-   I've got a sold amber light after a total freeze up on my computer. tried restarting to no avail... pulled video card didnt change anything. I get the keyboard check and hard disk spin but no video and its not completing the boot (no bios beeps as there is no internal speaker) i found a refurbished motherboard here:
any suggestions (this rebuild would cost me $190 plus shipping) what do you think?
-   Abraham_adam
Sep 22, 2008
-   I had just cleaned the fans (power supply and processor) of my optiplex GX260 PC. I started it the first and it worked well. I then restarted and changed the hard disk. It just stalled. When I opened I observed an orange/amber light that comes on and just stays on. But nothing else works. HELP!-   Guest
workaround - i have the same problem with my dell gx260 but have a work around. unplug the power cord and let the unit sit for about 2 minutes. if you open the case you will see a large yellow led light on the motherboard. wait for the light to go out then plug the unit back in and power up. this works most every time on my machine but occassionally i need to repeat it.
i suspect it is the power supply not powering the hard disks and not a problem with the motherboard.
1st remove all PCI cards, see if anything changes. If no change\:
If the power LED is solid AMBER, replace the motherboard
If Flashing AMber, replace the power supply
Was this helpful?
Yes
No
Popular Solutions for Dell OptiPlex GX260 PC Desktop
When i turn the tower on the fans start then a little red light flashes but then it turns off after...
(More)
When i turn the tower on the fans start then a little red light flashes but then it turns off after few seconds ? please help it is a Packard Bell
i hv window 7 installed on my computer, i hv made 6 partition on hard drive... i dont know what...
(More)
i hv window 7 installed on my computer, i hv made 6 partition on hard drive... i dont know what happend today... when i try to open the G: drivemsg displays>> ''Access is denied''. i m not able to open the drive. in its properties 0 byte free. Any help??? plz. my all important data is saved on this drive.
'Error code 5 cannot boot from disc' message when trying to clean install windows 7 on 'Time'...
(More)
'Error code 5 cannot boot from disc' message when trying to clean install windows 7 on 'Time' computer system about 6/7 years old. 2 gig memory, 1250 Athlon processor - MSI board New hard drive
