HP 2840 printer paper jam
My HP2840 jams ever time I try to use tray 2 (loading paper from the bottom tray). It works fine from tray 1, the front tray. I've replaced the separation pad in the drawer and the pick up roller for it that is underneath the unit. I can't figure out why it jams ever time. The paper path seems to be clear. What's the deal???
  • bill475 Nov 07, 2008
    I have the same problem. The paper jams and when I remove the paper tray there is a slight tear on the right side of the paper about 1/3 of the way from the front.
  • Anonymous Apr 20, 2009
    im having the same problem. Is it possible to just clean the sensor? if so, how and with what? Pager goes in to exactly 1/2 page every time. I Have cleaned all rollers, and still its the same.
    Ideas?
The paper feeds in maybe 2 inches, then the printer beeps and stops. After inspection, I sometimes can see the paper come up to the registration roller, then stop. Other times it doesn't even make it that far. If it is a sensor problem, wouldn't the paper stop at the same place every time?
Posted on Sep 10, 2008
Does the paper feed at all(1/2 way) no feed,if not pick-up paper most likely will be feed motor if 1/4,1/2 or 3/4 fed will be sensor at falt or 2nd tray conectors dirty or making false contact.
Posted on Sep 09, 2008
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Hp2840 printer error "Too large to print" even with a very small file.
The unexpected paper size may cause the above error. Whenever your printer detects an abnormal size, this error appears on the device. It mainly happens when more than one sheet are attached with each other or when the paper trays are not set properly. To handle this issue, reload the trays with appropriate paper size followed by front and back tabs. For all the trays verify that correct paper size adjustments have been done. Now enable the jam recovery button and press the button 'GO' to print your document.
http://www.fixya.com/support/t6355639-hp_2640_half_right_side_page
Oct 08, 2010 | HP LaserJet 2840 Printer
It says load paper tray 1
Oct 05, 2010 | HP LaserJet 2840 Printer
LaserJet 2420 Printer: hp 2420n 13.20.00 jam inside rear door...
i have 2420 dn printer..printer reddy mode the power on...but not initlizing...13.20 paper jaming error coming but paper is not jam..hw to resolve
May 06, 2010 | HP LaserJet 2420 Printer
Have a HP Laserjet 2840..error reads "paper jam tray 1" there is no paper jam I can find. Help !!!
There are paper sensing switches above the paper tray. Most likely the actuator has fallen out .
Mar 30, 2010 | Xerox Phaser 6110 Laser Printer
Hp printers continue to jam
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report .
IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue. Solution one: Clear the paper jam Follow these steps in the order presented to resolve the paper jam. Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism
Sep 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Jam in print paper path HP 2840 printer
does the paper feed at all(1/2 way) no feed,if not pick-up paper most likely will be feed motor if 1/4,1/2 or 3/4 fed will be sensor at falt or 2nd tray conectors dirty or making false contact.
May 20, 2009 | HP LaserJet 2840 All-In-One Printer
HP Color LaserJet 2840
Is it possible that you have the default tray set as "tray 1" (the one on top) and the paper is actually in tray 2 (the one on the bottom?)
If so, you should be able to press the "check" button & the printer will accept the paper in the bottom tray.
Shelley
Nov 06, 2007 | HP LaserJet 2840 All-In-One Printer
733 people viewed this question
k24674
jasbo
jasbo
