Question about HP PSC 2110 Color Printer
Printing I chatted with moseclive about a problem I have with printing. When I click on print i get "Unable to start driver for HPZipm12.exe(HPZipm12.exe). I also got a message "Unable to start the application - the Java Virtual Machine cannnot be loaded. Class not negotiated". Moseclive suggested I download JVM using the link java-virtual-machine.net. This took me to a home site for Java and selections were confusing. I did pick one that said download JVM. But nothing happened. Is this a free download?
  • bratislav Jan 22, 2009
    I need drivers for this model
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Mmacko1:
When I saw your chat go through, I knew that I was not prepared at that time to sufficiently help you address your issues - despite my numerous years (20+/-) of experience with HP equipment - primarily because my personal experience with both of these topics was fairly limited. I have not personally experienced issues with the particular driver mentioned, and my issues with java have been less complex.
However, perhaps for these reasons, as strengthened by my unique involvement with the HP brand, I was intrigued by these issues - enough that I spent a great deal of time researching both matters. [Please note that I refer to both matters, because they are two separate issues. The fact that they have both happened to appear at about the same time, if this is the case, appears to be relatively unrelated.]
As I recall, this was the problem submitted to a live chat session. This may be incorrect, but it seems very similar. It appears, as the issues have continued to be posted, that the problems you had have not been resolved. Therefore, I would like to share with you the results of my research, and I hope, serve as an effective vehicle to facilitate actual resolution of your issues.
I do not know, even with review of your numerous postings, what operating system and other equipment you are utilizing. However, I believe this may come into play only at certain times in selecting the appropriate download or the proper procedure for altering a setting within your system. Within my further responses, which you will find associated with the relevant posts (in order to attempt to clarify the issues and prevent confusion), you will see that I have generally assumed (?!) that you are running an XP OS. This decision was based primarily on the timing of release for the product you have indicated is at issue, and the inherent issues of the problems themselves.
Finally, it appears that the message received in regard to the driver is as stated; however, I believe that the actual message you have seen in regard to java, at the end, reads "Class not registered" as opposed to "Class not negotiated". Thank you for your consideration of these matters, and I trust that you will find this information helpful, and that your issues will be resolved. Please rest assured that I will work with you until the problems are handled, and we have reached a "FixYa" level of service...
Posted on Sep 14, 2008
When I click to print, the printer starts, but stop before printing, I must first retart computer, after that it prints automatically.
delete the printer driver and reinstall. your spooler is freezing and it's usually from a corrupted driver install. uninstall the printer and download latest driver from lexmark.
Dec 03, 2013 | Lexmark Office Equipment & Supplies
Tip
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE...
Print spooler service is a computer service that loads the print jobs into the printer memory for later printing and it acts as intermediary between a computer and a printer. When the print spooler service is stopped or malfunction, printing is not possible.
Here are the possible reasons :
1. Virus or Malware infection.
2. Spooler service was stop by accident or turn off to manual/disable mode.
3.Faulty installed printer driver that contains error or incompatible with previous printer drivers installed in your computer or system.
4. Print jobs and drawing jobs were corrupted by accident which caused print que lock and resulting print spooler service to crash.
5. Your printer had printing problem issue with pdf files.
To fix this problem, you have to check if the print spooler service had stop.
Here's how to check and fix the print spooler service.
Go to START
Choose RUN
Type SERVICES.MSC
Click on PRINT SPOOLER and check if the STATUS IS STARTED
If not, on the upper left side, click on STOP to stop the spooler service
Then click on RESTART to restart the spooler
Restart your printer and your computer
Then try to print again and it will surely solve your printing problem.
