Question about RIM BlackBerry Pearl 8100
Keyboard works but cannot dial
For some reason I cannot dial numbers anymore. I do not have fixed dialing on and I can make calls from my contacts. But I cannot dial a new number to make a call. What should I do?
Not sure if this is related, but I did notice an arrow on my screen located in the top right corner. The arrow is pointing upwards. Is this connecting to the dialing problem?
Thanks!
  • yorbalynda Sep 08, 2008
    Removing the battery and then restarting it fixed it! I always forgot that simple solution! Thanks!
  • RIM Master
  • 13,433 Answers
Do the buttons work at all? Try to remove the battery for a moment, and also a reset - master reset. covered on this page
http://forums.wireless.att.com/cng/board/message?board.id=rim&message.id=40447
Posted on Sep 08, 2008
    Genius:
  • 1,665 Answers
I think key pad must be removed to clean contact surfaces.
My Duo has dial tone, I can dial out, and it works fine. But when anyone calls me they immediately get an automated message to the effect "the number you dialed is not a working number, please hang-up and...
This is a problem with the your VOIP carrier failing to translate and switch incoming calls to your device. Contact them and describe the problem and they should be able to fix it fairly quickly.
Mar 06, 2015 | netTALK DUO Wi-Fi VOIP Internet Phone...
What is fixed dailing number
If you turn on fixed dialing, you can only make calls to contacts that appear in your fixed dialing list.
You can make an emergency call when fixed dialing is turned on, even if the emergency number does not appear in your fixed dialing list.
If your wireless service plan includes SMS text messaging, you can also send SMS text messages to contacts that appear in your fixed dialing list.
Feb 24, 2011 | Computers & Internet
I have i-mate jama 8050, i can't make call from my mobile,my mobile can call only the contacts which are saved in sim,but not calling on the number which is not in contacts list, please help me,
Your mobile has been programmed to only make calls from your contacts. This is controlled in your settings menu under 'Fixed Dial'. (or similar command). You will need to change this setting.
I do not have a copy of the user guide for your phone but for most phones these are the directions:
When you turn on fixed dialing, you
can call only numbers stored in the
fixed dial list.
Turn fixed dialing on or off:
- > Settings > Security > Fixed Dial
Use the fixed dial list:
- > Settings > Tools > Dialing Services
> Fixed Dial
Jan 26, 2010 | i-mate Jama 101 Smartphone
LG Xenon Keyboard Broken
MAYBE, you slid it too fast and broke the FLEX cable
Jul 29, 2009 | LG Xenon GR500 Cell Phone
Restricted calls on my lg chocalate
When a cell phone is lost the cell company often places restrictions on teh phone so outrageous bills are not ran up on an account. The reason the numbers that are already input into the phone can be dialed may help ensure it is returned.
Jun 19, 2009 | Cell Phones
Speed dial
NEW Number
Function
72
set
press destination like 01 the yellow part of the keyboard
enter fax number
set
enter name
set
stop
Delete a number?
press as above like 02
press clear
set
press clear
press set
stop
Apr 30, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Dialing the number
I went to to setup menu and updated through internet.The phone started working ,Thus the problem was solved but now i face another problem with it.The touch screen went dark ,although the navigation keys are working .i cannot call any contacts ,because the touch screen is not working.
Jan 18, 2009 | Cell Phones
Use call phones through voip321
It took me a while to figure out but here is how I am able to dial out from skype to a hardline to a person not in my skype contact. Simply start to dial the number (not from the talk button!!!) then instead of hitting the talk button to dial, hit the skype button on the bottom left hand side. I also have to dial 001 then the phone number. Hope this works for you too. good luck.
Sep 25, 2008 | Philips DECT VOIP-321 cordless telephone
Blackberry 7100g
About fixed dialing
If you enable fixed dialing number (FDN) mode, your device only makes calls to contacts on your FDN list. Your device can dial emergency numbers in FDN mode, even if the numbers are not in the FDN list. If your service provider plan includes SMS, you can also send SMS messages to contacts on your FDN list
so if you have this enabled chances are you have to turn it off.
this is how you turn it on so you should be able to use it as a guide to turn it off.
Turn on fixed dialing
1. In the phone options, click FDN Phone List.
2. Click the trackwheel.
3. Click Enable FDN mode.
4. Type the PIN2 code provided by your service provider.
5. Click the trackwheel.
or if you wanna keep it on and add friends to the fdn
Add contacts to the FDN list
3. Click New.
6. Type a name and a phone number.
7. Click the trackwheel.
8. Click Save.
and finally some shortcut keys:
To open the phone, press the Send key.
To end a call, press the End key.
To call a selected contact or phone number, press the Send key. To call a speed dial number, hold the assigned key.
To add an extension to a phone number, press the X key. Type the extension number.
To call your voice mail access number, hold 1.
To type a letter in a number field, hold the Alt key.
To type the first letter on a key, press the letter key once.
To type the second letter on a key, press the letter key twice.
To turn on or turn off mute using the Mute button, press the Mute button.
To turn on or turn off mute using the keypad, press the exclamation point (!) key.
To turn speakerphone on and off during a call, press the period (.) key.
To change the volume during a call, roll the trackwheel.
Aug 02, 2008 | RIM BlackBerry 7100G Smartphone
Speed Dial quit working
why for restart my V3 mobail?
Sep 07, 2007 | Motorola Mobility RAZR V3
RIM BlackBerry  Pearl  8100 Logo
122 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
