Question about Toshiba SD-3990 DVD Player
Display says "no"
I have just been given this model from a neighbour. All instructions are in French. The DVD has never been used. Once the disk is in - it displays "no". Is this the same as "no disk". If this is the case I would think there is a mechanical problem. She thought it may have something to do with the parental setup. Hope you can help. Thanks!
  • 3 Answers
I had the same problem with the unit displaying the word "no."
Take the cover off and disconnect the two ribbon wires on the PC board, then reconnect them. It's a peice of cake.
Truly Me,
King Tung
Posted on Oct 30, 2008
READ CD BUT NOT DVD NO DISK Disply
you need to replace the laser assembly in the drawer laser is going out
Jan 20, 2013 | LG LHT250SC Theater System
Create boot disk
Insert a blank diskette into the floppy drive. Click start click on computer you should see all of you drives.
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
hope this helps
Aug 22, 2012 | Seagate Computers & Internet
I have misplaced both my window and administrators passwords. So now, I can't enter into my system
There is a piece of software called ophcrack, I have used this a couple of times to sort this problem
May 05, 2011 | Computers & Internet
I have a nasty virus that did much damage to my Inspiron 531 desktop. I am no loner able to restore to previous date and the disks that came with it do have have the operating system on them. How do I...
Put the first disk in that will say operating System.
Turn the computer on and immediately keep tapping F12. This will show a boot menu. Select the CD/DVD Drive.
If prompted 'Press and key to boot from CD/DVD...' press any key.
This will load into the recovery disk follow the on screen instructions to recover the computer.
Apr 26, 2011 | Dell Inspiron 531s Desktop Computer
When I turn on the computer it takes a while to boot up, and when it does it stays idle for 10 seconds or so then shuts off?
Sounds like there may be a problem with your OS X.
You will need to boot from your OS X DVD and run your Disk Utility to do a repair on your operating system.
To do this, start your iMac and pop in your DVD. Once you hear the boot up sound, hold the Option/Alt key. You will be given the option to choose between your hard drive boot up and DVD boot up, so choose the DVD. It'll take a while longer to load than usual as you're booting from a DVD, but once your Mac has booted up, use Spotlight (Apple + Space, type "Disk Utility") to load up your Disk Utility program. Once you've got that open, select your hard drive on the left and click "Repair Disk Permissions" and then click "Repair Disk."
Once you're done, reboot and your Mac should be working good as new.
Mar 25, 2011 | Apple iMac Desktop
I have a Panasonic VHS-DVD player/recorder model DMR-ES35V. I was recording and playing back at the same time using a DVD-RAM disk (using the time slip feature). After about an hour of viewing I got an...
FOR AL THOSE WHO HAVE A PANASONIC DMR-ES35VS THERE ARE MAJOUR PROBLEMS WITH THE RAM DRIVE WHEN IT IS DEFECTIVE THE DVD PLAYER WILL MAKE A SOUND LIKE IF ITS TRYING TO READ OR YOU WILL HERE A SORT OF SCRATCHING SOUND THIS MEANE YOUR RAM DRIVE IS DEFECT IT WILL COST 200 DOLLARS FOR THE PART
Oct 21, 2010 | Panasonic DMR-ES35VS
My dvd/cd rom is not working and is not displaying on my computer folder/dialogue box of hp pavilion dv6000 laptop it is not displayed wen i click on my computer to check it. Others; local disk, recovery...
click on the start button>in the start
search box type in regedit>now you will
see the regedit option listed there>click
on it and click on continue>now you will
have the registory editor window
open>here on the left hand side double
click on HKEY_LOCAL_MACHINE>under
that double click on SYSTEM>under that
double click on Current Control Set>now
double click on Control>now double
click on Class>now look for 4D36E965-
E325-11CE-BFC108002BE10318.click once
on this option.>now on the right hand
side look for "upperfilters" &
"lowerfilters".you may have both of
them or any one of them.just right click
and delete any such file.after this close
all the windows and restart the
system.if everything goes fine your dvd
drive should work fine.
Jan 20, 2010 | HP Pavilion dv6000z Notebook
I bought a ET1331G-03w at Wal-Mart. I want to create recovery disks. I follow the instructions given with the product....For Windows 7 click (start)> All programs>emachines> eMachines Recovery...
What type of disks are you using? You cannot use DVD RW. You need to use DVD - R . I have had this very issue. Hope this helps.
PS, once it tries to write to a dvd and fails, try a new one.
Dec 30, 2009 | E-Machines eMachines Desktop PC
Disc Error
Try to clean the read laser and the laser pickup, by using a DVD cleaning disk. If this does not work you may have a misaligned laser or pickup.
That may sound like a canned response and it is, however it is a good start. I would also check the format of the video on the DVD-RW, and make sure the DVD player is set to display that format.  Also might I suggest that you try the documented Disk loading instructions. I know that sounds stupid, but I was working on a customers DVD player one day and I downloaded the manual, and I was shocked to find out that I was not following the recommended loading procedure, once I did that all of the disks worked (stupid? yes, but that's how things are now).
As I said try to clean the pick-up and laser, check the format of the DVDs, and then follow the recommended loading instructions.
I hope this helps
Thank you,
Shuttle83
Apr 23, 2008 | Sansui VRDVD4005 DVD Player/VCR
Toshiba SD-3990 DVD Player Logo
498 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
