me... plesae
This is not related to factory settings. This have everything to do with general service and consumables, so do optical cleanup and replace drum, cleaner blade, fuser rollers and corona wires.Developer must be adjusted by sim 65 then you can do exposure setting with sim 48.
Jun 11, 2011 | Ricoh FT3713 Copier
I have a ricoh ft5535 copier. When I click copy the display panel reads, "misfeed remains inside" and the area "A" light comes on. There is no paper in the machine anywhere.
This alert can result from the smallest portion of a paper misfeed. Open all doors and look into each roller corner for a piece of paper that may have been jarred into a corner.
Dec 31, 2010 | Office Equipment & Supplies
Ricoh FT5535 paper misfeed
I know your Ricoh. Your problem simple. However me it is difficult you tell in internet.
Let's on order. I Sergey, My experience of the work 18 years. Rico although and good копир, however moody. Here, it is difficult without skilled help. I have understood so that beside you stick the paper in enterring трэке. And with hands direct move and with pallet. Then listen. I shall enumerate причичины, but in afterwards check.
1. Vysoh giving roller.
2. The Substrate, which is found under rubber roller or is damaged or disappeared.
3. Exists the damage to axis of the presenting the paper and she on adjoins to paper exactly 4 Simply there is hindrance to passing of the paper 5 Sensors of the entering the paper or is littered or small flag sensor came out of jack and his(its) has wedged 6 Nakonc, most probably, this only in device Ricoh - on axis, which provides in motion feeder, seizes the paper, on which roller, on the part of opposite front behind there is bushing of the joining, she provides in motion roller joinings and stretches the paper. This bushing of the joining устроета thereby that she abrades or is polluted by dust. It is Necessary to remove the back cover, get before this bushings to see her(it). Otkrfti front lid and put(deliver) the stub on sensor to make lid and look, what operates the mechanism of the drive in moving the axis on which is located roller of the presenting and tracktor of the papers. Attentively define in what time stops the paper. Advisable give the paper with hands without pallet. If you find that gross does not revolve, but щелчQк there is, you necessary to analyse the bushing which on axis and wash the alcohol and define her wear-out, otherwise her(its) zameniti. my address goodgold@inbox ru Sergey. Write
Sep 11, 2009 | Ricoh Office Equipment & Supplies
Misfeed when attempting to make a copy - Ricoh FT5535
If you are a technical person you may want to remove the tray from the machine (pull all the way out, tilt upwards, and pull.) to clean the rollers. Once the trays are removed you will see a set of three rollers for each tray. They can be removed and cleaned or cleaned directly on the machine. They may have build up dust on them preventing feed. Reinstall the trays the same way they came out but in reverse steps.
Then:
1. Pull offending tray all the way out and remove paper.
2. Unlock the side guides and make sure they move freely
3. Set about 100 sheets of NEW paper for now and adjust the side guides and the end fence. The end fence must be against the paper (touching) and the side guides must NOT be too tight agains the paper as this will prevent the tray from lifting.
4. Make sure the paper size dial is set to the paper SIZE and ORIENTATION.
5. Close tray and test.
Let us know what happens. In the worst case it could be a Magnetic clutch malfunction
Aug 28, 2009 | Ricoh Office Equipment & Supplies
Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
Jun 09, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh Fax 3700L
Fuser error.....Either blown fuse, bad thermistor, or blown lamp. Problem needs to be repaired, and then a WAY over complicated reset procedure has to be performed in service mode to clear the error.
Apr 28, 2009 | Ricoh Office Equipment & Supplies
Error code E103
there are three posible causes for the above mentioned problem
  1. Scanner lamp blown
  2. thermistat blown
  3. Home position sensor is not working
One or a combination of these three conditions will cause E103 and hense you can replace as appropriate.
Aug 05, 2008 | Ricoh FT5832 Copier
Service error 0544 on a Ricoh Fax 5510L
Hi there the error you have is that the fuser unit is lower than 130 degrees for 1 minute. Suggestion replace fuser unit turn power off the on. If problem still persists replace control board or power board.
Thanks Jason
Jun 26, 2008 | Ricoh FAX5000L Plain Paper Laser
Ricoh FT5832 Copier Logo
243 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
