Question about Nintendo DS Console
Nintendo ds will NOT boot up
Hi, I fix broken hinges on the Nintendo DS, but when I put it together, it did not have touch screen function. I messed with the cables, and I thought I had all the cables connected, and the F2 fuse was blown. I soldered it up, and it charges the battery, but now when I try to power it up, the green light turns on, the screen flashes for a second, and then it shuts off again. It is not the battery, I am almost sure of it, because it was able to charge a DS Lite battery, but the battery for the DS Lite starts up, and then dies like the original battery. If there is something that needs to be changed, I will gladly accept any advice.
  • Jason Calvin Sep 10, 2008
    Hey! I figured out that you need a little black connector in one of the smaller cables that connect to the bottom screen. I got the power on, but I lost touch screen. Unfortunately, I lost one of those connectors. So, I'm going to try to improvise. Will get back if it works, or not....
    HAHAHAHA!!!!!!! I did it! For those of you who may have a similar problem, let me tell you how I did it. First, you cut a piece of paper the EXACT size of the cable, then you fold it up like this:
    Sorta, well you leave just a bit flat and the rest should be folded up...
    Then you insert that where the cable goes, then you put the cable in on TOP of it. Close up the system and you system should run very, very smoothly.
    Problem Solver:
  • 5 Answers
You need a new top screen......ebay.
Posted on Sep 25, 2008
  • RU-ready Sep 09, 2011
    Could this be the cable going to the top screen?
4 Suggested Answers
SOURCE: Nintendo ds hinge fix
My sons ds hinge broke and i taped the console, he removed the tape and eventually he broke the cable and the black wire. we bought another case and a new cable and replaced them both and now the ds only flicks on then goes off. we assume its the wire,as its a small coaxial one,we soldered it together. it charges fine but wont power up any more,we have tinkered with it so many times and cant get a result. I am currently trying to find a repairer to look at it. I dont recommend repairing it yourself to save money, put the money towards a repairer.
Posted on Oct 13, 2007
SOURCE: nintendo ds lite has a broken hinge
You can buy a new plastic housing for your DS lite on many different sites. Some are great quality. If the DS still works (despite the broken hinge) it makes sense to replace the housing.
You should be able to find enough videos on youtube to learn how to disassembe the DS and not do any harm. Make sure that you buy a tri-wing screwdriver (also called a nintendo screwdriver).
Hope this helps
Posted on Dec 23, 2008
Skelasoldier
  • 35 Answers
SOURCE: my nintendo ds lite charger hole is crushed and
Well basically you cant charge it without a power input source so you gotta buy a new one or buy a power replacment kit on amazon or ebay
Posted on Aug 23, 2009
DS Lite Top screen is all white after replaced for new one
you should use a crystal casing because every time you open the ds the wires get messed up or put some thing on the hinge so the ds hinge will not get loose.
May 12, 2009 | Nintendo DS Lite
Touch screen not working
Well, did you call nintendo to see if you were under warranty?
why did you try? do you have a degree in engineering? Regardless, now you have voided your warranty. Call them and see.
Jan 22, 2009 | Nintendo DS Lite Console
Nintendo DS Touch Screen has all these really distorted colors
well it would be the bottom lcd not the bottom touch since that is just a clear peice of plastic when removed from the lcd it would be your bigger ribbon that would be your display and smaller you touch screen.
try adjusting the ribbon for the screen make sure it clean as well and in good contact with the board.
Oct 04, 2008 | Nintendo DS Console
My DS Lite
No there isn't, you've been duped my friend (sorry to say). You need to send in the DS Lite because the electrical components for the touch screen are quite literally broken. Either that or you can... Pay for a new one...
Here's a mental note for later: Don't buy or trade electrical gadgets from non-reputable sources, this being your friends as well.
Aug 22, 2008 | Nintendo DS Lite Console
Fualt on DS
By putting the case together you've short circuit the black wire with the powerconnector. Open the bottom case and check the wire. Check Fuses F1 and F2. 99,9% change that one of them is blown out. Replacements can be found on the Internet
Aug 14, 2008 | Nintendo DS Lite Console
Nintendo DS Power problem powers on but goes straight off
You may have not put a connector back on properly....
http://www.instructables.com/id/Replace-the-top-screen-of-a-Nintendo-DS-without-o/
Go there and read it through - there are also other walk-throughs for repairs on this site that are very thorough.
Best of luck
Dec 24, 2007 | Nintendo DS Console
Nintendo ds
Its possible though sometimes it is expensive so dont worth the work.
-Top screen broken: you can buy a replacement and carefully do the work by yourself with the help of a guide (youtube have many) and some tools (3 winding screwdriver is the less common though not much). The foil data ribbon can be bought separatelly for the original NDS though the new NDS lite have it soldered and very difficult to work.
-Broken plastics: a broken hinge means you need to buy a replacement shell. Anyway buy a complete shell from a DS modding shop or take parts from a non broken plastics DS (water damaged one may be good) in a place like ebay. You would be lucky if you find a non broken screens and good plastics DS for parts.
At the end you may be over your repair budget and not only that, you would be very near to buy a new unit with this money. Each one make its own choice.
Good Luck...
Dec 03, 2007 | Nintendo DS Lite Console
Nintendo DS Lite top screen broke on one side
The only way you can repair this properly is to replace the casing with a new one... the hinge is a common problem and over 90% of my customers on the DS and DS Lite need a new case due to broken hinges. Once the plastic bit has broken then it will only get worse. The small bit that you say fell out was the actual hinge itself (a small black part with a silver end that twists and locks your console into place when open). Hope that helps!
Aug 21, 2007 | Nintendo DS Console
Nintendo DS Console Logo
1,806 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
