Installed new hard drive- tried to install Win XP and got this message--problem with file--isapnp.sys- computer won't go any further with install
  • Markmed623 Sep 09, 2008
    Thanks- I'll try another disc.
This is probably a problem with your install disk or CD-ROM.
Make sure you are using a genuine CD. You may need to order a replacement CD if you cannot copy or read the file, you might find in seperate attempts taht it gets stuck on different files, too.
Posted on Sep 08, 2008
How do i install windows xp when it wont let me. i reformated my medion 4215 computer and have problems with putting on win xp i get a message when i try to install xp setupdd.sys
Hi
thank you it would seem that your recovery media i.e. CD or hard driver recovery is corrupted and will need to be replaced as it cannot read the file mentioned
Please replace the CD
Regards
Shauqat
Jun 09, 2010 | Medion (20023245) PC Desktop
How to solve the problem file isapnp.sys caused an unexpected error (32768) at line 5882 in d:/ xpclient/ base/boot/setup.c.
Something is wrong with the file system on the partition in which you try to install XP. Start the install again and this time when asked where do you want XP to be installed delete the old partition and create a new one.
May 15, 2010 | Computers & Internet
How to upgrade win 95 to winxp without removing files installed
A computer running Windows 95 WILL NOT RUN Windows XP in most cases. Post all of your hardware details and we can explore that further.
Most programs that run on Windows 95 WILL NOT RUN under Windows XP easily. There are some compatibility things you can try for each one, but most simply will crash, and some will seem to work for a while then crash at inopportune moments.
What you should do is buy an newer computer with Windows XP, remove your current hard drive, and put your current hard drive as a second drive in the new computer. You will have access to your documents, but your programs will not run.
Mar 14, 2009 | Intel Pentium III, 800 MHz...
Video Drivers
The file “Windows/System/Drivers/mup.sys” is not actually causing the problem. It’s the next step after mup.sys that’s causing the computer to hang. That next step consists of the OS checking the registry files for plug and play devices.
Some causes are: new or defective hardware installed, corrupted registry, (caused by virus), defective or corrupted hard drive, just to name a few.
Try removing all devices attached to the computer like printer, web cam, flash drives, etc.
If your computer has a PCI or AGP graphics card AND your motherbrd has a VGA connector, remove the video card and use the one on the motherbrd.
If the above doesn’t work, try running “CHKDSK /P” from the Windows recovery console.
Your responses are intended to improve the level of service provided. Please rate this solution.
Thank You.
Oct 18, 2008 | Dell OptiPlex GX260 PC Desktop
Windows installation
sys file from the cd is corrupted...try wd any other disc
Aug 02, 2008 | Compaq Presario Notebook
Installing win xp from external hard drive
Umm...is your laptop crashed??? Usually ntlldr issues ****. try to delete the former installation so a new ntldr file can be installed so as to not conflict with the damaged ntldr file that is on the pc blocking the install. It sounds like your setup is ok...at the very least get another xp cd to make sure the disk is not damaged that you are loading windows from.
Aug 01, 2008 | Computers & Internet
Kstvtune.ax
ALCXWDM.SYS
portcls.sys
ksxbar.ax
kswdmcap.ax
vidcap.ax
vfwwdm32.dll
CCDECODE.sys
NABTSFEC.sys
WSTCODEC.SYS
ipsink.ax
MSTEE.sys
isapnp.sys
usbuhci.sys
usbuhci.sys
stream.sys
wdmaud.drv
ks.sys
ksproxy.ax
drmk.sys
ksuser.dll
I can't install my multimedia as these files are missing. I tried reinstalling the drivers but it needed these files which I can't download even after I have inserted the Windows XP Cd. Can you please help me with this also let me know how I can download these files from the net.
Jun 02, 2008 | Microsoft Windows XP Professional With...
New sata 500 gig hdd - ST3500320AS SD15
Dear Customer,
thats problem regardiong to your windows version if its working proerly when newly installed than may some files delted during some uninstalation can do all this stuff,
so try to install new full version windows xp than try ,i m sure about that your problem will fixed up.
THNX
May 17, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
ACER 4720Z
seems that it's a SATA drive and the drivers are not included in XP.
There are some tools available to include these drivers into the XP CD.
Search the net for 'xp-iso-builder' or 'n-Lite'.
This is not necessary if your laptop's got a floppy drive (i don't think so). Then the SATA drivers can easily be loaded by pressing F6 when booting from the XP CD.
Mar 02, 2008 | Microsoft Windows Vista Ultimate Edition
My hard drive shows only 1.5 GB instead of 100
is it correct that you installed XP from an "upgrade" pack?
when you installed XP did you convert the file system to NTFS?
Dec 26, 2007 | Maxtor Hard Drive
Computers & Internet Logo
David Payne
David Payne
