-   my computer does not present anything on the screen, even though i put the recovery disks it does not function... it has the hard time to read the hard disk and shown nothing at all what should i do -   jeffersin
Feb 19, 2008
-   only the b key doesn't work the manufaturer said it was moisture, and I can not find a keyboard for my everex laptop what can I do?-   Guest
Jan 09, 2008
-   since the touchbook cf18 i owed can withstand water, i tried pouring 1 glass. then i notice that the keyboard developed a problem of a bouch of keys are activating even without pishing it.. i tried blowing it with a blow dryer. still the problem exist. what will i do?? -   oyenboy
this solution divides in to 2 : 1. if u have a little skill in ur hands.... 2. if u dont and u r "left hands" 3. when i think about it...if you still got warranty-go to the store
1. FIRST: wash your hands and touch your fridge or the metal cover of your sound system (for grounding yourself) -disconnect the laptop from everything -open it from beneath - CAREFULLY AND SLOWLY!! -find the screws that are holding the whole boards together -draw a script of where were the screws -separate each level from another -wipe all remaining drops or moisture from everything -leave it to dry -spry conductivity spry on the top level (beneath the keyboard) -assemble everything
2. for the Amateures FIRST: wash your hands and touch your fridge or the metal cover of your sound system (for grounding yourself) -disconnect the laptop from everything -put the laptop (in open position) on a radiator or anything that can produce low heat for day , make sure the heat is not too hot *****NOT MORE THEN 50 Celsius !!!!! ***** -pray to god that it would work
you can also get spray cans of contact cleaner because they displace moisture and leave zero residue and spray the area down with this and leave it for about 1 hour
Was this helpful?
Yes
No
Solution #4
posted on Jul 27, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
You can dunk it in rice to help wick away moisture. Some people have said to use an oven especially with small portable electronics and DO NOT. A small heater with some kind of shield in front works great so its not to intense.
This is going to sound stupid, but open your laptop and put it in a tub that has sides that are at least 3-4 inches above the top of the keyboard and fill with rice. The rice will draw the moisture out... Also works for cellphones that have been dropped in water! (Or in my case, gone through the washer....)
I have a HP PSC 1510 ALL IN ONE. EVERYTIME I TURN ON THE PRINTER IT MAKES AN ALIGNMENT COPY. hOW CAN...
(More)
I have a HP PSC 1510 ALL IN ONE. EVERYTIME I TURN ON THE PRINTER IT MAKES AN ALIGNMENT COPY. hOW CAN i STOP THIS WASTE?
labtop acer aspire saya LCDnya terkena air. bagaimana cara menghikangkan air yang berada dalam LCD...
(More)
labtop acer aspire saya LCDnya terkena air. bagaimana cara menghikangkan air yang berada dalam LCD tersebut.
My Acer travelmate 2492wlmi wont detect or play DVD's/CD's anymore. Even when I go into My Computer...
(More)
My Acer travelmate 2492wlmi wont detect or play DVD's/CD's anymore. Even when I go into My Computer the drive (E) does not appear at all. Any suggestions/remedies would be greatly appreciated? Regards
stuck key (cntrl key next to side arrow key) keyboard will not function when running windows Dell...
(More)
stuck key (cntrl key next to side arrow key) keyboard will not function when running windows Dell XPS M1530
