Unable to connect: message reads the printer is not working properly
  • 234 Answers
Make Sure to give the printer model and type while to post a query,
But still you can try the bellow link if it is a HP Printer or if it is of any help for you:
http://search.hp.com/query.html?lang=en&submit.x=6&submit.y=7&qt=unable+to+connect&la=en&cc=us
Good Luck
Posted on Sep 08, 2008
Printer installation
hi
go to this link -- self help to install, use and maintain
http://www.lexmark.com/publications/eng/e120/
hope this help
Nov 28, 2010 | Lexmark E120 Laser Printer
Brother MFC 210C printer unable to clean print head. How can I clean it manually? The inkjet cartridges are full but the printer does not print. Error message on display: unable to clean.
If your printer is like the 420CN Model, do not forget to disconnect the printer for resetting purposes and connect it again and it may clean properly and run fine. Good luck! hopes it work. It did for me. My printer is working fine and I like it. It does the work.
Aug 02, 2010 | Brother MFC 210C All-In-One InkJet Printer
Unable to receive faxes on HP Photosmart Premium
Check the configuration set for incoming FAX and rectify the settings may resolve your problem.
Thank you for using Fixya.
Jul 22, 2010 | HP Photosmart Premium C309A All-In-One...
Samsung mobile sgh-i640v not working properly display after any call call failed and push camera key display message unable to connect camera
my mobile sgh-i640v desactive hemself evry time whats is the problimeeeeeeeeeeeeeee pleaseeeeeeeeeeeeee help meeee
May 11, 2009 | Cell Phones
Unable to acquire picures from camera to pc
Go into the add hardware wizard with the camera connected to the usb port and power on.
Go thru the procedure and it should start working...
Mar 30, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
Brother MFC-5860CN print unable 51 error message
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 31, 2008 | Brother Multi-Function Center MFC-240C...
Unable to print copies
Dec 30, 2008 | Brother MFC-845CW InkJet Printer
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
47 people viewed this question
k24674
jasbo
jasbo
