Question about Casio Exilim EX-V7 Digital Camera
Camera was dropped
After being dropped the camera makes a little noise as if it is trying to turn on but can't. I have taken the battery and card out and put them back in. Made sure the camera is charged. My question is it worth trying to get it repaired or is it toast? If it can be repaired where should it be sent.
  • 374 Answers
It can be repaired. It depends on where you live. On the east coast it would go to Dover, NJ and on the west coast it would go to California. The corporate headquarters is in NJ.
Posted on Sep 12, 2008
I accidentally dropped my samsung S1070 while I was taking a photo, and the lens is now stuck out. It won't turn on, and we've tried replacing the batteries and taking them out. I've also tried...
Check whether your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip.The next thing to try is examine both the battery and flash card door. There's usually a little switch on both doors (note some SD card doors do not have this switch) that activates when the doors are closed. If they don't, the camera won't start to prevent damage to the flash card or camera startup sequence. For most cameras its usually a little piece of plastic on the door that pushes in on a pin switch when the door is closed. Closely examine both doors to try to identify these switches. A lot of times that little plastic nib wears down or breaks off, but can easily be jury rigged with a small glued-on replacement.
If you've tried all of the above and still no luck, the problem is then likely to be internal to the camera. One example would be that if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
Thank you!
Sep 04, 2011 | Samsung S1070 Digital Camera
1. turn camera on 2. lens expands 3. lense immediately retracts 4. lens error
If you hear a noise from the lens when you try to take picture or During turn on/off time then it's a lens guide pin problem OR Somehow its jammed or damaged. It's happens when the camera pressed or drop down during turn on mode or long time not use.
For the solution you need to follow the steps.
1. Turn off the camera and remove the memory card and clean the external body of the camera and make sure in place of the lens there is no dust or damaged sign.
2. Now turn on the camera without memory card & make sure the battery are fully charged.
3. If the lens not moving then give a little shake or thrust by hand ( carefully very slow) and then wait for a moment. If no changes then turn on the camera and give a little twist an anti clock side and leave for few second. It is risky ( Do it slowly at your own risk)
4. If nothing change then reset the camera setting from the menu option.
After following all steps, if the camera does not start working then you need to visit service center for replacing the Lens or Repairing. If you have any more questions ask me I fell happy to answer your question. Thank you.
Jul 08, 2011 | Nikon Coolpix 5700 Digital Camera
Cannot open camera lens. it says "lens error 1511 or 1211
Jul 06, 2011 | Cameras
It cannot be turn off
Jul 06, 2011 | Canon PowerShot A480 Digital Camera
I have a fuji s7000 will not power up i have asked the kids have they dropped it but they just look sheepish and say i didnt what is the common asnswer its not battery as i have the main conected to it
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory carD
Jan 28, 2011 | Fuji FinePix S7000 Digital Camera
Camera will not turn on at all, no light no noises. But it worked last night.
Thank you!
Aug 17, 2010 | Nikon COOLPIX L5 Digital Camera
Why does my camera turn on, make a weird noise and
hi. you have problem in lens unit and the weird noise come from to focus gear.maybe you go to the beach or dusty place thats why the said dust or sand goes into lens gear. If you can open and try to clean its better but if not bring to service center and request for cleaning and adjustment.
goodluck my friend
Jul 13, 2010 | Casio EXILIM 10.1-Megapixel Digital Camera...
My camera makes noise when it's turned on, but not while reviewing pictures.
hi!
What you describe sounds perfectly normal! While powering on the camera, it takes out the lens and perhaps doing some mechanical self-tests. All this means moving parts using little servos inside the camera. Same happens when taking pictures - the lens moved, the shutter closes (and reopen), etc...
While watching the pictures you've taken, you're only reading digital info. from the memory cards - no moving parts, no mechanical movements - hence, no noise!
Take care,
Pelu.
Mar 17, 2010 | Kodak EasyShare Z710 Digital Camera
Olympus FE-280 not working properly
the lens could be the problem.. probably need to send to repair before the warranty runs out
Aug 28, 2008 | Olympus FE-280 Digital Camera
My optio was dropped with the lens going down first. now my camera makes noises & the screen is black. how do i go about fixing it?
looks like the gears or retracting mechanics are damaged.
its problably not worth to take it in, to get it fixed (depends on the camera). but most likely sound like the gears are busted.
you be paying for repairs that costing waaay more than the camera.
May 20, 2008 | Kodak Easyshare M753 Digital Camera
Casio Exilim EX-V7 Digital Camera Logo
75 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
