Question about ASUS P5S800-VM Motherboard
Ide not work
Secondary ide for p4s8x-mx not work
  • Ebrahim Metwly
    Ebrahim Metwly Sep 09, 2008
    i already did all of these i want to know any circuit or ic responsable about work this port to change it
  • 983 Answers
There may be some problem in the ide cable just change the ide cable and try once .. you can check it by going to BIOS whether after replacing the ide cable the device detects or not ..
if you persist same problem then there may be some problem in the secondary IDE port(may be some pin might have broken or some short circuit might have occured have a check) just take your motherboard to the motherboard technician if so ...
Posted on Sep 08, 2008
ASUS P4S8X-MX Motherboard AUDIO DRIVER DOES NOT WORK says access is denied
Hello, you can download the drivers here:
http://www.asus.com/Motherboards/Intel_Socket_478/P4S8XMX/#download
Please select your windows version.
Download the newest audio drivers by clicking on
global.
And unzip the file before installation.
Oct 16, 2011 | ASUS P4S8X-MX Motherboard
Driver the video ASUS P4S8X MX driver, necesito
please go to this page and select aprriopriate operating system tehn download required drivers:
http://support.asus.com/download/download.aspx?modelname=P4S8X-MX&SLanguage=en-us
Aug 14, 2010 | ASUS P4S8X-MX Motherboard
A bios nao reconhecer o son
Verificá-lo durante a inicialização do BIOS http://support.asus.com/technicaldocuments/technicaldocuments.aspx?no=270&SLanguage=en-us
BIOS mais recente Baixe para P4S8X-X de
http://www.roxysoft.com/drivers/ASUS-P4S8X-MX-Bios-v-0502-download-driver/
Siga as instruções e instalar:
http://www.asus.com/999/html/events/mb/ezflash.htm
During bootup check you bios http://support.asus.com/technicaldocuments/technicaldocuments.aspx?no=270&SLanguage=en-us
Download latest bios for P4S8x-X from
Follow instructions and install:
Sep 15, 2009 | ASUS P4S8X-MX Motherboard
Asus p4s8x-mx support CD
If you want a copy of the CDs contact Asus by clicking here and ask if they can sell you a replacement cd for your model.
Instead of getting a replacement CD you can download and run the drivers from Asus download page here:
DRIVERS for Asus P4S8X-MX Motherboard
Sep 05, 2008 | ASUS P4S8X-MX Motherboard
Usb
http://www.driverfiles.net/Bios/ASUS/P4S8X-MX/download/page,sh,29990,172,6,.html
download your drivers here
Hello sir
Here is the web link
http://support.asus.com/download/download_item.aspx?product=1&model=P4S8X-MX
next time dont be so lazy and google it yourself!!!!!!!!!!!!!!!!!!
Aug 16, 2008 | ASUS P4S8X-MX Motherboard
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
ASUS P5S800-VM Motherboard Logo
74 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
