Got a new computer and now I cannot get the printer to print from the computer.I am hooked to a modem and all connections are OK.
  • pmessing Sep 08, 2008
    I disconnected. I cant find the vista link
  • 1,879 Answers
LINK http://search.lexmark.com/printer/US/en/15K0000
>bottom half of the page click on the Windows Vista link
>then a new page, again bottom half, from the drop-down select Windows Vista only
>next page bottom half again hit the download now button
read the information on that page regarding the product use with vista
Posted on Sep 08, 2008
  • monk3ybidzness
    monk3ybidzness Sep 08, 2008
    what happened ? you got disconnected
  • monk3ybidzness
    LINKhttp://search.lexmark.com/printer/US/en/...
How to hook up a wireless printer to a computer
Does the printer also have some "wired" interface (parallel-port, or USB-port)?
If not, then you need to purchase a router with wireless capability:
1. Connect cable-modem (or DSL-modem) to the 'WAN' (or 'IInternet') port on the router.
2. Connect one of the 'LAN' ports on the router to the network-port on your computer.
3. Configure the wireless-adapter inside the router:
* set an SSID -- the "name" of your wireless network
* encryption-level -- use 'WPA' or 'WPA2'
* a password for your network
4. Configure the wireless printer to connect to that SSID, using the password
5. On the computer, click "Add Networked Printer"
6. Print a "test" page: computer -> wired -> router -> wireless -> printer
Mar 18, 2011 | Canon Office Equipment & Supplies
I just bought a apple macbook pro and would like to use my printer over the network rather then having to connect usb every time i want to print. how do i do this i have a big pond wireless modem its the...
you can buy a print server to connect to your printer to the network. however could you please list the printer type you have? some printers do not work over the network with a print server on mac.
the printer will still function as long as you got a phone line to it for faxes however some features like scanning will not work over the network.
Mar 07, 2011 | Computers & Internet
How do I pair up my printer with my new moden?
Hello Melissa !
What you need to do is to physically connect the printer to the modem, now your computer should be connected hardwired or wireless to this modem.
When you connect the printer to the modem , the modem will assign an IP Address to the printer, you can look on this ip address by printing a configuration report from the printer itself.
Now we have 2 options here, use the software that came with the printer (installation disc) to install the device and at some point of the installation it should detect the printer automaticaly, just remember choosing "network install"
If you already have the software on your computer, you will need to uninstall / reinstall the software so the computer can detect the new ip address. Or you can set the ip address manually by going under printer and faxes on the control panel, make a right click on the P4350 icon, go to properties, then the "Ports" Tab and click Add Port, you will need to select Standard TCP/IP, click new .. and then type the IP Address
This should connect your printer with your new modem - computer
Good Luck !!
You can contact me at:
eliteprintersolutions@gmail.com
Jul 17, 2010 | Lexmark P4350 All-In-One InkJet Printer
Got a new DSL modem from ISP and now wireless router won't work.
try to contact your ISP make sure you are not violating any rules then try resetting your router and modem check if that works
Mar 17, 2010 | Dynex 4-Port Ethernet Broadband Router...
Can't print from local printer using remote connection
To print the reports on your local printer, go to
1.Start->Run->
2.Type 'mstsc' and click 'ok'. A window pops up for Remote Desktop Connection
3. Click 'Options' button and select the 'Local Resource' tab.
4. Select the checkbx 'Printers' from the 'Local Device'
5. Click Connect.
Aug 20, 2009 | Actiontec GT701C DSL Modem
LexmarLk X4850 fax wireless set-up
Printing: since Lexmark say you can either connect wirelessly or wired and not both, you must either connect your daughter's machine to the hub by wire or yourself to the printer wirelessly.
Fax: this will need a phone line.
May 27, 2009 | Lexmark X4270 All-In-One InkJet Printer
Connecting a network printer to 2wire 2701HGV-w
This is a little tricky technically it your printer isn't made to go onto the network, but you and do one of to things... let me start with the most cost effective way and that is
1. Hook your Printer up to a computer that is already on the network and then go into windows and SHARE that printer giving access to all the computers to print to it that you need to. I don't know what Operating System you have so your going to have to give more information to get clarification on exactly what you need to do in the Operating System to share the printer. The CONS of this approach is that you can only print to that printer when that computer is on. So if you want to have continuous ability to print to that printer you will have to keep your computer on.
2. You can get what they call a Print Server... and connect it to your printer and your network.. turning your printer into a network printer. Of course you might need to get more detail depending on what Print Server you choose. The Cons of this approach is that ofcourse your going to have to buy more equipment... but the pro's are you won't have to keep other computers on in the network to print to it. One last note you will find Print Servers in the store where you find Routers and Hubs.
The best of luck to you... and I hope this Helps... after you decide which way you want to go you might want to contact me or one of the other techs to get more percise approaches to installing your equipment... but we will need to know you Operating System, and the Print Server... if you go that route. Good Luck! I hope this works for you!!!
Sincerely,
cdixon18
The Man Inside the Machine
May 20, 2009 | 2wire (1000-000057-000) Modem
I keep getting print spool message about my printer, I just hooked up a new Qwest modem with wireless
I found that you need the newest driver from the HP site and you may need to load it again and have it look for your printer IP address automatically, Mine was a pain at first and every time I have replaced my switch ot network router I have had to "rediscover" the printer as the network seems to ignore it...
Oct 09, 2008 | HP Office Equipment & Supplies
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