Another procedure :
Go to START
Right click on DOS command prompt and run as administrator
You should be in this command directory before you
Type CMD and be sure you are in this directory C:Windows\System32
And if not, type this to change the directory, CHDIR C:Windows\System32
Type NET STOP SPOOLER and message will appear like this
Exit and go to C: DRIVE
Choose WINDOWS and click show content if not view all the folder files
Choose SYSTEM32
Choose SPOOL
Choose printer and delete printing jobs if any
Again right click on Command prompts and run as administrator
Type NET START SPOOLER
Exit and restart your printer and your computer
I will works fine right now.
NOTE : You can bypass the C:Drive procedure and just type NET STOP SPOOLER AND NET START SPOOLER in the DOS COMMAND PROMPT if you believe that there are no printing jobs pending.
Another procedure is to download this troubleshooting software and follows the troubleshooter wizard and it will fix your print spooler service automatically and some common problems as well.
Click here to start downloading.
I hope it helps you solving your print spooler problem. Regards to all readers.
on Mar 24, 2011 | Office Equipment & Supplies
Unable read cups raster data os lexmark
It's a Driver issue. You need to reset the printing system by deleting the current printer and re-adding it, like this:
  1. Click the Apple menu, and then click System Preferences .
  2. Select Print & Scan.
  3. Right-click (or Ctrl + click) your product in the Printers list in the left panel, and then click Reset printing system .
  4. Click OK to confirm the reset.
  5. Type your user Name and Password .
  6. Click OK . The printing system resets.
  7. Next go to the Library\Printers folder and move the Lexmark folder to the trash.
  8. Under Print & Scan, click the plus sign and re-add the printer.
  9. The drivers should be reinstalled automatically.
Oct 31, 2013 | Computers & Internet
I printed all the pages I wanted and stopped the printing. today I want to print something else and it wants to prin about 30 pages I don't want, help
Hi
Go to START
Choose RUN
Type SERVICES.MSC
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Apr 14, 2011 | Office Equipment & Supplies
Printer status-offline unable to print
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
Jan 14, 2011 | HP DeskJet F380 All-In-One Printer
Printer was working, but is not now. All cables are hooked up properly and have been disconnected and reconnected. I have several documents in the memory to be printed, but the printer will not respond. ...
Here are four things you can try; may not have to perfom all:
Check to see if your printer is off-Line
1.Open the Printers, Printer and Faxes, or Device and Printers folder.
To do this:
Windows XP users; Click on Start > Settings > Printers an Faxes or Start > Control Panel > Printers and Faxes.
Windows Vista users; Click on Start > Control Panel > Hardware and Sound > Printers.
Windows 7 users; Click on Start > Device and Printers.
2.Right-click on the printer object (icon), and select Use Printer Online.
3.Microsoft Windows 7 users will double-click on icon, select printer and then de-select Use Printer Offline.
Printer Paused
The printer or print queue is paused and the print queue icon remains in the notification area ('systray') of the task bar.
Explanation:This is typically an end user error. Hint: Dragging the mouse cursor over the print queue icon in the notification area will reveal (1,2,3) document(s) pending for (User name).
What to do:
•Double-click on the print queue icon to open the print queue.
•Click on Printer in the upper left-hand corner of the menu bar.
•Is there a check mark next to Pause Printing?
-If yes, click on Pause Printing to turn off this Windows feature.
-If no, confirm that there is a check mark next to Set As Default Printer and make sure Use Printer Offline is not selected.
Delete print jobs from the print queue
Access the print queue.
Delete all print jobs
• Click on Printer in the toolbar and then click on Cancel All Documents,
or
• Right-click in the print queue and select Cancel All Documents from the pop-up menu.
You can also delete individual print jobs
1.Highlight the individual job in the print queue by clicking on it.
2.Right-click on the highlighted job and select Cancel from the pop-up menu.
IMPORTANT! If a job is stuck in the print queue and cannot be deleted or canceled using the above steps, there may be an issue with the printer spooler that controls the printing options in Windows. If you observe this symptom, it may be necessary to stop and restart the print spooler; then retrun to delete print jobs.
