Question about Saitek Mini Color UFO Hub-Olive Green
Router to router
How can i do the color coding bcos i did
one wg G wo B wbl O wbr B and then, the other end too wo OR wg BL wbl GR wbr BRO but still cannot get net what should i do now
    Problem Solver:
  • 24 Answers
router to router - 2d6ecac.gifThank you
Posted on Sep 29, 2008
I have a D Link WBR 1310 router. Is this outdated and would it solve my intermittend internet service if I should upgrade?
The d link wbr 1310 is end of life in the us as of may 1 2011. I have a dir-615 that I stopped using 2 years ago b/c of connection problems and I believe the dir-615 is newer. I think you should upgrade.
Jul 24, 2011 | D-Link DIR-615 Wireless Router
My WBR-1310 doesn't do wireless to my laptop.
theres a couple of version of this router http://www.dlink.com/products/default.aspx?pid=WBR-1310&tab=3 I'm using the manual from here http://www.dlink.com/products/?tab=3&pid=WBR-1310&rev=WBR-1310
on a working PC download and install this program http://www.xirrus.com/library/wifitools.php this will detect all the wireless signals being broadcast - see if the router is actually broadcasting - if it is detected on your PC then it may be that 1) the firewall is blocking access or 2) the security code is entered wrong - -log into the router and remove the wireless security and see if you can now detect
Mar 18, 2010 | D-Link 802.11g Wireless Router WBR-1310...
BL-C131 port forwarding.
So you've configured port forwarding on the router. Do you have any anti-virus applications installed or have your set an exclusion in Windows firewall?
Feb 01, 2010 | Panasonic BL-C131 Network Camera
Need to know the color coding for rear turn signals which side is gr/bl and which is gr/br
Just hook one of them up and you'll know. all it can do is flash. You have a 50/50 chance of being right the first try.
Oct 09, 2009 | 2002 Triumph Triumph Bonneville
I need tio hook up a 4 wire cooktop(Bl R, W, Gr/copper to a 3 wire boat(Bl-L1, W-L2 and Gr) Can anyone help?
hi my name is mark, you need to check local electrical code before wiring cooktop. if it is allowed the white and ground/copper can be tied together with green from house. but if not allowed you will have to run a seperate white wire or new 8ga 3 wire/ with ground from breaker box. check the code first. and shut off power before you wire cooktop. thanks for your question.
Mar 13, 2009 | KitchenAid 36 in. KECC568 Electric Cooktop
Double picture
convergence issue - has the set sustained a knock?
either way, it will require expert help or at very least access to a cross hatch generator
Nov 22, 2008 | Philips 9P5034C 50" Rear Projection...
Networking
Against my better judgement, because crimping doesn't work half the time, here's the color code.
A 4-pair Cat-5e or 6 cable has BLUE, ORANGE, GREEN, and BROWN pairs. The ones with the most white are called Tip. In a 568B wiring scheme, they go 54361278.
or, like this
1 2 3 4 5 6 7 8
wo ow wg bw wb gw wbr brw
Data is actually carried on pins 1 2 3 and 6.
If you wire the other end of the cable the same way as above, it's called a straight through cable.
If you reverse the orange and green pairs, it's a crossover cable. This is also the pattern for 568A
1 2 3 4 5 6 7 8
wg gw wo bw wb ow wbr brw
Getting the wires to untwist and behave is half the fun, that's why we use special plugs when we absolutely have to crimp. Otherwise, we use a jack and patch cord.
Carl
Oct 23, 2008 | GE (JASHO96273)
No wifi connection
connect by cable long enough to complete the setup
type this address in your browser
http:\\192.168.0.1
which should start the routers webinterface you can navigate thru the Wireless settings ,s et channels etc
and copy them to the pc that you are trying to connect,
WEP - wireless encryption protocol - a method of scrambling transmitted data for security - both ends of the link have to have the same code key or they wont talk to each other
Apr 29, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Saitek Mini Color UFO Hub-Olive Green Logo
95 people viewed this question
Top Saitek Computers & Internet Experts
micky dee
Ajay Virvan
Ajay Virvan
Are you a Saitek Computer and Internet Expert? Answer questions, earn points and help others
