Question about Jensen JXP340 Car Audio Amplifier
Amp wont work jxp340
The amp is hooked up properly and the power light comes on (green)but there is nothing going to the subs, is there anything i can test or check for inside the amp???
    Champion:
  • 277 Answers
Hi if you got a voltmeter TEST IT ALL ON A LOW LEVEL OF VOLUME!! check the outlets of the amp if there is a signal at all... no? - the amp isnt hooked properly! yes? - check if the volt level on the outlets is higher then the level on the inlets of the amp (the amp is amplifying) no? - the amp isnt hooked properly! or its bad... yes? - connect a speaker to see if its working wont put out a lousy spark? check your system, the problem if probably there... check all the connections, fuses, wires begin from battery and go FWD antill the next device isnt working good luck
Posted on Feb 23, 2006
Can i use my jensen jxp340 amp with my one 800watt 12" 4 ohm subwoofer?
Yes, technically you can, however you will be putting both your sub and your amp at risk. One of the worst things you can do to a sub is underpower it. The easiest way to explain it is n ot giving enough power to the sub leaves it starving for power. The motor structure ends up working too hard to try and move the cone properly and what happens is the sub will usually seize up rather than blowing out in the term you usually hear (ie, I had my system cranked up and I blew my subwoofer).
Secondly, in an attempt to get any real sound out of the under powered sub, you'll probably end up cranking the gain and bass boost on the amp which ends up overworking the amplifier quite a bit and can in turn lead to fried out amp chips, burnt up circuit boards etc.
Thirdly, by maxing the gain bass boost you're going to end sending a lot of distortion through your subwoofer in an attempt to get some decent bass. Distortion kills both subwoofers and speakers alike.
So to answer your question, yes you can hook up your subwoofer to that amp and yes, it will probably play for a while but I wouldn't recommend it. Look for a class d or mono block amp to push your sub as these will give you the most power and best heat dissipation. They are designed to push subwoofers specifically and you will get better sound and longer life out of your equipment. A good rule of thumb is look for an amp within 100-150 watts of both your RMS power handling and your Peak power. Remember, when it doubt, always go a little bigger on the amp side of the spectrum. It's easy to "tune down" an amp by having the gain and bass boost at a lower level (50%, 25% etc), than to turn 'em all the way up just to get some bass and end up prematurely blowing out your sub, amp or even worse, both.
Dec 01, 2010 | Jensen JXP340 Car Audio Amplifier
Subs wont work or do anything when hooked up
Check your safe light on your amp if it's green then the subs are **** but if you don't have a green light check your ground, just because it sparks when it touches dosen't mean it's a good ground so grind the paint off the bolt if need be. If all else fails get new subs, do your self a favor don't get lanzar products there horrible trust me on that one
May 11, 2010 | Lanzar (Pair) MAXP104D Max Pro Series...
My subs don't bump to the beat, they just go THUMP THUMP THUMP...
It sounds like you need to ask for pro help mate, mybe the amp just needs setting properly, Is the amp on bypass for bass, or does the amp run the complete system
Jun 13, 2009 | Cadence TXA 750D High Power Mono Amplifier...
How do I fix the problem so they work again.?
A 1000 WATT AMP HAS PROBABLY GONE INTO PROTECTION MODE BECAUSE YOU ARE TRYING TO RUN 1600 WATT SUBS COMBINED
Jun 08, 2009 | Car Audio & Video
Car amp has power but will not push subs
output blown on power supply - repair by tech required.
Jan 12, 2009 | Sony XM-SD22X Car Audio Amplifier
Sony xplode 1000w amp has green light puts out no power to subs
may haveto turn sub on through the stereo itself if rca cables are good.
Jan 08, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Directed audio 800a amp the protection light keeps blinking
1. Check your grounds. (including grounds for your stereo)
2. Check to make sure the power cable you connected to your car battery is properly connected, and not coming into contact with anything metal.
3. Make sure you are using proper fuses.
4. Check your connection from your stereo to your amp, and your amp to your subs.
Jul 18, 2008 | Earthquake Sound XTREME 900W.5 Car Audio...
Kicker 750.1 Amp wont play music
it is probably the rca inputs on the amp may have fried. was your cd decked turned up loudly before the power went out? did any wires accidently touch each other? If had worked fine and then suddenly stopped, than either a wire came loose or the inputs fried. try using different cables and I also suggest disconnecting power for 24 hours and then reconnect. If the green light is on then it is getting power and the problem is in the rca cables or the inputs
Jun 03, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Something Wrong With my Fosgate 500-a2 Amp
Is the amp being fed directly from the head unit's RCA preamp outputs or is it being fed by another amp's preamp outputs? Try temporarily wiring up a speaker you know is good in place of the sub and see if anything changes.
Apr 01, 2008 | Rockford Fosgate Punch 500a2 Car Audio...
Jensen JXP340 Car Audio Amplifier Logo
123 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