How to Stop and Restart the Print Spooler
Problem:
Unable to cancel print jobs; Unable to print; Print queue is unresponsive; Locked print queue; Unable to print; Cannot cancel print job; Printer driver not responding
Solution:
The print spooler controls print options within Windows. A problem with the print spooler can affect printer driver performance and Windows print queue responsiveness. Stop and Start the print spooler to see if observed symptoms subside or remain.
Method 1: Using Administrative Tools
Step Action
1 Click on the Windows logo start button.
2 Click on Control Panel on the right-hand side of the start menu contents.
3 Click on Maintenance.
4 Click on Administrative Tools.
5 Click on Services. NOTE: You may have to provide an administrator profile and password.
6 Scroll through the list and look for Print Spooler.
7
The following two options are available to stop and start the print spooler:
•Click once on Print Spooler to highlight it, and then click on the Stop or Start links in the right-hand window pane,
or
•Double-click on Print Spooler, and click on the Stop button followed by the Start button.
8 Observe the status column in the Services window to verify that the print spooler is stopped or started as applicable.
Trust this helps to resolve your problem. Please vote.
Dec 29, 2010 | Lexmark X5495 Printer
I cant stop my printer printing both sides of the paper
After you attach the two-sided printing accessory (duplexer) to your product, you do not have the option to print on both sides of the paper when you try to print. The two-sided printing option is not available in the print dialog box.
NOTE: The HP Automatic Two-sided Printing Accessory (Duplexer) ships with some printer models and is available as an optional accessory for others. Solution First, choose your operating system. Next, follow the steps to make sure that your printer driver recognizes the duplexer. Show all ' Hide all hpweb_1-2_plus.gifhpweb_1-2_minus.gifWindows XP Follow these steps to make sure that your printer driver recognizes the duplexer. Step one: Add the Duplex Unit to your printer settings
  1. Click Start , click Control Panel , and then click Printers and Faxes .
  2. Right-click the printer icon (c01601478.gif ) for your HP product.
  3. Click Properties , and then click the Device Settings tab.
  4. Click the plus sign (+ ) next to Installable Options to expand the list.
  5. Click Duplex Unit (for two-sided printing) , and then select Installed from the drop-down list.
  6. Click Apply , and then click OK .
Step two: Set the Two-sided printing preference
  3. Click Printing Preferences , and then click the Features tab.
  4. In the Paper Saving Options area, select Automatic from the Two-sided printing drop-down list.
  5. Adjust other print settings as needed.
  6. Click OK to save the settings.
hpweb_1-2_plus.gifhpweb_1-2_minus.gifWindows Vista Follow these steps to make sure that your printer driver recognizes the duplexer. Step one: Add the Duplex Unit to your printer settings
  1. On the Windows taskbar, click the Windows icon (c01319360.gif ), and then click Printers .
  6. Click OK to save your settings.
hpweb_1-2_plus.gifhpweb_1-2_minus.gifWindows 7
Oct 31, 2010 | HP Photosmart Premium C309g multifunction...
My printer is not printing any document and when i check whats printing it says its deleting another document
click on start
goto control panel
select printer and faxes
double click on printer icon
and delete all the que printing jobs
Jun 18, 2009 | Dell 926 All-In-One InkJet Printer
Printer will not print
First uninstall your present printer driver and reinstall it and it will solver your problem.
Feb 18, 2008 | HP PSC 2110 All-In-One InkJet Printer
I keep getting the message unable to print see trouble shooting in manual
If trying to Print in Word 2003 - 2002 - 2002
Click on tools > options > Print tab > Uncheck Back Ground Printing. Click on ok. Try Printing.
If you are trying to Print from Word 2007.
Click on Office button > Word options > Advanced > Locate Print options and uncheck Backgound Printing click on ok. try Printing
Oct 19, 2007 | Brother MFC 210C All-In-One InkJet Printer
HP PSC 2110 Color Printer Logo
67 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
