Compaq Armada M700 Notebook Logo
Posted on Aug 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My laptop is compaq Armada M700 with Windows XP Professional version 2002, how will i know if my battery is already fully charged? i have been charging it for a day and when I disconnect the charger tha laptop turns off
Paljeet Singh
Level 1:
New Friend:
  • Contributor 29 Answers
  • Posted on Aug 25, 2011
Paljeet Singh
Contributor
Level 1:
New Friend:
Answers
29
Questions
0
Helped
5484
Points
89
Your laptop is having a problem.
First make sure you can see it charge either on the taskbar where the system time is shown.
Then if you see it charge then you'll that it's charging. If you have a similar laptop or ask a friend to see if the adapter charges the battery if so then your battery needs to be replaced. If the battery loses the charge after being charged then the adapter needs to be replaced. If both the battery and adapter work together then it's time for it be tuned up.
Secondly take out the battery and plug it in so you see if it stays on. It probably will so what you do is take the battery and see on the internet if there's been a recall of laptop batteries for Compaq Armada.
Dou dou
Level 3:
Master:
  • Master 340 Answers
Dou dou
Master
Level 3:
Master:
Answers
340
Questions
0
Helped
55282
Points
1116
From your description it seems the battery hasn't been charged right, so there maybe something wrong with the battery or laptop. First, do a clean to the your Compaq Armada M700 battery and the connection chip on your laptop, then to see if there is something get better. When you charge you laptop, there will be a lights to note the state, do you have noticed? Else if your Compaq laptop battery are used for 2 years please try a new one
How do i get to the recovery partion on compaq armada m700
Dear Lizanne,
To get to the recovery partition on your Compaq Armada M700, turn on the notebook and press F11 repeatedly until "Windows is loading files..." displays on the screen. Then, follow the on-screen instructions.
If your notebook originally came with Windows XP or an earlier version of Windows, try pressing F10 to enter recovery instead of F11.
Hope you may find these instructions useful!
Best regards,
Miguel L. Martins
How will I know if my laptop Compaq Armada m700 is fully charged already?
Hi
You do not say which operating system you are using.
Right click on the toolbar at the bottom of the screen > properties > notification area > tick the Power under System Icons - Select Which Items to always show > Apply > OK > float the mouse on the battery icon to see % of charge and charge time remaining.
I hope this helps.
I have the majority of my product key but 3 of the digits are smudged, how can I find out?
If you still have XP or another version of windows installed try using "Magic Jellybean"
http://www.magicaljellybean.com/keyfinder/
If you have already reformatted your drive, there is very little else possible that I know of to recover a smudged COA key.
Need to know what type of printer to buy for my compaq M700 laptop
As long as Windows XP or Vista supports it. Just look for the printer specifications wether it is supported by Windows XP, SP1 then youre good. There are just too many models to list here.
Code 10 error over my network adapter in device manager
You need to download and install the proper drivers from Compaq (now HP). Go to http://www.compaq.com and do the following:
Click "Get Support" at the top.
Enter "armada m700" in the "Enter a product number" box.
Click the little submit button that looks like ">>".
Click "Download drivers and software".
Click one of the "Windows XP" links. Doesn't matter which one.
Scroll down and click the "Download" buttons that correspond to each driver you want to download.
Install the drivers you downloaded.
Code10 over my Network Adapter
go to the intel website and troll for the driver for that card.
make sure in adminstrator tools, services that windows zero configuration is 'started'
System disk for compaq m700
Hello Connie7077,
This is Romeet, id like to try and assist you. Please specify for what operating system you would like to download the drivers for? and i am assuming you have an Operating System CD with you already.
Please refer to link below for Operating System Specific System Drivers.Example for windows XP Professional you will need to click on " Windows XP Professional " and so forth.
Let me know.
B.Regards
Romeet
2answers
Compaq Armada M700 Shut Off During Windows XP Pro boot
remove the battery and directly connect to power and see.
Compaq Armada M700
Always start with the simplest solution first so start by cleaning all the contacts, AC adapter laptop plug, laptop socket, laptop battery contacts and battery contacts. How have you confirmed power output from the AC adapter? have you used a voltmeter to ensure you are getting power at the laptop end? Have you used a voltmeter to test the battery? Assuming you have tried all this don't forget that almost any component can interrupt power on some laptops, however you're 2 main culprits with this kind of problem are usually power controller (voltage regulator) and in some cases, on a laptop of this vintage, the charge controller built in to the battery. Try it with a different battery if you have one.
4answers
Compaq armada m700 power failur...
try removing the large battery and powering off wall supply only...if ok, then replace battery
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
