ASUS P5VD2-MX SE Motherboard Logo
Posted on Sep 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem solved but now something else!!!
I've re-installed xp and sp2 on my computer. The problem is now my internet explorer doesn't work. All it does it brings up a page starting with "use the refresh button" and it goes on by saying to check internet settings settings. It sometimes works when I press the refresh buttom a couple of times.
  • pielates2003 Sep 08, 2008
    forgot to say, the internet did work before I installed sp2. do not know if this has got anything to do with it
    Thanks
Anonymous
Level 1:
New Friend:
  • Contributor 49 Answers
  • Posted on Sep 22, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
49
Questions
Helped
21801
Points
77
Download ie8 new version..
Anonymous
Level 3:
  • Master 983 Answers
  • Posted on Sep 08, 2008
Anonymous
Master
Level 3:
Answers
983
Questions
8
Helped
434337
Points
2838
Your system might have attacked with some virus/spyware due to that it is not letting you to access internet .. please scan your system with good updated antiivirus & anti spyware...
delete the virus/spyware which is detected ...
or you can also just format the drive containing the operating system and you can reinstall the sp2 by the boot cd ..
regards
rate mt solution
Windows shuts down The Print Shop 3.0 Deluxe
print shop 3.0 is compatible with XP SP3 vista SP2 and windows 7. to install it correctly you must be logged in as administrator or right click the installation setup and choose Run As Administrator. if you dont do that it doesnt install correctly if you are trying to use it on any other windows system it wont work. print shop 4.0 is compatible with W8 or W10. once installed you may also have to Open the program using Run As Administrator too.
tip
INTERNET EXPLORER 8 CANNOT INSTALL IN WIN XP SP2
IF INTERNET EXPLORER 8 CANNOT INSTALL IN YOUR WINDOWS XP SP2. THEN U CAN INSTALL IT AFTER INSTALLING "WindowsXP-KB936929-SP3-x86-ENU.exe" (search from google download from microsoft site. the file is of 316MB.) AFTER INSTALLING THIS YOU CAN INSTALL INTERNET EXPLORER 8. IT WILL ALSO UPDATE YOUR WINDOWS FROM SP2 TO SP3
Internet explorer 8 hangs on opening a web page
Thanks for visiting FixYa!
There could be several reasons why IE8 is hanging. If you're using Windows Vista / 7 you may want to upgrade to IE-9. Click here to download IE-9
If you're using Windows XP, you can try the following:
1) Click here to: Reset Internet Explorer settings
2) Click here for: What to do if Internet Explorer stops responding
3) Make sure you have Service Pack 2 or Service Pack 3 installed on your PC. IE-8 only runs correctly with SP2 or SP3.
4) Re-install IE-8. Click here to Download IE-8 If you can't get to the internet on your PC with IE-8, use another browser if you have one. If you don't have another browser installed on your PC, download Firefox or Google Chrome to a USB thumb-drive from another computer and download one of them to your PC from there.
5) If you've (either, by accident or intentionally) downloaded a third-party browser helper, there may be a software conflict causing IE-8 to hang. To check, go to your Control Panel and select 'Add or Remove Programs'. Look to see if there is a 'third party' browser helper installed. If so, uninstall it.
6) If you're able to get to the Internet at all, go to Microsoft Security Essentials (MSE) - download and install it. Click here to download. You may have something on your PC that MSE can help you with.
7) Make sure you have enough RAM in your PC. At the very minimum, Windows XP needs 512Mb of RAM. 1GB is better.
Hopefully this will help.
No internet explorer display
Go to properties and do show explorer and if also not works then its something wrong in ur registry so make ur registry errors fix with intel software partner reginout
Corrupt or incompatible language id when click on internet explor
perform a system restore this should solve the problem or else
try a fresh installation instead of upgrading back up your documents and desktop items
2answers
Driver for ZTE WP560BD Qualcomm USB Modem under Vista
Put the USB stick in your USB port and wait a few seconds.
When there comes a popup choose folder view.
When not open your explorer and surf to the folder of your USB drive.
look for the installation folder.
You'll see a file named setup or install..
Stay on that with your mouse pointer and click right a menu popup.
Choose properties and choose compatibility here you can choose vista SP1, vista SP2
XP SP3.
when its done run the setup this will work to install the drivers and the aplication software.
I hope this will help.
Best regard: Henk® Mµskita ©2009.
1helpful
2answers
Acer Crystal Eye Web Cam
try reinstalling your camera driver
Win explorer encounter a problem
hit ctrl-alt-del at the same time.
windows task manager will appear.
click on file menu and select new task (run)
type CMD and click OK
type the word explorer and hit the enter key
your desktop should appear again.
Please rate this solution as solved if you are happy with it otherwise ask again :)
Thank you
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
