Question about Whirlpool Washing Machines
I have a whirlpool duet that is getting an error code of6. what does this code mean?
  • 1,028 Answers
Ck wires from motor to main control remove top to acess main control remove bottom panel to acess motor and motor control bd if wires ck ok suspect main control ..motor control a little more reliable but possible usually that would be f07
Posted on Sep 09, 2008
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ...
    • 6 MIN
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - · PDF file Kenmore Elite He3 F11 Error Code How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Fh error code wirpool duet washer
    Display shows F20 or FH - Front-load washer ' Whirlpool ...
    Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
    whirlpool duet error code FH - Appliance Repair Forum > Appliance Repair Help > Washer Repair
    Jan 5, 2009 - 10 posts - ‎1 author
    ... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
    1 post
    Dec 5, 2014
    Whirlpool Duet Washer HF Error Code
    Jun 10, 2013
    FH Error Code on Whirlpool Duet Washer
    Mar 11, 2013
    FH error code
    Sep 13, 2008
    More results from
    Stumped on error code FH for Whirlpool Duet front load washer .
    Jan 08, 2016 | Washing Machines
    What does f23 error mean?
    Display shows an error code - Front-load washer ' Whirlpool ...
    Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
    What does error code f23 flashing mean on a Whirlpool ...
    Nov 30, 2015 | Washing Machines
    Error Code 01 F06
    Your fault is mentioned here.
    An F06 fault code in a Whirlpool Duet washer (the Kenmore HE3/4t's are also made by Whirlpool) usually means a motor-related problem. It usually pops up when the drum won't rotate at all or only very sluggishly. Here's the excerpt from the Whirlpool Duet Service Manual on this:
    May 10, 2015 | Maytag Dryers
    What does the error code E04 mean on Whirlpool AWU610 Washer-Dryer
    Any error code starting with "E" followed by numbers indicates a code meant for a service technician. Call your Duet dryer retailer or Whirlpool directly to set up a servicing appointment.
    Read more :
    Mar 16, 2015 | Whirlpool Washing Machines
    Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
    Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
    To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
    Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
    My Whirlpool Duet front load washer is giving a F 11 error.
    power failure--------unplug the unit for 5 minutes and see if it clears that code
    Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    I have an error on my Whirlpool Duet Washer. What does it mean?
    It means there is something wrong with the machine. Do you have the error code?
    Dec 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet Sport ~ E28 Error Code
    serial communication error between central control and motor control.
    Check connections at ccu (top front right corner) and mcu (bottom by motor), check belt drive for wear.
    Did motor run ? Any other codes in diagnostic? (any one modifier button 4 sec on 4 secs off 5 times.) F codes are failures and C codes are portions of test cycle(automaticly run)
    Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    69 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
