Question about Apple iPod nano
OK to Disconnect
My Ipod Nano apears o be stuck on the "OK to Disconnect" screen. I am able to charge it through USB and an AC adaptor (that I have from another iPod) but unfortunately it will not let me actually play any songs. Any idea how to remove the OK to Disconnect screen or just reboot the whole thing? Thanks
Fixed it myself! Reset by holding down Menu and centre button until soft reset complete. All working fine now.
Posted on Feb 21, 2006
SOURCE:
I have apple iPod 2Gb. It doesn't start. it's display only busy icon. I think's it's frozzen how to sove this problem
How to Fix a Frozen IPod Nano
iPod Nanos will sometimes freeze up, sticking on one screen or not even turning on at all. If your nano is locking up, there are a few things you can try to get it working again.
1. Turn off the hold button. First of all, make sure that that wasn't the problem--don't worry, we've all done dumber stuff.
2. Cold boot. Assuming that wasn't the problem, flick the hold button on and off a few times, and then make sure it's off. Hold down the Menu button and the middle button button for about 15 seconds; this should reset the iPod nano, which may fix the issue. Make sure that the iPod nano is fully charged before attempting this.
3. Recharge. If that didn't work at all, try plugging the iPod nano into the USB port of a computer, using the adapter that came with it. Be sure to plug directly into the computer, and not through a USB hub. The USB needs to provide adequate power for the iPod nano to function, and it may be unable to do so through a hub. The iPod nano should be recognized by the computer; once it is, you simply need to safely disconnect it in iTunes, and it should be functional. If it doesn't show up on the computer at all, give it about 20 minutes, leaving the iPod nano connected to the computer, as the nano may be under-charged, which requires a few minutes to re-charge. If it's still not working, try plugging the iPod nano into a different computer.
4. Try again. If the Menu + Middle Button fix seemed to work, but just cycled the nano back to one of its starting screens (including the "do not disconnect" or the "loading Apple logo" screen), try that fix again. If it still doesn't work, try to charge it for a while, and then try it once more.
Feb 22, 2011 | Apple iPod nano
How to charge it.
You need a nano USB charger cable to connect the nano to your computer or an AC adapter USB nano cable to plug the nano into an AC outlet. You can find a variety of cables and adapters on the internet that will allow you to charge your nano.
Please rate this solution. Thanks.
May 10, 2010 | Apple iPod nano
I need the instruction on how to set up my
here's the website: http://support.apple.com/manuals/#ipod
you can download the user manual from there.
Dec 31, 2009 | Apple iPod nano
Don't know how to reject the ipod nano when charging at computer
  1. Once the iPod is attached to the iPod and USB port in the computer, an icon will appear at the bottom of the computer desktop. The icon is from removing the USB Mass Storage Device
  2. Now, click on the enject icon and it will show which drive the USB cord is attached to. Once the icon is clicked on, the iPod will show an arrow going down and reading "OK to disconnect". Once able to disconnect, the USB cord can be removed from iPod.
  3. Another way to eject the iPod from USB cord is through iTunes. Once anything you want sync'd to your iPod is complete, a message will appear on the iPod reading, "OK to disconnect". Just like it did on the ejecting icon on your desktop.
Sep 24, 2009 | Apple iPod nano
JBL on stage micro will not charge my ipod any more. It plays songs fine from the ipod but for some reason is not charging it. Any suggestions?
The JBL Onstage Micro is supposed to disable recharging of the iPod when running off AAA batteries to avoid draining them, but sometimes this setting gets stuck even when the unit is plugged in through the AC adaptor. The workaround that I found is pulling out and reconnecting the iPod to the Onstage Micro (while both are powered on) and then unplugging and reconnecting the AC adaptor. Sometimes you have to repeat this process, but the iPod should start recharging after that. I tried it on the new 5th generation nano and this seems to work.
Jun 14, 2009 | JBL On Stage Micro Portable Speaker Dock...
Ipod screen says connected eject before disconnecting shows picture of charger but won,t do anything the time is stuck the battery isn,t charging help
I had a temp problem like this too! I found that by purchasing the plug adaptor, it got around to charging the battery on the iPod eventually. Check that the points of the USB cord at either ends haven't been bent or are at least clean.
Apr 05, 2009 | Apple iPod nano
Ipod 4 GB not charging and gets very Hot when I try to charg
my nano 4gb ipod gets hot when i try and charge it on conputor ac ports it gets hot
Mar 18, 2009 | Apple iPod nano
Ipod nano 8GB 3rd generation FROZEN!
You need to reset your ipod. Flip the hold switch on then off, then press select button and menu button at same time. Hold for 10 seconds or so. Ipod should shut off and reboot to apple screen. If this doesn't work first time try again. This should solve any stuck screen problems. Mine was stuck on pioneer screen and this operation fixed it.
Aug 09, 2008 | Apple IPod nano Second Generation MP3...
Ipod not recognized by computer
I have the same problem. My ipod nano is not reconized by my computer or any other and the Ipod's screen is locked. The screen doesn't light up and only apears the time and a battery half way full.It doesn't turn on or play and it doesn't turn off either, but some times it begins to work again but nor for long. I am runnig windows xp and the latest itunes version.
Jul 29, 2008 | Apple iPod nano 3rd Generation
My ipod wont charge to the computer nor the ac adapter. before the battery died it when i was hooking it up it charge on the screen would display fully charged, but i it's wasn't. also, on the upper right...
Do the 5 R's:
These are for Nano, but they apply to all iPods:
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
installed.
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
May 24, 2008 | Apple iPod nano
Apple iPod nano Logo
564 people viewed this question
Top Apple Audio Players & Recorders Experts
Parshiv Luthra
Marvin
Marvin
Dapid Candra
Dapid Candra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
