Question about Microsoft Xbox 360 Console
Help connecting to XBOX Live
I?m trying to connect to XBOX Live through my computer modem(telewest). It?s unable to connect and tells me that the IP is already in use. The modem is not connected to the computer. Do I need a router or something similar, or am I failing at some other point?
  • 21 Answers
If the modem is not connected to a computer, you have no need for a router. Try restarting the modem with the XBOX connected, that might do it.
Posted on Feb 21, 2006
Not connecting to internet
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Jun 07, 2010 | Video Game Consoles & Games
XBOX 360 LIVE Won't Connect
Is the modem also a router?
You need to login to the IP address of your device... if the modem is only a modem, try going to your own IP address.
http://whatismyip.com will help you find it. This may bring you into the settings of the modem. If it is a router as well, then you will need to go to your default gateway's IP address.
Go to start, then run.
Type cmd, then click ok.
type 'ipconfig' and hit enter. Look for your Default Gateway
type that ip into your browser (IE/Firefox/whatever) and login
adjust the MTU to recommended settings. If its at 1500, try 1364 of 1492
Jun 16, 2009 | Microsoft Xbox 360 Arcade
Cannot connect ot xbox live my ip address test fails
if you dont have a router, you can either have the xbox or the pc conneted to the internet, not both. you have to have an eithernet cord or a usb 2.0 high speed usb chord that goes directly from the xbox to the modem. you cannot go from the modem to the computer then to the xbox.
Jan 24, 2009 | Microsoft Xbox 360 Console
Problems connecting to XBox live
I would strongly suggest to call Xbox techsupport for help. They will tell you what are the things taht you may try...its for free!!
Dec 08, 2008 | Westell Wirespeed LiteLine 6100...
Unable to connect to Xbox Live!
are you connecting both imac and xbox to the internet at the same time? is your adsl modem a modem/router? and does it have wireless capability?.. if all answer are yes.
assign static ip/subnet mask/default gateway and dns on xbox, then forward 88/3074 on your modem/router.
Nov 08, 2008 | Computers & Internet
Ip address failed
I think you need to ring your internet provider and they will enable xbox live from their side. Its fairly simple and they will know what your talking about.
Oct 20, 2008 | Microsoft Xbox 360 Console
IP Address keeps failing on my Xbox 360
You shouldnt have an amp, when you do this. Also, you arent supposed to plug the modem directly into the console. It is supposed to be plugged into a router, which is pluged into a computer. That was, you can configure it.
Apr 04, 2008 | Microsoft Xbox 360 Console
Can't get Xbox live to Connect to Xbox Live
wait 30 secs then turn it on then wait 30 sec to dotest
Mar 02, 2008 | Microsoft Xbox 360 Console
Xbox live
THINGS TO TRY loadTOCNode(1, 'whattotry'); Direct connection with a modem only loadTOCNode(3, 'whattotry'); 1. If you are connecting to Xbox Live by using a modem that is connected directly into your broadband socket, your IP address settings are obtained from your ISP. Set your IP address in Network Settings to Automatic. 2. If you use a static IP address that you obtained from your ISP, you must manually enter this address in the Dashboard. Contact your ISP for their static IP address if you do not know it. If the IP is not static, continue with the rest of the troubleshooting. 3. Power cycle the modem. 4. If your ISP requires PPPoE settings, verify that you have entered them correctly. 5. If your ISP does not use PPPoE authentication, do not use these fields in the Dashboard. Shared connection with a modem and a router loadTOCNode(3, 'whattotry'); 1. Power cycle both the modem and the router. 2. Try connecting the Xbox 360 console to Xbox Live by using the modem only. This eliminates any configuration problems on the router. • If this setup works without the router, there is a configuration issue with the router. See the router's documentation or contact the technical support group. 3. Verify that your router's DHCP service has been enabled. See the router's documentation or contact the technical support group. 4. The IP address that you entered in the Network Settings area of the Xbox Dashboard may be incorrect. Set your IP settings to Automatic. 5. If your ISP requires PPPoE settings, try to connect with only the modem after you enter the PPPoE settings in Network Settings. • If you can connect, see your router documentation to configure the PPPoE settings correctly on the router. 6. If you are receiving an IP conflict error in the More Info section, turn off all the devices on the network. Try to connect with only the modem and Xbox 360 console connected. • If this works, there is a configuration issue on the routers DHCP server. See the router's documentation or contact the technical support group. Shared connection with a gateway device (combined modem and router) loadTOCNode(3, 'whattotry'); 1. Make sure that the device is turned on. 2. Verify that there is activity with the blinking lights sequence WAN, ADSL, and Internet connected power. Note These names will vary from model to model. 3. Power cycle the gateway device. 4. The IP address that you entered in to the Network Settings area of the Xbox Dashboard may be incorrect. Set your IP settings to Automatic. 5. If you are receiving an IP conflict error in the More Info section, turn off all the other devices on the network. Try to connect with only the Xbox 360 console on the network. • If this test works, there is a configuration issue on the gateway DHCP server. See the router's documentation or contact the technical support group. Shared connection with Microsoft Windows Internet Connection Sharing loadTOCNode(3, 'whattotry'); 1. Verify that you can browse the Internet. If you cannot browse the Internet, Internet Connection Sharing is not configured correctly. 2. Power cycle the modem. If the modem does not have an on and off switch, unplug the modem from the power outlet. You cannot follow this step if you are using a USB modem. Instead, go to the next step. You must follow this step if you are switching the modem between the Xbox 360 console and a computer. 3. On the computer, click Start, click Run, type ncpa.cpl, and then click OK. 4. On the View menu, click Tiles. 5. If the connection is listed as Firewalled, the firewall may have to be configured. See your firewall documentation. 6. Enter manual settings in the Dashboard for IP address, subnet mask, DNS address and gateway: • IP Address : 192.168.0.2 • Subnet mask : 255.255.255.0 • Default Gateway : 192.168.0.1 • DNS server (Primary): 192.168.0.1 • DNS server (Secondary): 192.168.0.1If none of this works you might be banned. If you modded your xbox360 or for downloading game saves from the internet to boost you gamer score. You might be banned!
Oct 14, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
42 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
