Question about Sunfire Audio Players & Recorders
My stereo says its locked and won't work. How do I unlock it?
Why do my door locks stop working when I try to install a stereo in my 2000 dodge caravan?
Hi Tony, I'm AL the owner of Big As Auto Repair
I look forward to helping you with your problem!
Tony, most likely you have hook your stereo into wiring that is interrupting the signal that comes from the computer to unlock the or lock the doors. The best way to see if this is your problem is to unhook the stereo and see if the problem goes away. If it does you'll need to hook the stereo to some other wiring. If you problem is still there you'll need further assistance. Click here for Help! Auto Repair
Feb 26, 2015 | 2000 Dodge Caravan
Locking failed, how do I fix?
you will have to look under dash and trace the harnesses for damage , disconnect or improper hook up
May 02, 2017 | Hyundai Elantra Cars & Trucks
I was having alternator problems a week ago,so i turned off my stereo so my battery would last longer,I put in a new alternator on the expedition and now I've been trying to turn on my stereo and it...
Thanks for choosing FixYa. More then likely, you need to enter the unlock code on your radio. It locks up when there is a power loss. As far as the code, it may be in your owner manual or you may need to contact Ford to get it.
Jan 25, 2012 | Kenwood Car Audio & Video
2008 chevy impala rear locks only work partially
I have problems with all door locks. Some work some others don't. Or right side of the car won't lock or unlock. Or the left side won't unlock or lock. Or they all work great . When it's very hot outside none will or will.What's the problem.
Sep 09, 2011 | 2008 Chevrolet Impala
I changed the key batteries for my 1999 BMW 323i after they died. Afterwards the remote unlock and lock won't work, the car also won't start but it can turn over/on and the radio and the lights...
stick the key in the ignition, turn it to the on position, remove it within 5 seconds, then hold the unlock button down and press the lock button 3 times within 10 seconds and release both buttons. The doors should lock/unlock to give you confirmation and your key should work.
Jul 05, 2011 | 1999 BMW 323 Series
I have a Ford Escape 2008 model - after a service, we received the car back with the CD/Stereo player locked. The Ford dealership are unable at this stage to provide me a code for the unlocking of the...
yeah they should be able to unlock the stero /unhooking battery without retreiving codes will lock up stereo . i would tell them get codes or get new stereo
Nov 05, 2010 | 2008 Ford Escape
My 2004 cavalier stereo is locked.i put a
That's the anti theft lock... It's not a system that comes with every car radio, but i've saw a few of those on cavaliers and sunfires, and a few civics, and i think a couple others have some too, but i've only personnally seen and worked with the ones i mentioned. In any case, unfortunetly even if i know how they work, there is no easy way to get them unlocked and working again. You need the special code for that specific radio, and to get it you don't have the choice to go to you GM dealer and ask them to do it. You need their special machines to get the codes and get the radio unlocked, there is no other way other than changing it for an aftermarket radio again like before. So if you really want to get the OEM radio going again, go with the car to your GM dealer to prove to them it's not stolen and they will get the codes from the GM support center with their dealer code and will unlock your radio, but of course they will charge for it, dealers never give any gifts to anyone.:p So ask them how much they charge for the service, cause in some cases, buying an aftermarket radio will cost less.
Jul 08, 2009 | Chevrolet Suburban Cars & Trucks
94 bmw stereo unlock code
If the stereo is original the unlock code for the stereo is the last numbers of the chassis number
May 05, 2009 | 1994 BMW 3 Series
18 people viewed this question
Top Sunfire Audio Players & Recorders Experts
shaun taylor
Are you a Sunfire Audio Player and Recorder Expert? Answer questions, earn points and help others
