Question about Samsung HCN4727W 47" Rear Projection Television
HCN4727W Convergence issue
I have a local shop and I am having some problems with the convergence board on a HCN4727W. Quite a few components are burnt up and I can't tell what value they are. I was hoping you might have a schematic and be able to help me out. I need to know what STK's it needs. Locations: RZ142-RZ145, CZ141and CZ140. My email is Thanks in advance.
  • serge1er2003 Jan 26, 2009
    I have the same problem but now I have a different problem I bought a new board for the samsung, I plug every wire like it supposed to be but now when I turn it on it make a rumbling sound in the back for 8sec and it turns off. when I install the old burnt convergence it comes on, it sound like a safety is on for some reason please help
  • Samsung Master
  • 5,138 Answers
Repalce STKs with 392-040 resistors should be 3.9 ohms,also you might want to join Repairworld it is for members who have TV shops over 7,000 different shops / lots of good techs there.They will not put up with anyone just looking to repair there own tv .Sorry unable to help with cz140,141.will do some checking you also can order whole convergence board.
Posted on Sep 14, 2008
Blue green and red not in line. how to solve
Thats a convergence issue which is caused by the convergence amp board needing repair. The samsungs with the P55A chassis such as your model usually require replacing the convergence amp board which is a simple unplug old board and plug in the new one repair. You can get the convergence amp board for your model from
Jul 12, 2011 | Samsung HCN4727W 47" Rear Projection...
The picture has double images and looks kind of like it is 3D.
The tv have a problems known as a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv convergnece board,must have these parts changes on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 31, 2010 | Panasonic PT-47WX49 47" Rear Projection...
The green and red color are seperated. how do i figure out which bulb it is or how to fix it myself..
Thats a convergence issue. you will need to replace the two Convergence IC and quite possibly a few of the 6.8 ohm resistors. You can get the phillipd DPTV305-DPTV345 convergence repair kit from the kit works for your model also and it includes the ICs and resistors plus the CD with detailed repair instructions.
Aug 03, 2010 | Philips 50P8341 50" Rear Projection...
Projecting double images
When convergence output ICs got failed, tv shows double image or 3D like picture. Replace convergence output ICs in tv to fix the issue. Local tv repair shop will replace it for you.
Jul 07, 2010 | JVC AV-56WP74 56" Rear Projection...
Mitsubishi Convergence Problem
you need to replace the convergence board but it will cost you around $200 to fix the board and components associated with it .......
Have you tried adjusting the convergence settings ........
Oct 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
HCN4727W with Convergence issues
The ICZ designations on that board are two Sanyo STK392-040 amps used for convergence. Rz142 through Rz145 are the yoke return circuit are 3.9 ohm 1/2w resistors. CZ140 and 141 are two electrolytic radial 22mf/50v caps in the feed circuit for those amps.
My question would be - and I've NEVER seen this, in my 30 years in electronics, what caused such a domino failure? The amps are basically LV fed by a +/- 24v line input. If the yoke(s) were to short shouldn't cause enough feedback to destroy the convergence board in the manner you've indicated here. That's a P58A chassis used in several models of the Samsung and Akai designs. Only trouble I've heard of with those boards are cooling and most techs have taken to installing cooling fans directly on the board, driven by the +/- 20v line. That drops the temp several degrees and allows the amps to operate at a much cooler temp. We rebuild those boards here on a daily basis and add the mods for greater reliability. But other than that the P58A is considered a bullet proof chassis.
Hope this helps!
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
Sep 09, 2008 | Samsung HCN4727W 47" Rear Projection...
Blowing Convergence Amp Boards
either the DCU Digital convergence Unit or the velocity board are most likely the fault.
Jul 10, 2008 | Samsung HCN4727W 47" Rear Projection...
Samsung HCN4727W
Convergence board shot. Cheap to fix yourself, board has two STK chips on it and is easy to get to.
May 16, 2008 | Samsung HCN4727W 47" Rear Projection...
Hitachi 50UX22B Convergence Problem
there is a company called pts that will rebuild the board for u just send it in the will repair it and send it back , alwways use your wristground strap.
Nov 21, 2007 | Hitachi 43UWX10B 43" Rear Projection...
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Nov 08, 2007 | Televison & Video
Samsung HCN4727W 47" Rear Projection Television Logo
124 people viewed this question
Jerry Greenberg
Jerry Greenberg
